VWLarry Samba Member
Joined: May 12, 2005 Posts: 104 Location: Bismarck, ND
Posted: Tue Jun 12, 2007 3:49 pm Post subject: Shifter for VW Trike |
I'm in the process of building a VW trike, using a '72 Super Beetle as my donar vehicle. My question is, I have to offset my shift rod a little, well offset or bend, I know that the old buses had a fixed shift rod, but on bugs the shifter can rotate in the rod, is there anything wrong with making the shift handle to rod connection solid, so it can't rotate. Thus allowing me to put a 90 degree bend in the shift handle so it will stick out under the seat and still be able to shift. This won't work if the shifter has to be able to rotate. Hope this makes sense and would appreciate any comments. |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Tue Jun 12, 2007 7:57 pm Post subject: |
That's what a lot of guys do anyway, Larry. Most mount their shifters on the side of the body if the body covers the seat up to the tree. For more options and opinions, you might want to check out http://btw-trikers.org/uploads/forum.php
which is strictly dedicated to VW trike builders. Personally, I'm building (with help) a mid-engine trike, so my linkage is just a little different!
Rick |
redawg Samba Member
Posted: Fri Jun 22, 2007 12:11 pm Post subject: shifter for vw tike |
you can use a type 3 shifter and rod. it has a pin in the front to keep it from rotating email me at [email protected] and i can send you some pics of a type 3 shifter i have |
Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2029 Location: Alexandria, VA
Posted: Mon Jul 02, 2007 11:13 am Post subject: |
Be sure to use a skull or 8 ball for the shift knob, anything else is bad luck.
Trike on, Nick |
