WaWesty Samba Member
Joined: May 21, 2007 Posts: 181 Location: Shoreline, Wa
Posted: Wed Jun 06, 2007 8:01 pm Post subject: Wipers not working |
... and I live in seattle so thats a problem.
I just got my new westy home today Ill post some pics when i can. I have a 78. My first question now is the wipers. When I push the switch up to turn them on I can hear the motor humming along a constant sound but the wipers dont move, the parts i found in my bently have trouble shooting if the motor doesnt work or works slowly but i couldnt find anything about the motor running just not moving the wipers. Any suggestions ? |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Wed Jun 06, 2007 8:29 pm Post subject: no wipers |
Check the wiper arms first/make sure they are tight,Then check the linkage at the motor assembly.At least you can hear the motor run. _________________ V.W.owner since 1967 |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Wed Jun 06, 2007 9:31 pm Post subject: |
take off the black boots on the arms and see if the shafts are spinning inside the arms. Its the plastic cap at the pivot of the arms. If nut is turning and the wipers not, you just need to tighten it. Or it could be a missing linkage under your dash.
curiuos, I was removing my wipers for the first time today to paint them, and could not find any instructions in my bently. none whatsoever on wipers function, no diagrams, etc. could you tell me waht page it was on? _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
busdaddy Samba Member
Posted: Wed Jun 06, 2007 10:30 pm Post subject: |
Check that the shafts are not siezed into the pivots, mine were turning the whole assemblies in the seals where they come out of the body. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jun 06, 2007 11:29 pm Post subject: |
Thanks guys ill check this out tomorow after work -
The wiper stuff is in the electrical section pg 28 - 37 |
Posted: Sat Jun 09, 2007 6:09 pm Post subject: |
Ok So I can see the wiper motor on the bottom and when i turn the switch on it hums and hums faster on the faster setting, I cant see much and i am afraid to feel around and chop my fingers off.
What i have learned, The wipers first seemed locked down but i pull lightly on them a couple times they go free back and forth a couple of times then lock in the up position, pull back and forth lightly again they go back and forth a few times then lock down, i can do this over and over it doesnt matter if the motor is on or not it does the same thing, and the wipers do move together so they are connected and when they move they move freely. |
Posted: Sat Jun 09, 2007 6:25 pm Post subject: wipers |
..So it sounds like the nut is loose,or fell off at the motor where the linkage is connected. it's a tapered shaft. Do you have a mirror that you can use to look up there and see? the nut head is 10mm. _________________ V.W.owner since 1967 |
Posted: Sat Jun 09, 2007 6:26 pm Post subject: |
its getting dark ill check it tomorow thanks |
TrickyThom Samba Anarchist
Posted: Sat Jun 09, 2007 6:27 pm Post subject: |
Untill you figure it out..... RainEX!
Apply a double coat about once every two weeks or less. I never use my wipers, and my glass is nice and unscrached because of it. _________________ 1977 Riviera |
Posted: Sat Jun 09, 2007 8:58 pm Post subject: |
way ahead of you there is a triple coat on there now |
