jspbtown Samba Member
Posted: Mon Dec 03, 2007 4:54 pm Post subject: |
Stock linkage...I know. Not good. Is there a way to test for the linkage so I can know its that before investing? When I disconnect the carbs there are no return springs to hold them closed. Should I use something like a rubber band on each?? |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Mon Dec 03, 2007 5:35 pm Post subject: |
Ohhh...there ought to be some sort of return spring on the throttle plates, Jeff. If there isn't, rig something. Rubber bands won't do it. I've got a rather healthy return spring off my left carb (Webers) due to weak internal return springs. The linkage itself, so long as it isn't binding anywhere, should be fine and servicable.
The popping then stalling is a sign of a very lean condition. Double and triple check the obvious first before you go ripping into the carb to see what size jets it has (though, that may be the problem). A little tickle in the back of my brain keeps telling me it may be distributor related. Are you getting spark on that side? And platinums aren't really good for the car - stock plugs are the best. Something about the heat range, which would definately foul up the best laid plans. Before you get into the carbs, change the plugs for stockers, and if you've got a spare distributor, change it out and see what happens. I had to do that on my SR (similar symptoms) and found that my NEW 090 distributor wasn't worth squat. The advance mechanism wasn't working. It would idle, but at the slightest hint of accelleration would backfire and stall.
Rick |
Posted: Mon Dec 03, 2007 7:09 pm Post subject: |
The return spring....and its a big one....is on the linkage.
I bought new plugs yesterday and had hoped to install today but I am watching the Pats kick some butt on Monday Night Football with my boy. Priorities ya know!
Plugs first, adjust carbs next. |
Posted: Mon Dec 03, 2007 7:29 pm Post subject: |
Somethin' ain't right then. I've never had Kads, but I think all carbs have built-in return springs. "Helper" springs are only necessary when the other ones are getting weak. You should be able to take off the linkage, pull the throttle plate all the way open and let go, and the butterflys should snap shut. Without knowing the model of the Kadron, I can't find a parts diagram to see if there is supposed to be one.
R |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Mon Dec 03, 2007 7:39 pm Post subject: |
Try switching the plug wires on cyls. 3 and 4. A VW engine will run suprisingly well with those 2 wires crossed and they will pop on occasion. Give it a try? _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
hotair65 Samba Member
Joined: July 31, 2007 Posts: 271 Location: Wakefield MA.
Posted: Tue Dec 11, 2007 7:28 am Post subject: |
any luck getting it running yet?? |
Endoboy Samba Member
Joined: May 19, 2005 Posts: 502 Location: Allentown, PA
Posted: Tue Dec 11, 2007 7:48 am Post subject: |
Letterman7 wrote: |
Ohhh...there ought to be some sort of return spring on the throttle plates, Jeff. If there isn't, rig something. Rubber bands won't do it. I've got a rather healthy return spring off my left carb (Webers) due to weak internal return springs. The linkage itself, so long as it isn't binding anywhere, should be fine and servicable. |
Just make sure whatever you rig up is either in the center of the linkage, or exactly matched on both sides. Otherwise, the carbs will never sync up properly throughout the range of motion. The linkage needs to engage each carb evenly from idle to full throttle to work smoothly. I learned that the hard way when my motor builder put a large spring on just one carb (on top of a weak one in the center). He spent hours trying to get that thing to run right and never did, and the guy who redid it properly clued me in finally. Now it works great. _________________ 1970 Autodynamics Deserter Series One (gone)
"Americans can always be counted on to do the right thing...after they have exhausted all other possibilities." --- Winston Churchill |
Posted: Tue Dec 11, 2007 8:38 am Post subject: |
Yeah, that's true. I'm still fooling around with fine tuning the motor, but on it's maiden voyage to the next town for a show earlier in the year, it seemed to pull nice and strong, with no stumbling, but I just don't like the idea of a helper spring pulling on the linkage right at the carb. A center mount would certainly take some of the pressure off, but it's a matter of finding the right mounting points! |
Posted: Tue Dec 11, 2007 9:32 am Post subject: |
Letterman7 wrote: |
The thing that made the biggest difference was that he put some bicycle brake housing through the guide tube for the throttle cable to go through. That reduced a lot of the drag on the cable from going through the tube at an angle, and made it so the spring didn't need to be nearly as stiff. It's also much smoother at the pedal when I accelerate now. It was really amazing how much difference it made. _________________ 1970 Autodynamics Deserter Series One (gone)
Posted: Tue Dec 11, 2007 2:24 pm Post subject: |
Hotair65,
Running better...not perfect.
Thanks |
lazybonz Samba Member
Joined: April 07, 2007 Posts: 347 Location: Long Island, NY
Posted: Fri Dec 14, 2007 10:25 am Post subject: |
Posted: Fri Dec 14, 2007 10:34 am Post subject: |
steering wheel looks great. nice soluton on the shocks too! must be nice to get it back on the wheels. |
Posted: Fri Dec 14, 2007 11:20 am Post subject: |
Wouldn't be a fair trade...yours is soooo much nicer!
Oh yeah...plus my wife would kill me. |
Posted: Fri Dec 14, 2007 12:13 pm Post subject: |
"jeff nice for you to say that but untrue "
Untrue about the wife or yours being nicer........
Must be yours being nicer cause I KNOW the wife would kill me. |
Posted: Fri Dec 14, 2007 12:20 pm Post subject: |
untrue about mine being nicer i have to say you did a great job.
My wife would call me a idiot after what i have been trough untill she see yours pull up in the driveway i belive she would say good deal now lets go get a rita's ice cream. _________________ also known as GreenManx on the other sites.
Lime Green Meyer's MANX
Avatar artwork done by Sandcat John..
http://s475.photobucket.com/albums/rr118/LongIslandManx/ |
BIG BALLS MAGEE Samba Member
Joined: February 13, 2006 Posts: 109 Location: your girlfriends house
Posted: Fri Dec 14, 2007 12:50 pm Post subject: |
what size are the front tires? _________________ 69 square |
Posted: Fri Dec 14, 2007 1:40 pm Post subject: |
BIG BALLS MAGEE wrote: |
what size are the front tires? |
36DD is what came to mind first
had to sorry _________________ also known as GreenManx on the other sites.
