bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Thu Jun 28, 2007 10:01 am Post subject: Subaru radiator additive |
After performing the rear brake job on the 84, I noticed the perverbial water drip coming from the right side head. I removed the right side engine tin, and can see that the blue gasket is allowing a drip in it's center. There is a quarter sized puddle on the ground. Very small leak. I removed the valve covers and checked the torque of the head bolts; all were good.
I did the search, and did not see if there was a general aggreement as to if adding the Subaru additive might help stop this slight leak. Any testimonials?
Or do I replace the seals? _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
kenmag Samba Member
Joined: March 12, 2007 Posts: 275 Location: Toronto, Canada
Posted: Thu Jun 28, 2007 10:21 am Post subject: |
I don't think that additive is applicable in your case.. I believe it was made to help stop corosion of aluminum (electrolysis), not to stop existing leaks. Though it would not hurt to use after the leak has been fixed. _________________ 87GL Westy/suby ej22
87GL tintop/suby ej22
05 Golf TDI
95 jetta GLX |
Tomasz Samba Member
Joined: September 08, 2005 Posts: 1096 Location: in a van down by the river
Posted: Thu Jun 28, 2007 3:18 pm Post subject: Re: Subaru radiator additive |
bucko wrote: |
Or do I replace the seals? |
Don't sweat it and add it without a hasitation. I did so 3 weeks ago as did Markus who posts here as well. He and I had the same symptoms after 1500 mile memorial weekend trip, a several drop puddle right under the tin. Get yourself one bottle for whopping $1.81 (tax inc.) at the Subaru dealership and add it to the pressurized expansion tank then take it for a ride. Haven't had any leak or issues since, nor did Markus and his was added in September of last year. .
Later |
bucko Samba Member
Posted: Thu Jun 28, 2007 3:53 pm Post subject: Re: Subaru radiator additive |
Tomasz wrote: |
bucko wrote: |
Later |
Thanks for the feedback. I thought I read awhile ago where some folks added it to "soften" the seals used at the heads. I had used "BARS LEAK" in an old AMC Matador about 20 years ago to seal a head gasket leak. That stuff worked great, but I read here from others that it's not wise to use it in our wasserboxers because of all the plumming, and because the VW only cools the heads, and not the engine case, therefore it would plug up the radiator core.
It's such a small leak; I can see the wet spot on the blue head seal. I'll run out tomorrow and try the Subaru additive. Can't hurt, and I won't be out that much if it doesn't! _________________ Current VW drives: 1984 Westfalia
Joined: April 12, 2003 Posts: 1839 Location: Englewood, FL
Posted: Thu Jun 28, 2007 4:06 pm Post subject: |
kenmag wrote: |
I don't think that additive is applicable in your case.. I believe it was made to help stop corosion of aluminum (electrolysis), not to stop existing leaks. Though it would not hurt to use after the leak has been fixed. |
The Suby additive is actually repackaged "radweld" made by Holts from what I have seen and read.
http://www.motortraders.com/xcart/catalog/product_16308_Holts_Radweld44192_125ml.html
Kinda scary at first to think your pumping stop leak through the system, but hey they are putting it in subies left and right at the dealerships etc... Plus it sure beats pulling the heads if your not quite ready to do that. I was pretty sceptical I've heard run 2 bottles cause the system is so big, but I was a little concerned about blockage in the radiator. so I tried just one bottle and kept the heaters closed (not like they are ever on much here in FL anyway). Like Tomasz said, it worked.
Stuffs been in mine since early october, has not leaked a drop and we have done quite a few long trips pulling the trailer and a/c pumping with no overheating issues. Mabe not the best fix, but I was trying to avoid teardown right in the middle of a great camping season, at this oint it looks like I can keep on going through next season (knocks on the faux wood of his computer desk ) [/url] _________________ Markus |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Thu Jun 28, 2007 4:20 pm Post subject: |
Hey Bucko,
I noticed the same "drip" almost a year ago
added the 2 Suby blue and it's been great ever since
you can't go wrong for the price
expect the usual naysayers who do their own headwork and engine rebuilds in their garages on the weekends |
bucko Samba Member
Posted: Thu Jun 28, 2007 4:45 pm Post subject: |
Still a toss up; I just read up some replies on this doing a serch. There are many including those that have a respectable opinion that say don't use it, and others also with respectable opinions that have used it with grat success.
I plan to take this vehicle to Texas soon to be used as a "daily driver".
I don't have the time for this repair, so I'm contiplating taking it to the local VW dealer and having new heads installed, as pitting on the head surfaces is the cause for leaking, along with the 2 cylinder ring seals. GoWesty article also mentioned lack of flushing and lack of using non-phosphorous coolant. All of which I can assume previous owners ignored. _________________ Current VW drives: 1984 Westfalia
Petervw Samba Member
Joined: July 04, 2005 Posts: 1020 Location: Sarnia Ont. Canada
Posted: Thu Jun 28, 2007 4:52 pm Post subject: |
subaru puts the "blue bottle" in every one of there new cars now....for the older models to Maintain the warranty, it is Required to add this coolant conditioner when changing out the coolant ...if the subi head has an external leak like the vanagon ( not entering the combustion chamber) then 2 bottles are required and this service should be done every 12000mi as conducted by subarus research(this can be a pain)...any "all metals" coolant will do, but I prefer "Peak"..there is absolutely no danger of plugging up the rad from this additive...because the vanagon has such a large cooling system 2 bottles would be recommended, maybe even three bottles..should cost about $1.35 per bottle...have the motor oil checked every once in a while to make sure that the coolant is Not entering lubrication system...if not, then everything should be fine, maybe even for many years to come |
kenmag Samba Member
Posted: Thu Jun 28, 2007 8:41 pm Post subject: |
wow, didn't know that stuff was so intense. I did add a bottle at the end of the
EJ22 conversion. Another one of those 'cheap insurance' to do's I suppose.
Thanks. _________________ 87GL Westy/suby ej22
05 Golf TDI
95 jetta GLX |
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Fri Jun 29, 2007 5:45 am Post subject: |
I'm going to weigh in on the side of the skeptics. When I replaced the radiator on my wife's '93 Loyale last summer I was gathering as much information as I could from the Subaru sites... especially NASIOC.org. It seems to me I stumbled across quite a few complaints that attributed plugged cooling systems to the Subaru additive, but of course Subaru was claiming there's no way it would cause a problem. I recall several folks on the fence as to whether to use it or void the warranty. Granted, a thread on an Internet forum is not a statistical sampling. I'm not saying it will plug up your system but if I decide to use it I'm going to do more research specifically on that subject on the Subie sites. |
kenmag Samba Member
Posted: Fri Jun 29, 2007 5:54 am Post subject: |
Volksaholic wrote: |
Good Subie site:
http://bbs.legacycentral.org/ _________________ 87GL Westy/suby ej22
05 Golf TDI
95 jetta GLX |
Terry Kay Banned
Posted: Fri Jun 29, 2007 6:47 am Post subject: |
<<I tried just one bottle and kept the heaters closed>>
Huh.
What happens when you open the heater valve?
If your having heater core problems now ( little or no heat)--wait till you open up the valve.
If our Van still has the original radiator in it---
Well, plan on spending some Dracma's, and some time in replacing it.
Subaru uses the stuff in a new vehicle with all open cooling passages.
Wait till you drop some of this stuff n a 20 year old ( plus or minus a couple of years) ride.
You'll find out what's going to go bad in your cooling system pretty quick.
Keep an eye on your temp gauge--you'll know. _________________ T.K. |
Posted: Fri Jun 29, 2007 7:04 am Post subject: |
That is a very good point made here...many years ago when I first bought my van the previous owner or whoever put in some Silver stuff??...the thermostat was all gray in color and slightly caked up...I can only imagine what the heater core/rad must of looked like inside....shortly after that time the motor was replaced ...regular coolant changes will keep it fresh looking
Terry Kay wrote: |
Huh.
Keep an eye on your temp gauge--you'll know. |
Tomasz Samba Member
Posted: Fri Jun 29, 2007 4:39 pm Post subject: |
we'll keep you all updated as to what happens with our cooling systems,
so far Markus traveled at least a few thousand miles with no issues
I on the other hand only covered 600 miles in Florida heat with nothing to speak of
by adding this stuff I really had nothing to lose and possibly postpone head gasket replacement for a year or two
if you have money to spend then yes why bother with some cheap uncertain fixes, just replace the head gaskets and while at it I would just send the van to gowesty and have them go through it just in case, however if you're tight with the money then go with $1.81 fix to start with |
Posted: Fri Jun 29, 2007 9:17 pm Post subject: |
Huh.
"I TRIED JUST ONE BOTTLE AND KEPT THE HEATERS CLOSED" can you hear me know?
Quote: |
What happens when you open the heater valve? |
Uh, I get hot air I can even adjust how hot and and how much blows on me with those knobs on the dash, I can also control how hard I want the air to come out with the fan, you know the one I fixed what 2 years ago by spraying electrical cleaner lube directly onto it, still going strong BTW
Well, plan on spending some Dracma's, and some time in replacing it. |
No heater problems, other that the rear one is in my way, Oh no I still have the OG rad with bout' 130 k miles and Ive wasted all my dracmas at the all night massage parlor on a"rub and a tug"! Oh wait, thats right its been a year and no overheating or leaking issues, phew!
I've been watchin', nothings happening, its not like I pumped a big chunky bottle of "bars" through the system, thats last resort used car saleman tactics there. Oh snap, wasn't that you who did that?...my bad
Now folks as stated in my prevous posting I'm a bit of a skeptic, I don't think I would use it as a conditioner like suby does, but the fact that they use it the way they do tells me that even though it is a "stop leak" type of substance, its defanitly not like many of the off the shelf stuff that you would run to the auto parts store to stick in your 1970 C/10 chevy when you plowed through that elderly church group after a hard nights drinking only to find that one of thier canes punctured that 4 core you just picked up at the pick-n-pull!
I dunno what the Holts (subie) stuff is, I know its not a bottle filled with pellets of rabbit food looking crap, and instead of a dumping a whole bunch of it in I used a minamum amount and wanted its "magic" to focus on the the engine area-not the heaters. what do you know it worked for me
But It's probably just dumb luck , Heck I'm sure that Terry will be more than happy to point out just how dumb I am. In fact I bet he'll have a good laugh about it with his "buddies" at the parts counter in the local VW dealership, as it always seems to end with a good time had by all over at vw of shitcago or whatever, I just wonder are they laughing with you or..... _________________ Markus |
SVYOLO Samba Member
Posted: Sat Jun 30, 2007 7:09 pm Post subject: Subaru coolant additive |
We take apart Subaru motors for a living. Some have a "jelly like" coolant substance in a few places in the engine. The additive solidifies when it contacts air.
Please take this post for what it is worth, as my opinion. The Subaru coolant additive may help with leaks short term, but might trash your engine and entire cooling/heating system long term.
Subarus cooling system was vastly simpler/less leaky than a waterjunkers. Their leaks were external head gasket leaks. Waterleakers are internal head gasket leaks, and leaks everywhere else, which is 10 times more connections than a Subarus'. The Subaru product helped on Subaru's, but might actually cause more harm on Vanagon engines.
My opinion,
John
East Coast Vanagon |
bheck Samba Member
Posted: Sun Jul 01, 2007 4:21 am Post subject: |
I put 2 bottles in last summer. I am not having any overheating problems. |
Terry Kay Banned
Posted: Sun Jul 01, 2007 7:00 am Post subject: |
<<<Plus it sure beats pulling the heads if your not quite ready to do that.>>
This line is pretty funny, and I've been thinking about an anology.
It's kinda like applying oral gel to a tooth when you've got a tooth ache.
It'll dampen the immediate pain down, but sooner or later your either gonna have to go to the dentist, or if you wait long enough the tooth fairy will be visiting you when you have to have it yanked, or even visiting the root canal quack---and spending big money. $$$$$$
Why prolong the inevitable?
If the heads leaking, take the lumps, and get the job done and over with.
It isn't that bad of a task, and by the time your all done, you'll probably have changed a couple of rotten hoses you've found, replaced a few leaking exhaust gaskets you didn't know were bad-- and the Van will be fixed and good for another 125,000 miles.
All of this without the possiblity jepodizing the rest of your cooling system with the Wham Bam, magical Oral Gel stop leak.
I would think you would want to do your treasued Van right rather than short cut the job, and possibility of screwing more things up in the process.
The thought of yanking the dash to change a plugged front heater core really would make my mind up real quick against using a miracle in a bottle--
I'd rather do the heads than yank the dash--
Think about it. _________________ T.K. |
Posted: Sun Jul 01, 2007 9:17 am Post subject: |
I think "good for another 125K" would be wishful thinking without having too deal with the leaking problem all over again ...perhaps I am wrong here but I believe that many vanagon owners do not think the headgasket replacement is a permanent solution...I have met many people who's headgasket issues, for whatever reason, remained with them....the worst case senario would be 4 motors (1 from the factory and 3 remanufactured motors from VW Canada..the rebuilders of past time)..all this with having only 60k on the van...Oh by the way, the 4th motor started leaking almost immediately...he simply got tired of the situation and sold the van...the motors were all under warranty but the install labor costs were starting to really irratate him....it really all depends from where one is coming from...for ex., if one is waitng for a better time along with more money to install a better solution, then the "blue bottle" semi-solution would be the best option |
Terry Kay Banned
Posted: Sun Jul 01, 2007 10:22 am Post subject: |
<<I think "good for another 125K" would be wishful thinking without having too deal with the leaking problem all over again>>
Not really.
It depends on who did the head resealing job.
If you don't know, then I'd have to agree--it's a crap shoot.
I do know this--and this is how I put it to the list.
When I'm done with the job,I will, and can expect another 100,000 miles outa the head seals.
If you hire the wrong doctor--well this is your poor call.
<<perhaps I am wrong here but
believe that many vanagon owners do not think the headgasket replacement is a permanent solution>>
For what?
For the heads leaking again?
It's not the head seal's fault that somebody did a crummy job, and used the wrong, or the garbage sealer that came in the gasket kit.
If the head surfaces wern't checked out to be true--is this the engine's fault?
I don't think so.
<<I have met many people who's headgasket issues, for whatever reason, remained with them....the worst case senario would be 4 motors (1 from the factory and 3 remanufactured motors from VW Canada..the rebuilders of past time)..all this with having only 60k on the van...Oh by the way, the 4th motor started leaking almost immediately>>
This whole picture reads to me --buy cheap, have problems.
<<he simply got tired of the situation and sold the van...the motors were all under warranty but the install labor costs were starting to really irratate him....it really all depends from where one is coming from...for ex., if one is waitng for a better time along with more money to install a better solution,>>
Sounds to me like the choice of a Vanagon for this guy was the bad solution.
If ya can't afford the price of the toy--get rid of it.
This sounds like a Chevrolet kinda guy---
<< then the "blue bottle" semi-solution would be the best option>>
There ya go--
if the wound on the finger is deep--throw a band aid and some bag balm on it.
It might heal, or then again--wait long enough and just go get it cut off.
The doctor is way too expensive to get it done right the first time--
short cut the repair--patch it up.
I agree, be frugal.
Good idea. _________________ T.K. |
