Vanagon/Westy Hot Foot!
jwallis
jwallis is offline
PostPosted: Fri May 25, 2012 11:17 am    Post subject: Reply with quote
Terry Kay wrote:
Good.
Keep close an eye on the hose as you crank down on them made In Cassablaca vice grips.
This isn't the right tool for the job---
But any port in a storm I guess.
Or--any Tool when your Tapioca.
In the past I have put pieces of wood between the teeth and the hose, I guess I should have mentioned that. Is that your concern, that the teeth would chew up the hose? If it's an old hose, I'm not crazy about crushing down on it regardless because I'm paranoid about stressing the hose... I know I should probably replace them soon...
TheVanTracker.com - Kill Switch + GPS Tracker + Door-open alerts, made specifically for the Vanagon!
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more...
greyerlynx
greyerlynx is offline
PostPosted: Mon Jul 23, 2012 9:15 am    Post subject: Gas Pedal linkage heat Reply with quote
Hey all. I'm new to TheSamba having just purchased my '86 Wolfsburg Weekender. I grew up in VW campers though. Smile
I've read through this thread and I understand the two major problems that people are fixing: Heater leakage and radient footwell heat. The fixes for both make sense but I'm pretty sure neither are the issue I'm facing.
Early on in the thread, DogPilot mentions hot air coming in through the gas pedal linkage. I've confirmed that this is exactly what's happening in my van. I've reached down and put my hand under the gas pedal while driving and I can feel a significant amount of hot air blowing up through that hole. Before I just start attacking it with my own (sometimes successful) ingenuity I wanted to reach out and see if anyone had a solution that specifically dealt with that problem.
Thanks!
MidwestDrifter
MidwestDrifter is offline
PostPosted: Mon Jul 23, 2012 6:08 pm    Post subject: Reply with quote
There should be a plastic cover that goes over the pedal linkage under the van.(see picture below) This forms a seal around the hole where the rod from the pedal goes through the floor. If yours is missing or damaged a decent amount of hot air can get in.
If it is in place but you still get hot air leaks, you can try sealing around the cover with a silicone or similar sealant.
2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215
greyerlynx
PostPosted: Sat Jul 28, 2012 8:49 pm    Post subject: Reply with quote
Wanted to make sure I followed up here. I tracked down the plastic cover you were talking about up in the spare tire area. I don't have it apart yet but it looks like the stuff they used to seal the edge has disintegrated after 26 years and the hot air is getting in through the gap. I'll need to get up in there and use some silicone like you said. I'm guessing the gasket for that is not readily available.
Thanks for pointing me in the right direction.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sun Jul 29, 2012 4:11 pm    Post subject: Reply with quote
Polyurethane caulk will stick better and handle the hot environment better. Silicone is for bathtubs! Wink
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
MidwestDrifter
PostPosted: Sun Jul 29, 2012 5:32 pm    Post subject: Reply with quote
True, I just re-sealed mine after replacing the throttle cable. I used some sikaflex (polyurethane adhesive sealant) I had lying around from another project. That stuff will probably out-last the van.
A good quality automotive silicone would work just fine. Might be easier to remove as well, if you need to get under there to add some lube.
2000 Jetta TDI
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Jul 29, 2012 9:20 pm    Post subject: Reply with quote
GOOP would seal that cover off from the heat & elements forever--
Good stuff.
T.K.
jwallis
jwallis is offline
PostPosted: Tue Jul 31, 2012 2:21 pm    Post subject: Reply with quote
Good stuff.
Are you talking the GOOP contact cement in the blue tube? I've never had good luck with that stuff. You use it for a wide range of jobs? Follow the instructions on the tube?
Terry Kay
Banned
PostPosted: Tue Jul 31, 2012 7:39 pm    Post subject: Reply with quote
It comes in 37 different varieties--
Plumbing,Home,Garden,Shoe, etc.
I've got the purple & white tubes .
Clean the area well with lacquer thinner, scuff up the area with 80 sandpaper, and apply the goop.
Let it dry overnight, and you'll need a jack hammer or an act of God to have it fall off.
A liitle bit of prep, & patience goes a long way.
What's wrong with using the required screws & the Goop to hang & seal the cover ?
T.K.
greyerlynx
PostPosted: Wed Aug 01, 2012 12:29 pm    Post subject: Reply with quote
I'd like to leave the option to get into it at some future point. I'll probably go with the polyurethane or auto silicone. Thanks guys!
gmoyle
gmoyle is offline
PostPosted: Sun Jun 16, 2013 4:35 pm    Post subject: Plumbers tape? Reply with quote
Hate to revive such an old thread but I was about to this mod but I had a question. It looks like you used some plumbers tape here. I was wondering if any old plumbers tape will work or if a specific kind is required to be resistant to antifreeze?
[/quote]
Stella - 1988 Westfalia Vanagon GL Camper
Powered by Subaru SVX
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
J Charlton Premium Member
J Charlton is offline
PostPosted: Sun Jun 16, 2013 6:09 pm    Post subject: hot foot solution Reply with quote
Anyone interested in a solenoid controlled valve to do this shut off? It would be controlled by a toggle switch on the dash that would trigger a relay that would make the solenoid valve move from the "off" position - i.e. closed, no coolant flow through the heater core to the "open" position. I.E. the default position would be closed, throw the switch to open the valve and have flow.
NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024
DubNuts
DubNuts is offline
PostPosted: Sun Jun 16, 2013 7:20 pm    Post subject: Reply with quote
Haha small world.. Recently I've been installing the solenoid shut off vales.
I'm using the Hi temp 1\2" Valves think there called Viton rated to 248 degrees. I install them in the rear of the Van before the heater hose T's off into the Rear heater.. Note.. The valves are somewhat heavy so I create a hanger to support the weight so that they won't bounce, flop or drop. Works great even wire them to a powered LED amber switch that I install on the lower Dash. Works great for those spring or Fall days where it's chilly in the morning and then hot.
Only problem is getting above the coolant pipes to install and wire the valves, but normally I offer the valves when upgrading total coolant system and pipes, and total heater hose replacement stuff.
But this fix won't solve your Rad heat blow back, for that your need the foil insolation etc. For that stuff I buy from Summit Racing etc "Heat Foil" it's sticky on one side and used to keep the heat from race engines, Turbo's etc out of the car. They have several different types some rated to 1000+ degrees.
gmoyle
gmoyle is offline
PostPosted: Sun Jun 16, 2013 7:46 pm    Post subject: Plumbers tape? Reply with quote
Yup. Putting in butyl sound deadener and ULtratouch radiant barrier but I still would like a recommendation on the plumbers tape. The last thing I want after tearing out everything, cleaning and installing all the insulation and putting in new carpet is a coolant leak.
Suggestions?
joseph928
joseph928 is offline
PostPosted: Sun Jun 16, 2013 8:16 pm    Post subject: ptfe tape Reply with quote
Blue Bay Bus White used on threads up to 3/8 of inch, yellow used on threads 1/2 to 2 inch . WE use yellow at work on low presser steam lines and that seems hotter the the VW gets. Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
PostPosted: Sun Jun 16, 2013 8:34 pm    Post subject: Reply with quote
Small world indeed - I've been looking at mine - I currently have a manual shut off - the valves I have are (I think) sized so that I could install just about right where I now have my manual shutoff. I.E right up pretty much next to the heater core. For sure, I'd always replace the original POS plastic valve with the wire cable attached to it with a piece of hose that would splice into the original heater line, eliminating the manually controlled valve altogether.
I'd love to come up with a reasonably priced variable opening valve so you could vary the coolant flow, but any I've seen are ridiculously expensive.
syncrodoka
syncrodoka is offline
PostPosted: Sun Jun 16, 2013 8:56 pm    Post subject: Re: ptfe tape Reply with quote
The yellow teflon tape gets used on gas lines around here. Think
joseph928
PostPosted: Sun Jun 16, 2013 9:01 pm    Post subject: Re: ptfe tape Reply with quote
Blue Bay Bus The yellow we use is better on larger pipes it's called duel density the white is single density. Been using on steam lines for years, with no problems. But if this is a problem use pipe dope. Very Happy PS look it up rated for up to 500 degrees! + also water! Shocked
malibu
malibu is offline
PostPosted: Sun Jun 16, 2013 9:25 pm    Post subject: Re: Plumbers tape? Reply with quote
The place I ordered the valve from had it put together for me when I got there. They knew it was going to hold antifreeze so I wasn't worried. I think it's just regular white tape. So far it has been working great.
85 westy weekender - 2.5 suby
85 full westy - 2.2 suby - Sold
gmoyle
gmoyle is offline
PostPosted: Mon Jun 17, 2013 12:03 am    Post subject: Reply with quote
Fabulous. I should be able to finish it up this week then. Thanks all!
Page 5 of 10
