Swamp Coolers, Bee Catchers, Thermadors. Help!
Page: Previous  1, 2
ivsamhell
ivsamhell is offline
PostPosted: Wed Aug 01, 2007 3:52 pm    Post subject: Reply with quote
bgs wrote:
I've never seen a "square" one before or one that was
"motorized"..>
http://cgi.ebay.com/ebaymotors/2-RARE-WINTER-BREEZ...dZViewItem
[/img]
theres a square one that i really like not sure who makes it though, there was electric fans available on some models.
never seen that one though.
spooky65
spooky65 is offline
PostPosted: Thu Aug 02, 2007 9:04 pm    Post subject: Reply with quote
I was just wondering if its possible for the guts to be rotted out of these things. I am looking on ebay at them and most people dont know if theres works. Seems like most would be badly rusted internally if they are filled with water unless of couse they are aluminum or stainless. The slinging rusty water comment got me wondering.
bgs
bgs is offline
PostPosted: Fri Aug 03, 2007 9:33 am    Post subject: Reply with quote
The interior of mine is in good shape. It appears that it is made
out of galvanized metal. No rust whatsoever. I used to run
crushed ice with just a bit of water in mine. As mentioned, it
got cold as one could get. I'm glad it has a rod one pulls to
close the forward vent door. It can be positioned full open
partially opened or closed. I removed the old aspen wrapping
that was encased on the squirrel cage and replaced it with a
fibrous material used in home swamp coolers called Dura Cool.
It helped keep the unit cooling longer. I also used two cap fulls
of white vinegar in the unit once a week to kill the mildew that
might build up and stink. The vinegar really worked great.
Hmm, ruff.
ivsamhell
PostPosted: Fri Aug 03, 2007 4:10 pm    Post subject: Reply with quote
i always open them up and replace the ansen mat, though one on ebay now says "buy a can of hammertone paint and a decal and its restored!"
they get pretty nasty i had a rats nest in mine...
gt1953
gt1953 is offline
PostPosted: Sat Aug 04, 2007 6:51 am    Post subject: Reply with quote
When installed and in a low humidity climate they function quite nicely. and having pop outs even helps more as long as you are above 40 MPH.
72 type 1
73 type 1
72 Squareback
({59 Euro bug, 62, 63, 67, 68, 69 type ones 68 & 69 type two, 68 Ghia all sold})
aircap
aircap is offline
PostPosted: Wed Aug 15, 2007 11:41 am    Post subject: Reply with quote
Here in Kansas those things are largely worthless in the summer due to the high humidity. You definitely do feel cooler, but you get out of the car with your clothes damp all over. Bleah.
In dry climates, though, I hear they actually work pretty well.
LouisR
LouisR is offline
PostPosted: Thu May 29, 2008 10:05 am    Post subject: coolers Reply with quote
Okay, I know some of you have serviced your coolers so how are you taking the thermadors apart? Are you prying of the end or both ends. If it is just one end is it the one that faces to the front of the vehicle? I got the rear side off but it is covered with tar with the center rod folded over.
I am really trying to be careful not to bend or dent and have decided to ask for help. Help!! Is there a certain trick?
Thanks
ivsamhell
PostPosted: Thu May 29, 2008 5:48 pm    Post subject: Reply with quote
the rear inner panel is sealed on, also has 3(?) screws. i scraped it out a bit then resorted to heating it until it fell out(actually had the whole thing apart so just set it on fire for a bit). I wasn't worried about the finish though as i powdercoated it after all was said and done. the front panel is spot welded on, you will have to drill out the welds if you wish to remove it.
Page: Previous  1, 2
Page 2 of 2
