1950split Samba Member
Posted: Thu May 31, 2007 3:56 pm Post subject: GB 580A manifolds for 40 IDF/DRLA and Thing shroud |
Hi!
I own both these parts. I was told that you cannot use these manifolds with an OEM dog house fanshroud, that I have to use a 36hp fan. And what about a thing shroud, will the manifolds clear it??
Thanks in advance
Philippe |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Thu May 31, 2007 5:22 pm Post subject: |
The Berg catalog makes no mention that they won't fit. They do say you can't use a carb to carb linkage and need their fan mount linkage. And the odd think is that the fan mount linkage only works one OEM, which includes Thing, shrouds.
http://www.geneberg.com/product_info.php?products_id=994
Gene Berg wrote: |
VW to 40 IDF (has additional material at the carburetor end so it can be ported to 44 or 48 IDF). Also accepts Dellortos used for VW as they have the same bolt pattern. These will not work with cross bar carb to carb linkages. Requires our fan housing mount linkage such as GB 454 for IDF or Dellorto. SW 6# |
_________________ Glenn
Member #1009
#BlueSquare |
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Thu May 31, 2007 8:26 pm Post subject: |
I believe a carb to carb cross bar linkage will hit the heater outlets on a stock fresh air shroud of any type when using these manifolds. I'm pretty certain the '73 Thing shroud would work. To confirm, I say call Berg and ask them.
Its not odd Glenn, the cheap aftermarket shrouds have the 4 bolts holding the alt/gen tin rotated and typically are missing the coil mount inserts. So Berg says their linkage "won't fit" those (crap) parts. _________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
darisb Samba Member
Joined: March 25, 2012 Posts: 78 Location: Coos Bay, OR
Posted: Mon Jan 30, 2017 12:30 pm Post subject: Re: GB 580A manifolds for 40 IDF/DRLA and Thing shroud |
1950split,
Did you ever determine if the Thing fan shroud and the GB580a manifolds would work together? _________________ My Spyder 550 build: http://www.thebouthilliers.com/spyder/ |
