sagebus Samba Member
Joined: July 26, 2004 Posts: 310 Location: Temescal Valley, Corona California
Posted: Thu Jun 28, 2007 8:19 am Post subject: Replace rear heater core "T" w/ 5/8" T ? |
Rusted T fittings on my 84 westy 1.9 Ltr.As you know the T is 3/4" on two of the ends,and the end going to the rear heater core is 1/2".The nipple on the heater core is also 3/4".Have had trouble getting one of the rear heater core hose VW part #255 265 591.Why not replace factory T with one 5/8" and then use 5/8" hose to the heater core in place of the VW one.Anyone ever done this ? _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
tikibus Samba Member
Joined: July 07, 2006 Posts: 834 Location: Rochester, NY
Posted: Thu Jun 28, 2007 8:28 am Post subject: |
Bus Depot or Van Cafe stock the plastic T's. Also try Bus Boys and GoWesty. Vanagain too! Some won't show the T's on the Web sites, call and all will be well.
Best bet is to stick with OEM.
My .02's _________________ Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC |
Posted: Thu Jun 28, 2007 8:34 am Post subject: |
Tikibus,I have the plastic VW "T"s , it is the $70.00 hose I am trying to get around.Part # 255 265 591 _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
Posted: Thu Jun 28, 2007 8:43 am Post subject: |
Oops.
My Bad.
Napa might have the hose.
Also try Gates hose. Get to a Tractor Trailer repair shop and ask around.
BMW and Audi repair shops may have stock hose to cut to length.
I'm kinda in the same pickle, had to cut the hoses when doing my rehabilitation to the V last winter. Hoses are rather stretched to the limit!
Mark
______________
1984 Westy - Tiki
Posted: Thu Jun 28, 2007 9:09 am Post subject: |
Yep,tried Napa,the guys at my local Napa are not the sharpest of parts helpers,been to that store several times this week,have never got what I needed.Napa says they have the hose, but it will not fit. The hose I need is smaller on the one end that connects to the "T" ,7/16" ID,and the end that connects to the heater core is 5/8" inner diameter.Went to the VW dealer parts Dept,his search turned up, 1 in Henderson,NV, one? In all of the USA?He said it will take a week to get here.$57.00 _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
Posted: Thu Jun 28, 2007 9:15 am Post subject: |
That's just not right!
Could try www.CIP1.com
Frank Condelli and Assoc.'s in Canada.
There is a parts place in AZ, but I can't remember the name... German Autohaus?
Double turds on the hunt for the hose, man. _________________ Happy Trails!
Mark
______________
1984 Westy - Tiki
tencentlife Samba Member
Posted: Thu Jun 28, 2007 12:10 pm Post subject: |
Quote: |
As you know the T is 3/4" on two of the ends,and the end going to the rear heater core is 1/2".The nipple on the heater core is also 3/4". |
If this is the case, why not use a 3/4" brass barbed tee, and 3/4" ID heater hose. There's a restrictor in the rear heater core fitting anyway, so what size hose you use doesn't alter the flow rate there (too much and you don't get good flow to the front core). Brass will never ever need to be replaced, and you can find barbed tees at the home supply stores. |
Posted: Thu Jun 28, 2007 12:28 pm Post subject: |
Tencentlife,Thats what I am going to try.Restrictor in that hose eh? I have been wondering and asking what that little plastic insert was I found on the one hose I have that comes off the top nipple of the rear heater core.Should the bottom hose have the same restrictor insert ? I have a picture of the offending hose and said insert in my gallery.Please take a look,and give me your thoughts.Thanks much,Mark _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
Posted: Thu Jun 28, 2007 12:43 pm Post subject: |
You only need one restrictor, and it shouldn't matter which short rear heater core hose, feed or return, it is put in, as long as it stays put. Without it, if you have the rear heater control valve fully open, you would get a diminished flow to the front heater. Since front heat and defrost is priority, this reduces the maximum volume of coolant that can go thru the rear core's sub-circuit, so there is better flow available at the front.
So all the hoses could be 3/4" ID? I'm contemplating replacing those tees myself at some point, before I have an unpleasant surprise, and I'd sure prefer using brass pipe barbs to any more plastic. Let me know if that works out. You are my guinea pig. |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Thu Jun 28, 2007 11:17 pm Post subject: |
If my memory serves me correctly the main heater hoses are 5/8 and not 3/4. The hose to the back heater is 1/2 on one end and 5/8 on the other. Hunt and find a 5/8 hose with a 90° bend molded into one end and use the 90 to connect to the heat valve. This will eliminate the force on the heater that causes the o-ring on the valve to leak. |
Posted: Fri Jun 29, 2007 8:18 am Post subject: |
I can't remember, myself. I had the rear heater out some years ago, put in a new core, and haven't had any trouble with it, so I'm going on sagebus's estimation of the pipe sizes. I'm sure when the day comes I'll have to figure it out myself again, since there's no way I'll remember this little bit of arcana way down the road (he types with fingers crossed). |
