erdonline Samba Member
Posted: Mon Apr 01, 2013 11:04 am Post subject: |
Jake de Villiers wrote: |
danfromsyr wrote: |
a 16mm is equal to a 5/8"
vw often uses that size on the I4 waterpump/AC bracket (iirc)
not sure atm, where on a vanagon
syncrodoka wrote: |
16mm socket? I am not sure that I even own that size, I have been in every system except to tear into the tranny. |
5/8" = 17mm. I got two 16mm sockets with my Craftsman 'Master' set 25 years ago and have never used them! |
5/8 is closest to 16mm. 5/8 is 0.625 inches, and 16 mm is 0.63 inches. 17 mm is 0.67 inches.
Ed _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
randywebb Samba Member
Posted: Mon Apr 01, 2013 12:38 pm Post subject: |
randywebb wrote: |
Anyone know if 21 mm is used anywhere? |
Front suspension uses 21mm or 7/8" |
Thanks - I will add add my 21/24 mm Snap-Off wrench to my Vanagon Tool kit... _________________ 1986 2.1L Westy 2wd Auto Trans. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Apr 01, 2013 1:15 pm Post subject: |
erdonline wrote: |
danfromsyr wrote: |
syncrodoka wrote: |
Ed |
So all this time I could have been using a 16mm wrench on my 5/8" fasteners instead of a 5/8" wrench? Awesome. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Mon Apr 01, 2013 2:02 pm Post subject: |
danfromsyr wrote: |
syncrodoka wrote: |
Engine conversions are always a wild card that the owner has to allow for.
Since the I4 didn't come in the vanagon where was it used??
I am curious to know. |
VWagabond Samba Member
Joined: March 19, 2011 Posts: 272 Location: Charlotte, NC
Posted: Mon Apr 01, 2013 8:22 pm Post subject: |
Hatterasker wrote: |
"You got triple A?"
"No."
"You're a brave man to drive a Westfalia without triple A." |
I hear Vanagon owners make up a large portion of their customers and that they are going to start charging a surcharge because they have to tow so many. Mine has been in a compromising position behind a tow truck more times than I care to remember. They know us so well, they send birthday greetings to me and the 'Krautcan'. _________________ The Road Goes Ever On & On……...
VWagabond
87 Camper GL
87 Syncro GL |
Terry Kay Banned
Posted: Tue Apr 02, 2013 8:05 am Post subject: |
_________________ T.K. |
scruffyboy Samba Member
Joined: December 21, 2004 Posts: 170 Location: San Francisco, Ca
Posted: Tue Apr 16, 2013 7:39 pm Post subject: O.K. I'll bite |
I'm not really a fan of "cheap" tools, they're most likely to fail when you most need them I've found the "Crescent" tool set available at Costco stores to be invaluable. Wide variety of tools (metric & SAE) in a blow-mold case. Stores in the closet pretty well. At around $100 it's a really good value and the tools are decent quality. FAR better than anything I've found at Wallywhirlled or other big box stores. Oddly, the only addition I had to make was a 13/16 spark plug socket. Kit didn't come with one for some odd reason.
I also carry a tow strap, small hydraulic bottle jack, "cribbing" blocks, small digital multimeter, headlight so I can have hands-free light where I want it, jumpbox/compressor combo and a tire repair kit.
I tend to go a lot of places off the beaten path so being able to deflate/inflate & repair a tire is a necessity. Having a few spare parts on hand rounds out the load.
I've decided to go "primitive" with my 1982 Westfalia, it now sports dual carbs and a mechanical fuel pump instead of the FI. The "electronic" ignition presently installed can be easily swapped out for a set of points should it decide to up and croak.
Nothing against the FI system or electronics, but the places I tend go? Simple is better |
Posted: Mon Apr 22, 2013 2:10 pm Post subject: |
GoWesty lists a tool kit called "TOOLKIT-AUTO" that includes some small Allen hexes -- "3mm, 4mm, 5mm & 6mm hex key set."
Where are 3 and 4 mm Allen fasteners used in the Van? _________________ 1986 2.1L Westy 2wd Auto Trans. |
Colorado Yeti Samba Member
Joined: August 25, 2013 Posts: 356 Location: Ft. Collins, Colorado
Posted: Tue Jul 08, 2014 11:01 am Post subject: |
A pair of panty hose. So you can rob the nearest 7-11 to pay for all of the repairs that your van is going to require during your brief roadtrip. |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Fri Oct 03, 2014 8:32 pm Post subject: |
I have a couple different length/size stainless surgical clamps, I use them for all sorts of things, from retrieving small parts to holding nuts or bolts during assembly that I can't get my fat fingers in to. Not to mention clamping off fuel lines when changing a fuel pump. In the olden days I might have used them to keep from burning my fingertips. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
outdoornate65 Samba Member
Joined: September 29, 2012 Posts: 161 Location: SE burbs of Denver, Colorado
Posted: Fri Oct 03, 2014 9:48 pm Post subject: |
Colorado Yeti wrote: |
Good luck trying to out-run to police in a Westy.....
Better suited for a protracted hostage situation. _________________ 1984 Westfalia Wolfsburg "Nana" |
Merian Samba Member
Posted: Sat Oct 04, 2014 1:01 pm Post subject: |
by stainless surgical clamps, you mean hemostats?
if so, I agree, small, large, bent & straight
if not, then can you post a pic? |
Posted: Sat Oct 04, 2014 1:07 pm Post subject: |
Yes hemostats, usually pick them up at the flea market for a buck or two. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
boroko Samba Member
Joined: September 11, 2012 Posts: 326 Location: S.W. Michigan
Posted: Sat Oct 04, 2014 8:53 pm Post subject: |
OK, while I totally can appreciate the lists of tools and spares, there is one thing not listed that has saved my bacon more than once. A cheap tire plug kit. $5 dollars from HF. I also picked up their cheap compressor for $8. Those items are now standard in all my kids cars.
Bo _________________ '87 SyncroWesty: Smokey the Turtle, '85 SubiWesty: Chappie, '84 GTI, '86 GTI in full Rally trim,
previous: 2 Syncro tin tops, 2 Vanagons, 3 busses, 3 Ghias, 2 Jettas, a 411, a gas and a diesel Bunny and about 25 Beetles, one that only drove left. |
morymob Samba Member
Posted: Sun Oct 05, 2014 5:02 am Post subject: |
Except 4 bleeder & axle nut I carry sae 6point set, covers metric also. |
tjet Samba Member
Posted: Fri Oct 23, 2015 12:57 pm Post subject: |
Here's a few specific things I like to carry (along with you generic wrench, socket, & screwdriver sets) - in order of usage:
1. Cardboard - like a mirror or large picture shipping box before it's folded. It fits perfectly over the engine compartment when folded in half. I use this everytime I'm under the van
2. Empty coolant bottle. It makes a great pillow when you are under your van (& it's adjustable when you let some air out). You can also carry liquids, and you can fabricate a makeshift oil drainer out of it by cutting a large hole in the side.
3. Aircraft lockwire. You want the stainless steel stuff. Way stronger than zip ties, especially when you double it up by twisting it together. A good size is .041 & you can get it here, along with pliers (not required tho)
http://www.mcmaster.com/#8860k64/=zhubsw
http://www.mcmaster.com/#lockwire-pliers/=zhucla
4. a 10mm & a 13mm combo wrench. I use these 2 sizes all the time. If you have a complete Harbor Freight wrench set, do yourself a favor & buy a pair of Snap-On's in this size.
5. Needle nose pliers. Super handy.
6. Magnet. This one below can be bent in any position.
https://www.matcotools.com/catalog/product/MP14X/HEAVY-DUTY-FLEXIBLE-MAGNET/
7. Hammers (2). You want to carry 2 hammers:
This one I use a lot. I use the plastic part to strike against a combo wrench when I loosen something.
http://www.mactools.com/en-us/Striking-and-Struck/...ad-Hammers
This one below is when you need some real power - very handy. Think mini sledge
http://www.craftsman.com/craftsman-3-lb-hand-drill...ockType=G9
8. Flashlight. I own this mil-spec one below. It's not the brightest light, but you can leave it on for a week (I did this by accident). USA made, too You don't need the aluminum one. The military one is plastic. The run time they show is way under-rated.
https://www.tek-tite.com/proddetail.php?prod=EXPEDITION_STAR |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Fri Jan 29, 2016 10:37 pm Post subject: Re: Essential Tool List |
I now consider these Ryobi One+ 18V tools to be "Essential":
They all use the same rechargeable 18V LI batteries. I bought the largest capacity batteries they offer for extended run times (photo below). Recharging batteries is easily accomplished if you have access to shore power, a small generator, or an inverter/solar system. All of these tools are powerful and quite compact. They are sold separately or in kits (usually including a charger and 1-2 batteries). Home Depot has the exclusive on Ryobi Tools and I found their prices to be lower than Amazon. Overall these Ryobi One+ tools are very affordable, versatile, and include a 3yr warranty.
I'm not a Ryobi salesman... I only play one on the internet. All kidding aside, I have really found these to be essential (for me and what I do... SUPing, changing tires, and sleeping comfortably in the summer)... YMMV.
There are many more compatible tools (including lanterns, radios, etc.) on their website https://www.ryobitools.com but the ones below are the ones I own and have experience with.
This high pressure inflator tops off tires up to 150 PSI ($25):
This high pressure / high volume inflator also fills tires no problem, but it's much faster than the one above for inflatables such as iSUPs, kayaks, rafts, etc ($40):
This 1/2" impact wrench makes effortless and fast work of tire changes. Do you really want to hand crank all your lug nuts in 38F rain on the side of a busy highway? ($120):
This "hybrid" fan moves a lot of air and runs for 10+ hours on low with a battery or endlessly with 120v plug (see second photo). 1 for the top bunk and 1 for the lower bunk ($40/ea):
High capacity batteries (optional, but recommended for the fan in particular) with LED indicators ($90 for 2):
Single battery charger ($40):
_________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
OhBetty Samba Member
Joined: August 23, 2014 Posts: 80 Location: Salt Lake City
Posted: Mon Feb 29, 2016 4:57 pm Post subject: Re: Essential Tool List |
Ok, so I ran into this problem last time I had to change my wheel bearings out on the road... Is anyone willing to suggest other, less frequently used (>14mm) socket/wrench sizes to carry at all times?
I've heard 17, 19, 21, and 24mm referenced. Any other highly-regarded sizes for the essential road kit?
Thanks in advance. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32576 Location: Reading Pennsylvania
Merian Samba Member
Posted: Mon Feb 29, 2016 5:15 pm Post subject: Re: Essential Tool List |
OhBetty wrote: |
big one for the wheel hub nut and a long steel handle to stand on - can double as a stove leg or something...
if you look in the other tool threads you'll find a list posted from a Snap-Off Vanagon mechanics set or some such - from that you can see if a 15 mm is there (I'd bet yes)
and others needed to get you home or to a garage while traveling
meanwhile we can await djkeev's list of what's in that bag... |
