bazzamon Samba Member
Joined: January 09, 2007 Posts: 38 Location: Guildford NSW
Posted: Thu May 31, 2007 4:26 am Post subject: AFM |
Ihave a 1.9l digijet & have noticed the cost of a new AFM to be considerably more than the AFM on a 2.1l digifant...Is it possible to have the digifant AFM modified to fit the digijet??? Baz |
tclark Samba Member
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Thu May 31, 2007 9:36 am Post subject: |
I played with this several years ago, and if memory serves, one of the differences is that the air intake boot is a different size at the AFM side - just slightly, so that part won't fit. Even if that did fit, you likely have a narrow-throat throttle body which that same boot is way too big for.
You can't even swap the whole air box as the mounting is a little different, too (again, IIRC). I unfortunately can't speak to the possibility of putting a 2.1 AFM on a 1.9 airbox.
I think the point is that you'd have to get a bunch of other stuff to make it work which would likely eat up all your cost savings...
-Damon _________________ '84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go. |
klucz Samba Member
Joined: February 14, 2006 Posts: 1062 Location: Chicago, IL
Posted: Sat Jun 02, 2007 11:43 am Post subject: |
I might be able to get you a new Digijet AFM for a little less than what the Digifant piece goes for. PM me in you're interested. |
