Birdmanhere Samba Member
Joined: June 03, 2006 Posts: 1054 Location: CANADA EH
Posted: Mon Jun 11, 2007 8:06 pm Post subject: eberspacher duct hole pics |
I am looking for pics of the hole you need to cut through the firewall beside the gas tank to install the eberspacher duct work.
anyone? _________________ 66 Bus
71 Bug |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Jun 12, 2007 10:12 am Post subject: |
My bus is cut.
If you need measurements, they are online.
A BN4 duct is cut from the "floor" where the gastank sits, a hair wider than the width of the duct, about a quarter inch from the edge of the wheelwell and its height is in the online installation manual which is on the Vintagebus website. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Jun 12, 2007 10:29 am Post subject: |
The hole size depends on the year heater you're putting in. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Tue Jun 12, 2007 10:46 am Post subject: |
crofty wrote: |
The hole size depends on the year heater you're putting in. |
True.
So, what year heater is being installed? |
Posted: Tue Jun 12, 2007 10:49 am Post subject: |
If anyone needs them I can take pics of the deffierences between Barndoor, 58-61, 62-67 and 68-to 71. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Tue Jun 12, 2007 11:53 am Post subject: |
it is a later model
part number looks to be 211 261 103 off the bottom of the tag _________________ 66 Bus
71 Bug |
Posted: Tue Jun 12, 2007 1:34 pm Post subject: |
If it is a 12 volt BN4 going in a 66 bus then the information I gave earlier should be sufficient. |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1154 Location: San Tan Valley, Arizona
Posted: Tue Jun 12, 2007 1:55 pm Post subject: |
Here's a pic
Posted: Tue Jun 12, 2007 2:44 pm Post subject: |
Kommercial wrote: |
Here's a pic
I may be on crack but that pic appears to show the control cable emerging down low and to the right of the duct? If so, it will not work on a later BN4 which needs its bowden cable to emerge high and to the upper left of the duct. |
Posted: Tue Jun 12, 2007 2:52 pm Post subject: |
Yes that is a 6v BN4 setup, good point. |
Posted: Tue Jun 12, 2007 4:34 pm Post subject: |
Major Woody wrote: |
Kommercial wrote: |
Here's a pic
All the literature I have has it entereing low, do you have a something that says otherwise?
The 6 Volt and 12volt models are set up identically as far as switches and connections are concerned. There is a holder for the cable mounted at the regulating switch on all models, even bay windoww heaters.
Those pics sshow, as far as I can tell from the mounting holes a later style heater ( Non-mesh fan cover) _________________ Your Vanagon sucks, Stop waving at me.
