Bleyseng Samba Member
Posted: Wed Jun 20, 2007 8:34 pm Post subject: Started redoing the interior paneling |
found some okume 3mm paneling and had some stained made to try to get it close in color.
first piece is done...not too bad. I'll spray it with a stain clear finish.
_________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
ChiTwnVW Samba Member
Joined: November 18, 2004 Posts: 1174 Location: Home. Sweat home.
Posted: Wed Jun 20, 2007 9:00 pm Post subject: |
How are you cutting it?
I had a dickens of a time with the thin plywood, splintering, chipping... I pretty much had to sculpt it into shape with sandpaper... |
Posted: Wed Jun 20, 2007 9:24 pm Post subject: |
I clamped the old piece onto the new paneling. Then using a router with a guide ring and straight bit the same as the outside diameter, followed the old piece cutting very smoothly the new piece. I worked slow so not to chip it and it cut it very nicely. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Doc1982 Samba Member
Joined: April 11, 2007 Posts: 139 Location: Murphysboro, IL
Posted: Wed Jun 20, 2007 9:27 pm Post subject: |
I'm going to be doing this myself pretty soon. How did you match the color on the stain? I like the look of that a lot! _________________ 1977 Westy
1982 Rabbit Convertible
1999 1.8t Passat Wagon |
Posted: Wed Jun 20, 2007 10:12 pm Post subject: |
Went to Daly's in Seattle and had it color matched to the old panel colors providing them with a sample piece of the new ply to test on. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Thu Jun 21, 2007 3:37 am Post subject: |
That looks pretty close. I eyeballed mine, and it came close as well.
I used a jigsaw with a very fine blade to minimize chipping. To also minimize chipping (splintering), after I traced the lines (on both sides of the wood), I used a box knife and cut in just inside the lines. This will confine the chipping. I then used masking tape on both sides. _________________ '76 Deluxe Campmobile |
rcnotes Samba Member
Joined: July 09, 2005 Posts: 641 Location: Ann Arbor, MI
Posted: Thu Jun 21, 2007 5:20 am Post subject: |
I used a utility knife with a new blade to cut the panelling. No splintering and easy to cut
1/8" birch plywood is available as a product called door skins from good lumber yards
Posted: Thu Jun 21, 2007 5:46 am Post subject: |
Nice color rc. _________________ '76 Deluxe Campmobile |
simon66 Samba Member
Posted: Thu Jun 21, 2007 6:06 am Post subject: |
ChiTwnVW wrote: |
I used a bosche jig saw blade on my 3mm birch paneling. The teeth on this blade were straight and fine. It did a real nice at preventing splinters and splits. You can get these at Home Depot in the tools section.
Very nice color match!
Scott
70 |
