John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
Posted: Sun Jun 17, 2007 6:46 pm Post subject: Trick to installing Ball Joint Boots |
My ball joint boots keep popping off once I get both torsion arms in the spindle. I probably messed with the passenger side for 2hrs; reattaching boots and spiral clips; then putting spindle on.
Any helpful hints? This is getting a bit ridiculous. The BJ's are all new and I had the boots removed when the joints were pressed in. _________________
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sun Jun 17, 2007 7:46 pm Post subject: |
When you tighten the ball joints to the spindles, the boots compress quite a bit. I don't understand how they could be popping off. A photo would sure help... |
wcfvw69 Samba Purist
Posted: Sun Jun 17, 2007 7:47 pm Post subject: |
John, a pipe that fits over the boot but will still grab the sides of the ball joint boot works well to seat them all the way down. Even a large socket will work. Sometimes you can get lucky with some channel plyers to pull it down one side at a time. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Jun 17, 2007 8:02 pm Post subject: |
Woreign wrote: |
The torsion arms have to be twisted into position so the spindle fits. The ball joints get pulled to one side and the boot slips off the corner. _________________
Previous:
Posted: Sun Jun 17, 2007 8:59 pm Post subject: |
I might be thinking of a different type of boot. They have a tension ring that has to be pushed down. It sounds like yours have the ring that raps around it once or twice. Either way, they boot should be seated all the way down the the ring should hold it down. _________________ Contact me at [email protected]
