Zack1978 Samba Member
Posted: Mon Jun 11, 2007 10:26 am Post subject: What kind of exhaust/muffler are you running? |
Hi everyone,
As an informal poll I would like to know what type of exhaust most people are using on their Karmann Ghia's. I have a bone stock 1600 engine in my 72 Coupe. I think I might have to replace the muffler soon, so is it best to go stock or should I look at another type of exhaust? Any ideas as to what the "best" is?
Thanks,
Zack _________________ 1972 Coupe |
werka Samba Member
Joined: August 25, 2006 Posts: 1110 Location: Huntsville, AL
Posted: Mon Jun 11, 2007 1:22 pm Post subject: |
I currently have a bugpack merged header with dual quiet packs on my 71. Does ok, but fits like crap. The triangular flange is poorly welded, so the dual quiet packs are mounted crooked such that the passenger side is slightly higher than the driver side. You can adjust them some...
Recently purchcased an A-1 but haven't installed it yet. Lots of folks are happy with the A-1 sytem, and from just looking at it, it appears good quality. I haven't installed it yet however. |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Mon Jun 11, 2007 2:16 pm Post subject: |
I have always wondered if a header would work with a trailer hitch on a type 1. I am thinking of the VW type 1 accessory hitch.... |
74Ghia Samba Member
Joined: December 17, 2003 Posts: 2131 Location: Middle of Georgia
Posted: Mon Jun 11, 2007 2:40 pm Post subject: |
I'm using the Euro Sport Exhaust muffler from Mid America. Fits really well and has that nice throaty sound. _________________ Allen C.
2012 Silverado
53 FiberFab MG TD Replica (VW)
Life is hard and its harder if you're stupid. |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Mon Jun 11, 2007 4:30 pm Post subject: |
Werka and 74Ghia
Do both of you have stock engines.If so ,any more pep when stepping on the gas?Ant better gas milege? _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
werka Samba Member
Posted: Mon Jun 11, 2007 7:39 pm Post subject: |
Nope running a 1776 in my ghia. For a stock ghia upgrading the exhaust to a merged header (much less restrictive than a stock exhaust) and carbs (dual kadrons) would give you a noticeable increase in performance. |
Gromit Samba Member
Posted: Mon Jun 11, 2007 9:32 pm Post subject: |
No idea, but I put stock back on mine. I found out cheap parts don't fit and arn't worth the trouble. |
dog_jr911 Swamp Donkey Assistant
Posted: Mon Jun 11, 2007 9:45 pm Post subject: |
cermaic coated merged turbo tuck or hideaway system. also have the "phat boy." nice to switch them with three bolts every few weeks. _________________ AKA Chris™
ROCKIN a ESP LTD F2E |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Tue Jun 12, 2007 8:32 am Post subject: |
GeneBerg Ghia 1 3/8" header and single quiet muffler. This header has the bottom pipes pulled upwards compared to a generic "1600 engine" header. The telltale of this design is that the triangular attachement flange for the muffler has its bottom edge paralle to the ground. The matching muffler is bent so that when viewed from directly above, it follows the contour of the rear body apron. When mounting the muffler, there is enough play in the fastening holes in the flange that you can tilt it upwards (rotate the tip CCW) to maximize ground clearance and keep it level. I painted the muffler flat black. Very nice sound, not loud at all. My engine is a mild 1776cc with stock-valve heads and dual carbs. |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Tue Jun 12, 2007 8:40 am Post subject: |
I too am running the Gene Berg 1-3/8" Karmann Ghia header and single quiet pack on my Ghia.
GB908 - Collector moved up and special single quiet muffler tucked up under back bumper for best appearance.
_________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
sslick Samba Member
Posted: Fri Jun 01, 2012 9:59 am Post subject: |
werka wrote: |
I know it's been a while since you posted this, but I have a question. I'm running a Bugpack 1 1/2" merged header and am having trouble finding muffler(s) that will fit the Ghia. I like the idea of a dual setup for a balanced look, but don't want it to fit like crap either. What's your opinion on the looks of the dual QP's on the Ghia? Any fender interference? |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Fri Jun 01, 2012 10:17 am Post subject: |
I was running dual QPs on my ghia w/ a 1 5/8" merged exhaust before I switched to the Dansk high-flow flanged heater boxes and Bugpack 1 5/8" Streetmax system with Mondo muffler (the only muffler that fits with the Streetmax system).
Old duals QPs and 1 5/8" merged exhaust:
Bugpack Streetmax system w/ Mondo muffler:
I liked the more balanced look of the dual QPs better, but I can't find a set that fits with the Streetmax exhaust. _________________ 1966 Karmann-Ghia convertible |
O2COOLED Samba Member
Posted: Fri Jun 01, 2012 12:34 pm Post subject: |
I liked the look and sound of the EMPI 4 tip I had before I got a new rebuilt 1600 which came with a 2 tip. Just got an ANSA 4 tip which I still have to install. I like the looks of the 4 tip with the muffler hidden under the rear clip and just the 4 tips sticking out. I'll update after I put it in. _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
"At my age time is too short to respond to people with short minds"
Current: '69 Ghia Coupe
VW History:'63 Bug;'70 Bug;'73 412;'83 Rabbit;'86 Golf;'76 Fat Chick; 67 Ghia Coupe; '70 Bug |
Volfandt Samba Member
Joined: March 15, 2012 Posts: 500 Location: Knox County, East TN
Posted: Sat Jun 02, 2012 6:43 am Post subject: Stock exhaust |
Good thead.
I'm currently running stock heat exchangers, stock muffler and straight through slash cut exhaust tips and I've got to say those tips make it pretty loud. Performance seems good on my stock 1600DP but I'm an air cooled VW newbie so what do I know
I'd like a little more melowness w/a lower rumble at low speeds
Banzai KG, whats the purpose of that square-stock bracket bolted up to the rear of your engine w/the all-thread? additional support?
Dave |
sslick Samba Member
Posted: Sat Jun 02, 2012 7:37 am Post subject: |
sactojesse wrote: |
I liked the more balanced look of the dual QPs better, but I can't find a set that fits with the Streetmax exhaust. :( |
When you ran the dual QP's, your header and mufflers were both Bugpack? No interference with the bottom rear of the fenders? I have Bugpack 2008-23 (their 1 1/2" ceramic merged header) and Bugpack's Mondo muffler (my builder told me would fit) that hits the bottom of the pass. fender. I want to be sure that when I order a muffler/mufflers that it/they will bolt up, look good and sound good as well. |
Posted: Sat Jun 02, 2012 8:12 am Post subject: |
sslick wrote: |
The dual QP merged system is pretty old and I don't recall the manufacturer, but I believe they are both from the same manufacturer and they fit with no issues. Sorry for the lack of info. _________________ 1966 Karmann-Ghia convertible |
mlhsquared Samba Member
Joined: October 13, 2008 Posts: 1482 Location: Strasburg, VA
Posted: Sat Jun 02, 2012 9:40 am Post subject: Re: Stock exhaust |
Volfandt wrote: |
Dave |
That would be a traction bar. Here's one of several out there for sale: http://lowbugget.com/thebar.html _________________ Mike
'67 Ghia Coupe |
Deluxe Lowlight Ghia Samba Member
Posted: Sat Jun 02, 2012 10:16 am Post subject: |
I custom made a flowmaster for my lowlight when it was still driveable
_________________ These vws are cool but the people who own them are far more valuable. Keep friends close they can be taken away overnight.
57 ghia
59 patina ghia
61 patina Ghia
71 bus
73 super beetle
74 thing
75 half bug |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Sat Jun 02, 2012 11:43 am Post subject: |
Ran a stock type muffler with different internal baffles and taper tips for more flow. Switched to a Bugpack 4-1 header and single quiet pack. Put the first muffler back on to see if I could retune to get the same performance, but could not. The header and quietpack were just repainted yesterday with 2000 degree paint, and will be going back on real soon. The fit is good, but I did have to grind an internal weld a bit to get them to slip onto the heater box pipe without using a hammer.
I like the stock look, but I like the performance and sound of the header. Interestingly, the single quietpack is quieter at idle and low speed cruising, louder on the freeway, and WAY louder at wide open throttle.
Not a lot of difference in MPG, as both return mileage in the mid 30's. Since the header lets it get up to redline in top gear quicker, I'll stick with that. Only downside is the loss of stock looks, and putting up with Cadillacs.
Paul
nikita Samba Member
Joined: September 16, 2007 Posts: 531 Location: California
Posted: Mon Jun 04, 2012 1:49 pm Post subject: |
O2COOLED wrote: |
I liked the look and sound of the EMPI 4 tip I had before I got a new rebuilt 1600 which came with a 2 tip. Just got an ANSA 4 tip which I still have to install. I like the looks of the 4 tip with the muffler hidden under the rear clip and just the 4 tips sticking out. I'll update after I put it in. |
I have the 4-tip ANSA style, dont know the actual brand. Love the look, hate the sound. Will probably go back to stock, but with taper tips. |
