Paulbeard Samba Member
Posted: Mon Dec 11, 2017 7:41 am Post subject: Re: Vanagon/Westy Hot Foot! |
kaalualu wrote: |
OMG, no wonder TK became so cynical. 9 pages for this mod seems excessive. So simple. |
Most of those threads dragged out as a result of his contentiousness, tbh… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Mon Dec 11, 2017 8:23 am Post subject: Re: Vanagon/Westy Hot Foot! |
a thread that spawns 'useless Chinese dreck' has earned its eternal existence... _________________ .ssS! |
RicoS Samba Member
Posted: Thu Dec 14, 2017 7:57 am Post subject: Re: Vanagon/Westy Hot Foot! |
Paulbeard wrote: |
Most of those threads dragged out as a result of his contentiousness, tbh… |
THAT has no veracity. Set aside you prejudice long enough to have a peek into TheSamba archives.
Richie (near The Burgh) |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Thu Dec 14, 2017 8:13 am Post subject: Re: Vanagon/Westy Hot Foot! |
perhaps time to lock this thread if it's going down this route...
He done, He's gone - get over him and move forward. _________________ This free advice is worth exactly what you paid for it.
Posted: Thu Dec 14, 2017 8:18 am Post subject: Re: Vanagon/Westy Hot Foot! |
BTW, I stopped at Pep Boys last night and happened to see the High temp insulation in their street rod exhaust selection.
Another area which could benefit from insulation is between the front on the floor. The heater and Radiator hoses are routed under there and they contribute to the interior temps on a long drive. _________________ This free advice is worth exactly what you paid for it.
Sodo Samba Member
Joined: July 06, 2007 Posts: 9606 Location: Western WA
Posted: Sun Aug 12, 2018 1:11 pm Post subject: |
llilibel03 wrote: |
Is it possible to do this mod in a way that makes it possible to shut off the flow without removing the trim panel? If so, pics? |
This pic is just the glovebox removed. I haven't tested it yet. Didn't have to cut any hoses.
Harbor freight long nose 6" vise grip $6.99 can be used for other tasks in the wintertime.
https://www.harborfreight.com/6-in-long-nose-locking-pliers-63870.html
There are other types too 22850 Hose Pincher by Lisle. http://a.co/8ITln0l
But the vise grip is a more useful tool (otherwise) and easier for this task. _________________
....KTMs, GasGas, SPOT mtb |
danmccann993 Samba Member
Posted: Wed Sep 12, 2018 8:25 am Post subject: Re: Vanagon/Westy Hot Foot! |
I had a similar problem in a 1990 syncro Westy I just bought. This is a very old post, but I sometimes read these old ones to learn how to fix a common issue. Before you go pulling everything apart, or crawling under the van, take off the cover of the heat control levers on the dash. This is a simple process that is well described in a gowesty Youtube video for replacing the bulbs with LEDS. Then check that the cable attached to the heat control (2nd lever from the top) comes to a stop when moved to the left. If the lever (without the rubber extension) moves past the opening in the dash, your problem is that the cable is adjusted incorrectly and that is why you cannot close the valve that controls hot water flow to the heat exchanger. Loosen the 7 mm bolt that captures the cable (you need small hands to do this and might have to also remove the blower control for the rear compartment fan), use needle nose pliers to pull the outer rubber covering of the cable to the right an inch or so, and re-tighten the cable retaining bolt. That's it. Now when you push the lever to the left, the valve operates correctly and closes completely. If this does not fix the problem, the solutions described below should help you eventually get this fixed. Good luck.
Dan |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1841 Location: Vancouver Island, BC
Posted: Sat Dec 18, 2021 6:37 pm Post subject: Re: Vanagon/Westy Hot Foot! |
Thanks for the idea and inspiration. Here is my take of the heat shield, builtusing Reflectix. Note that I already had the stock insulation on the driver's foot area. It was in good shape, all I did was reglue it in place.
I applied reflective tape on all seams for durability:
Magnetic clamping !
_________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
