ProjectHerbie Samba Member
Joined: January 10, 2007 Posts: 17 Location: Springfield Ohio
Posted: Thu Jun 28, 2007 8:06 pm Post subject: |
All of my other gauges work just not the coolant temp gauge the light flashes all the tim the previous owner said it started the flashing about the time it went out of warranty so the gauge has not worked for a long time. I installed a new cluster out of another because my tach didnt work now it works but not the temp gauge. |
funagon Samba Member
Posted: Thu Jun 28, 2007 5:44 pm Post subject: |
My 87 had a bleed screw in the top of the rear heater valve. My 90 does not. Maybe VW got tired of the leaky thing. |
skaaudivw Samba Member
Joined: April 12, 2006 Posts: 316 Location: wesT hartford, ct
Posted: Thu Jun 28, 2007 5:33 pm Post subject: |
Yes there is a bleeder in the rear heater, I had no problem bleeding my 1.9 85. I just opened the front rad bleeder screw and also did the rear heater once or twice. never jacked the van. Just keep filling the tanks and checking the front. leave the grill off and take a ride. fill more if needed. bleed front more. easy and after reading alot of posts i thought it would be harder then it was |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Thu Jun 28, 2007 3:58 pm Post subject: |
Looking at Ben's site, is there really a bleeder screw in ther rear heater? I'm pretty sure there is a bypass, but I don't recall anything like that in the Bentley... _________________ Rich |
kayakwesty Samba Member
Joined: February 15, 2007 Posts: 687 Location: East Tennessee
Posted: Thu Jun 28, 2007 1:25 pm Post subject: |
are you saying your stock temp gauge doesn't work?
and if so did it just stop?
do the other gauges work? ie gas gauge? _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
B.5.5 Passat Wagen with 30v V6-67000 Miles
DAS AUTO
CHANGE YOUR FUEL LINES!
A post without pictures is useless
http://www.kayakwesty.com
http://www.waldensridgewhitewater.com/ |
Posted: Thu Jun 28, 2007 1:16 pm Post subject: |
I thank you for the info I am going to go home and fill him up my temp gauge did not work when I stopped driving it. Is there a place for an aftermarket gauge so I can monitor the coolant temp |
Posted: Thu Jun 28, 2007 12:54 pm Post subject: Changed water pump how do I and where are bleeders coolant |
I just installed a new water pump on my 86 waterboxer and now its time to put some coolant in how do I properly burp the system? Where are the bleeders Thanks for any help Keith |
