Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Tue Aug 26, 2014 6:42 pm Post subject: ADAM WESTY, '78 Champagne Edition w/Subaru 2.5 SOHC |
Hello everyone,
I haven't had a build thread on here before and I decided to start one for my '78 Champagne Edition Westfalia. I have had this bus since 2000 and it used to be my daily driver. I knew it was built Feb,1978 but I just recently found out it was built the same day as I was born, Feb 10th 1978, pretty cool !
The then new motor, from a company that is now out of business ( no surprise there ), sucked a valve shortly after it was installed back in 2004. I pulled the motor to rebuild it, some stuff happened and it never got fixed. Rather than fill this thread with the story of what happened, read about it here: http://www.thesamba.com/vw/forum/viewtopic.php?t=511092&highlight=
If you read that link I posted above, you will know why I am doing what I'm doing as far as the swaps are concerned. Also, if anyone has any of the parts I have listed in that thread, please PM me.
Some quick things to bring you up to date.
Back in 2012, shortly after my original post linked above, I was allowed to remove ALL of the automatic parts I needed from a totaled '77 Champagne Edition bus for free. So, I will be doing an automatic conversion as well.
I was given a 2000 Impreza RS 2.5 SOHC motor for free and it is currently at my machinist getting finished up so I can put it back together. Please don't go on about the 2.5 headgasket issue. I have rebuilt several of them with zero issues. I use MLS headgaskets as well as have the heads and block prepped by my machinist.
I was also allowed to remove the rest of the parts I needed from a 1999 Legacy with a 2.2 SOHC that was heading to the junkyard for free. If you're wondering if the 2.5 harness will work on a 2.2 it will, as long as I use the 2.2 intake and 2.2 cam and crank sprockets. The '99 2.2 SOHC is Subaru's "bastard" motor in that it looks exactly like an EJ25 SOHC only it's an EJ22.
I will be doing dual radiators in the engine bay as well as putting a heater core and squirrel cage into the stock VW heating system.
I will be bastardizing the Subaru cruise control and adapting that to my bus as well as keeping the wiring for Subaru's A/C to have for a future air conditioning install.
I picked up a barely used KEP adapter for an auto tranny on here for $200 less than a new one ( The guy did a syncro swap in his Vanagon and you can't use an automatic in a syncro ).
Pics of the Subaru donor:
My spoils:
Two days ago, I gave Adam Westy a quick bath and I pushed him into my garage ( with my Subaru Forester ) so I can begin rust repair.
_________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
Keith Samba Member
Posted: Tue Aug 26, 2014 6:55 pm Post subject: |
There isn't too much rust on him, thankfully. I got 85% of the rust repair panels on this site from Raul (VW76WESTY) and will be using genuine VW metal to replace the rust.
So, today I decided to start on the passenger dogleg.
The donor dogleg:
I cut out the rot on the outside skin. I will cut the inside tomorrow:
Rough cut of the donor area. This will be cut down more to weld it in:
Immediate plans are to repair the rust, do the swaps, get it mechanically sound and then prep it for an outside respray in the original colors over the winter.
Future plans are to restore the interior, lift it and install knobby tires as well as a "roo bar" and other off road bits. I will likely end up regearing the trans as well.
Here's a quick running tally of my expenses so far.
•Rust repair panels: $250 shipped
•Near new crank for 2.5 motor: $200 ( just over 1,000 miles on it )
•Set of good used connecting rods: $50 shipped ( Being rebuilt )
•Brand new NPR Piston Set: $100 shipped
•Complete barely used KEP VW automatic to Subaru engine adapter: $350 shipped
•Mercedes Tach/Clock combo: $32
•Brown plaid rear cushion cover ( no foam ) : $125
Total so far: $1,107 _________________ Formerly known in the forums as "OVALTEEN"
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Wed Aug 27, 2014 9:04 am Post subject: EDIT: lift jack |
Where did you get that lift jack?
**EDIT
http://www.snaponequipment.com/ProductInfo/models....l=EELR300A
rated at 6000lbs That is awesome! _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
Keith Samba Member
Posted: Wed Aug 27, 2014 9:22 am Post subject: Re: EDIT: lift jack |
This is my second one, I bought both new. I had the model before this one that was a single piston and it didn't lift as much weight (5,200lbs) and didn't lift as high (only 48"). It also had an open "H" design on the top. I traded that one in towards this one when it came out in 2001. The model number is EELR338A. It's a double piston design and it's rated at 6,500lbs and lifts 52" and has the benefit of a closed design on the top which allows me to use it as a height adjustable work table for fabrication.
When I worked at a Dodge dealership I had them get the first one I had and we used it in a dead bay. I would pick up full sized Ram trucks and Durango's and such.
I forget sometimes that "normal people" don't have these things in their garages, LOL !! _________________ Formerly known in the forums as "OVALTEEN"
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Wed Aug 27, 2014 11:49 am Post subject: |
Good to see this Keith! One more reason to do my 77. But for now buying a house is top priority for me.
JMS sent me a hit list of items to get - look for for now - patiently watching. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Ives676 Samba Member
Joined: June 20, 2013 Posts: 274 Location: Rogers, AR
Posted: Wed Aug 27, 2014 12:27 pm Post subject: |
notchboy wrote: |
JMS sent me a hit list of items to get - look for for now - patiently watching. |
Care to share the list?? _________________ 1974 Riviera - Subaru EJ22
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=630031 |
Manfreds78bay Samba Member
Posted: Thu Aug 28, 2014 10:58 am Post subject: |
Love your garage! _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
Keith Samba Member
Posted: Thu Aug 28, 2014 11:22 am Post subject: |
Manfreds78bay wrote: |
Love your garage! |
Thanks ! There's a more detailed look at my garage half way down in this thread ( page 81 if it doesn't open right up to it ):
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...start=1600 _________________ Formerly known in the forums as "OVALTEEN"
Posted: Thu Aug 28, 2014 12:20 pm Post subject: |
I love it even more, which I didn't think possible. I've come to the conclusion, I'd rather own a garage than a house. One of the perks of being single. _________________ 1978 2.0L FI Campmobile
Nepenthe88 Samba Member
Joined: September 03, 2010 Posts: 1320 Location: Colorado
Posted: Fri Aug 29, 2014 6:48 am Post subject: |
Looks like a good start. The Benz tach won't work without an amplifier (expensive). Save the gauge cluster from the Subaru, tear it apart and stick the subee tach guts in the Benz gauge. It's an easy rainy day project. See my thread for pics on how I did it. I'll be watching! _________________ a Black & Blue Su-BUS-aroo
Follow my adventures in the GoWAND'RLoST bus on Instagram:
https://www.instagram.com/gowandrlost/ |
Keith Samba Member
Posted: Fri Aug 29, 2014 8:01 am Post subject: |
Nepenthe88 wrote: |
Looks like a good start. The Benz tach won't work without an amplifier (expensive). Save the gauge cluster from the Subaru, tear it apart and stick the subee tach guts in the Benz gauge. It's an easy rainy day project. See my thread for pics on how I did it. I'll be watching! |
Thanks!
I actually commented in your thread about your tach mod but you didn't reply to my questions.
From what I've been reading, some Benz tachs work, some don't. I believe the reason was that it depended on if they came out of a diesel or not as they used a different way of getting a signal. It seems the majority of those Benz's were diesel and you may have gotten one of those. I read about some people using a stock Benz signal amplifier as well. Regardless, I have the Subaru cluster to gut if I have to.
Let me know the answer to my questions in your thread please so I know if I should even bother with the Subaru tach guts if the Benz tach doesn't work on its own.
There is a great write-up in this link about the Benz tach. You just have to put this link into google translator to read it if you can't read German:
http://forum.bulli.org/forum/viewtopic.php?f=12&t=16199 _________________ Formerly known in the forums as "OVALTEEN"
Posted: Fri Aug 29, 2014 10:10 am Post subject: |
Keith wrote: |
I actually commented in your thread about your tach mod but you didn't reply to my questions. |
Oh goodness. By the time stamp of your post, it looks like I was writing a new post when you commented and I guess I never saw it. Sorry...
Anyway, here's your post:
Keith wrote: |
Nepenthe88 wrote: |
Aha!
I came up with an idea on how to "fix" the Mercedes Benz Tachometer. Problem was, I need to amplify the ECU signal in order for the Benz Tach to work. Solution.... Crack it open, throw it away, and replace it with something that works better. Here's a pic of the Stock Benz Tachometer after I snatched it out of the gauge:
In its place I decided to try to install the guts of a tachometer from my donor subaru. I completely forgot that I had saved the gauge cluster out of my donor subaru. It was in with all the scrap wire I haven't got around to scrapping yet. Bonus!! (sometimes it pays to be a hoarder... which I'm not)
Now, installing this is the Benz tach housing presented some challenges. First, it had to fit above the guts of the clock. Second, it has to be positioned absolutely perfectly in three dimensions in order to line up the pin that the needle rotates on, in the center of the hole in the gauge. If it were off a little bit then the screw holes that hold the gauge face on, as well as the pin that the clock arms spin on wouldn't fit. And if it were installed too deep, or too shallowly, then the needle might rub. I decided to forego any attempt to screw the thing in knowing that I don't have the technology to get it lined up as accurately as was needed. Instead I made the decision to hot glue the bloody thing in. That way I could hold it right where I needed until the glue set. I then slathered hot melt in all the crevices and linked them together. That way, even if the glue bond breaks, the tach guts shouldn't go anywhere as they're linked like some inseparable puzzle piece. Here's the front:
and the back of the gauge. I slathered the circuit board in a thin layer of hot melt to keep any of the tracings from accidentally grounding out on anything. I'll probably make a cheap-o cover for it as well. The brass outcroppings are clearly labeled, 12v, Ground and signal. I've since cut off the excess to prevent shorting anything out.
And Voila!! Finished product.
This might be the solution to how I do my Mercedes tack/clock combo. Let me know how accurate it is when you get to test it. I am wondering if the Subaru tach will line up with the Mercedes tach line increments correctly.
Also, when you did the Subaru heater fan did you make that a separate Subaru harness or did you have the idea to do it when you made the main Subaru harness?
I saved the HVAC stuff as well with the thought that I may use some of it.
I actually JUST got done ripping the harness and all of those bits out of my donor Subaru 10 minutes ago. |
The tack is accurate at speed, but isn't accurate at idle. It says I'm idling at 1500 when I'm only at 800, but the RPM's match at 3500 with the subee guts in the Benz housing. So, not perfect, but... I can always photoshop a new background with appropriately spaced numbers. Bleh! It was that same Bulli link you posted that got me on the Benz tach kick. I also swapped the speedo over so I could have a trip odometer. I grafted the whole thing into a hacked up stock bus gauge plate. I think it looks pretty sharp, but youall'r free to your opinion. I installed some strip LED's at the bottom that illuminates things real well, and is dimmable off the stock rheostat in the stock light switch (This is obviously not fully installed yet):
Subee fan harness was done WAY after I made the main harness, but... seeing as how I have 2 OTHER harnesses laying around in various stages of completion, I'd say it'll be easier to do first, before you actually do any engine harness work. It'll get a bundle of wires out of the way, and in my setup the stock wiring was ALMOST the perfect length. This fan/resistor/switch combo works great and pushes a TON of air thru the vents (See the beginning of my thread for how I plumbed things) _________________ a Black & Blue Su-BUS-aroo
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Sat Aug 30, 2014 2:10 am Post subject: |
'Adam Westy' might be the greatest name ever. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Keith Samba Member
Posted: Wed Sep 03, 2014 9:08 pm Post subject: |
Hi guys, I thought I'd post a small update.
I have been a little busy with a monthly show I do at the Mauch Chunk Opera House in Jim Thorpe Pennsylvania called 40 Story Radio Tower, so I didn't get as much done on the bus as I would have liked. That and my damn anxiety has been all over the f'ing place because on Aug 4th it was the ten year anniversary of my fathers lost battle with brain cancer.
I have been dealing with anxiety/panic disorder for 4 1/2 years now due to the fact that I never properly dealt with the loss of my parents and grandparents and a few other things that all happened in the very short span of 10 months between 2004-2005.
ANYWAY, on that depressing note........
Todays update:
I got the passenger dogleg repair piece mocked up today! I did this piece as a unit, meaning I cut it off with the outside and inside skin together as they came from the factory. You can see what I mean in the pics I posted earlier in this thread. My phone died before I could take better pics but, here is a pic of it mocked up before I did final trimming to get it to sit correctly together. I hope to have it properly fitted and at least tacked on tomorrow. Sorry about the phone pics.
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Thu Sep 04, 2014 8:07 am Post subject: |
Waiiiiiit you got all the bus AND conversion parts for free? If you need anything to distract you from depressing stuff, keep that in mind
It'll be cool to see this coming together, I love all the suby conversions on here lately, it will definitely be the route I go if/when my motor goes. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Thu Sep 04, 2014 8:31 am Post subject: |
Hey Keith. I would strongly rethink the in bay radiators. Busaru is having issues, I was having issues, mild-core is running hot....
After speaking to jake about my issues, to make that system sound is expensive. Not knowing my situation, he wouldn't really sell me his configuration as it wasn't tested for my application. I really appreciated jakes input to the in bay set up.
If you get easily bummed out, do not go in bay. I just literally spent my 2 week vacation messing with it. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Thu Sep 04, 2014 8:45 am Post subject: |
skills@eurocarsplus wrote: |
Busaru is having issues, I was having issues, mild-core is running hot.. |
Not to say "I told you so", but .. I'm not exactly surprised. In-bay radiators *can* work -- look at Raby and JMSkater with working setups -- but there's a lot of work in making them work.
I tried to work the word "work" into that last sentence more, but couldn't make it work... |
guanella74 Samba Member
Joined: March 13, 2009 Posts: 520 Location: Boulder, CO
Posted: Thu Sep 04, 2014 8:54 am Post subject: |
Skills, on that note, from what you've found what would make the in-engine-bay radiator setup work, even if it is expensive?
Is it the necessity for expensive Porsche radiators and fans, or sealing issues, or what? _________________ - Travis
1974 Westy CampMobile - the OG!
1979 Transporter
1979 Transporter
1977 Transporter
1974 Transporter
1973 Transporter
1971 Westy |
Posted: Thu Sep 04, 2014 9:34 am Post subject: |
Sorry, I won't talk about what jake raby told me. I was willing to purchase his setup, but as he pointed out I may not be optimized for my setup as "off the shelf"
That commands respect if a company won't sell you something. My hats off to jake for sure!
That said, every in bay I have seen/asked about runs insanely hot on the freeway. Trust me, I asked whoever would respond
I wish jsm skater ran a gauge on his first trip. I bet he was on the brink the whole way...he had to be.
From my 2 weeks of trial and error (as in 7am to 1am most nights) I can tell you that I am once bitten, twice shy. I don't know if I would revisit it unless I was paid to, and the customer would have to know it would be an assload of money up in smoke.
Custom radiators with super high efficency would be a must...it would just have to be. I have not spoken to griffin or afco on what this would take, but its more than row/core design _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Sep 04, 2014 9:50 am Post subject: |
I can respect that; I believe in a different thread someone asked about 'why Porsche Radiators?', and Jake responded by saying something to the effect of 'because that's the key'. I forget exactly what it was. Anyhow, Richard Jones (RJES) over in the UK also swears against in-bay setups.
It's been done effectively, so it's possible, but someone with the willingness to find out the key components and share it is the crux now. Apparently the Aluminum honda radiators aren't the way to go, neither are the scirocco... _________________ - Travis
1979 Transporter
1979 Transporter
1977 Transporter
1974 Transporter
1973 Transporter
1971 Westy |
