VolksFire Samba Member
Posted: Wed Jun 20, 2007 10:31 pm Post subject: Identify this radio! |
Ok guys. I may have found the correct radio for my bus. My 67 kombi originally had a Blaupunkt Emden radio. The only Emdens that I have found on the internet for sale are Emden III's which came out in 68. Well here's a 67 radio (correct knobs and everything) and it has the same part number as the later Emdens (minus the letter at the end of the numbers), which leads me to believe that this is an earlier Emden radio, and more importantly, it's the right one!!! The part number is 111 035 103. Can anyone comfirm that this is a 1967 Blaupunkt Emden radio?
_________________ Jahnai Pearson - VW Restoration Technician
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Quantum Coupe
85 Quantum Sedan
85 Quantum Syncro Wagon
96 Golf GL |
coad Samba Scapegoat
Posted: Thu Jun 21, 2007 4:55 am Post subject: Re: Indentify this radio!!! |
VolksFire wrote: |
Blaupunkts have date codes starting in 1956. The first letter of the serial number on the paper tag on the side tells you the date of the radio
Quote: |
1956 - 1957 - K
1957 - 1958 - S
1958 - 1959 - G
1959 - 1960 - Q
1960 - 1961 - D
1961 - 1962 - E
1962 - 1963 - T
1963 - 1964 - U
1964 - 1965 - V
1965 - 1966 - W
1966 - 1967 - Z |
http://members.aol.com/porshalaka/DerWhitesBlaupunktRadios.html
Another quick thing to look for are the Civil Defense marks on the dial. These were used by almost all US Radio manufacturers between (approx) 1953 and 1963. Since your radio has those markings (the little triangles) it was probably made closer to 63 than 66. But since the radio would have sat on the dealer's shelf a while earlier is still OK. |
aircooled Samba Member
Joined: December 02, 2003 Posts: 1290 Location: Heartland, Neb
Posted: Thu Jun 21, 2007 10:04 am Post subject: |
My Blaupunkt has a part number of 111 035 101, with 67 knobs and the VW logo on them. Is it in fact a 67 model. The serial number starts with an X from Wolfburg.
_________________ 67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska |
Posted: Thu Jun 21, 2007 1:51 pm Post subject: |
There were no paper tags anymore. The only markings at all was the part number. 111 035 103. Thanks for the input so far. _________________ Jahnai Pearson - VW Restoration Technician
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Quantum Coupe
85 Quantum Sedan
96 Golf GL |
Posted: Sat Sep 15, 2007 2:53 pm Post subject: |
well everybody, upon confirming that the radio is in fact the correct Emden model that i need, i purchased it. however, it didnt come with any wires or plugs, and i cant find any info. on what plugs in where. does anybody have a picture of the rear of either the emden model or wolfsburg model installed so i can see how it should look? _________________ Jahnai Pearson - VW Restoration Technician
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Quantum Coupe
85 Quantum Sedan
96 Golf GL |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Fri Sep 28, 2007 1:21 am Post subject: |
aircooled wrote: |
My Blaupunkt has a part number of 111 035 101, with 67 knobs and the VW logo on them. Is it in fact a 67 model. The serial number starts with an X from Wolfburg. |
Yes, it is a 1967 model. 111-035-101 is a 1967 Wolfsburg, 111-035-103 is a 1967 Emden. The difference is the bands they receive. Wolfsburg for 1967 has AM and long wave (LW not used in the U.S.), while 1967 Emdens are AM-FM. Emdens were made by both Blaupunkt and Grundig for VW, and both are very similar externally but totally different internally.
VolksFire wrote: |
well everybody, upon confirming that the radio is in fact the correct Emden model that i need, i purchased it. however, it didnt come with any wires or plugs, and i cant find any info. on what plugs in where. does anybody have a picture of the rear of either the emden model or wolfsburg model installed so i can see how it should look? |
Everett has the radio tech bulletins here .... note the later ones are listed as 1966 bulletins but reference the new radios from August 1966 (1967 models)
http://www.thesamba.com/vw/archives/manuals/techbulletins/e5.php
If you need a speaker plug to fit, send me a PM. If you don't have the Blaupunkt speaker mounting bracket for the bus, you can use a Sapphire bus speaker bracket. The Blau bracket mounts with a screw through the dash on top, the Sapphire mounting screws are under the bottom lip of the dash.
-Dave _________________ ~~~~~~~~
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Sat Sep 15, 2012 5:49 pm Post subject: |
I bought this radio the VF is referring to. I love the VW embossed Black knobs and its gonna look great in my 67 Bus. Unfortunately, the faceplate is broken. Anyone hording faceplates?
Youriam Samba Member
Joined: January 11, 2018 Posts: 7 Location: Caro, Egypt
Posted: Tue Jan 30, 2018 6:27 am Post subject: Re: Indentify this radio!!! |
coad wrote: |
VolksFire wrote: |
Quote: |
1956 - 1957 - K
1957 - 1958 - S
1958 - 1959 - G
1959 - 1960 - Q
1960 - 1961 - D
1961 - 1962 - E
1962 - 1963 - T
1963 - 1964 - U
1964 - 1965 - V
1965 - 1966 - W
1966 - 1967 - Z |
Do you have any idea is that the original one for my 71 standard bug.
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Tue Jan 30, 2018 9:51 am Post subject: Re: Identify this radio! |
EverettB wrote: |
It's hard to see in your photo but It looks like it has a B serial # prefix?
Or it says 7 630 081?
B or 7 630 is 1970 production so there is a good chance that is an original radio.
There is a larger serial # listing that what is above here in the Forums
https://www.thesamba.com/vw/forum/viewtopic.php?t=279505 |
Please find herewith the photos in clearer version
I guess that's what you mean, so is it the right one ? |
