Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Jul 06, 2007 2:34 pm Post subject: |
rosevillain wrote: |
COFBack wrote: |
Tram was on the bottle (still !) |
The "blue bottle" too. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
KTPhil Samba Member
Posted: Fri Jul 06, 2007 4:14 pm Post subject: |
If you ar changing from stock, make sure you determine the new compression ratio. CR will determine timing, and timing is important for a good-running EFI motor. My rebuilder used to shim the barrels to keep it down, especially when unleaded gas came out. |
blankc72 Samba Member
Posted: Sat Jul 07, 2007 10:49 am Post subject: |
[quote="Tram"]
I would research the notorious unreliability of the 1776 before diving in. quote]
I have a 1776 in my '72 beetle and have never had a problem. It is driven daily with my than 15,000 miles on it. It's even been driven 600 miles within a single day a couple of years ago with no trouble. Also, on more than one occasion the engine has seen the better side of 5500 rpm's, NEVER giving me a problem. |
RSL Samba Member
Joined: December 27, 2013 Posts: 5 Location: Netherlands
Posted: Fri Jan 03, 2014 2:54 am Post subject: |
Hello,
I have read lots of discussions about inproving hp on a stock FI.
I have a 78 beetle with 1600FI, I want to put a 1776 in but want to keep the stock FI, will this work?
Or do i need to change or add larger injectors, cam, crankshaft, heads .... ?.
I dont want to make a "race machine" but a daily driver.
Thanks. |
racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Fri Jan 03, 2014 3:17 am Post subject: |
1776 good, 1835 bad |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Fri Jan 03, 2014 7:59 am Post subject: |
I have a 1776 and stock fuel injection in my Notch. It works, but requires adjusting the MPS to achieve the proper AFR. On the advice of Tram, I just swapped out the stock injectors for some larger ones (blue Mercedes). I'll find out this weekend how they affect performance... |
RSL Samba Member
Posted: Fri Jan 10, 2014 7:14 am Post subject: 1776 and stock fuel injection |
Thank you for your reply, did you try the larger injectors, and how dit it work on your engine? how can you adjust the MPS for the proper AFR? how much increase of HP is expected with 1776?
Thanks |
Posted: Fri Jan 10, 2014 7:33 am Post subject: |
The larger injectors seem to be working well. I now have a smoother idle and my AFR readings are less "wonky".
You can adjust the AFR by adjusting the internal screw inside the MPS. If your MPS still has the resin seal covering the large slotted plug, it will need to be removed, along with the plug. Then a small flat-head screw driver can be inserted and the internal screw adjusted. Clockwise = leaner, counter-clockwise= richer. Be sure to note how many turns it takes to remove the large plug because it will need to be re-installed the same way.
There are numerous discussions on this mode here on the Samba which can provide more details... |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Jan 10, 2014 7:39 am Post subject: |
You should have plenty of power for hills etc. Keep a stock camshaft in it or you are asking for trouble. Tram adjusts the MPS & AFR on my '69 FI/AT with a small screw driver while a meter is clipped to the tailpipe. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Jan 10, 2014 12:26 pm Post subject: |
Woreign wrote: |
You can also pull it apart and adjust it internally going in opposite direction 1/8 of a turn at a time or so to achieve the same results without disturbing the setting of the big plug.
This gives you an opportunity to clean the oil out of the unit with electrical cleaner. Note the O ring that seals the two halves isn't present in this pic. This procedure is applicable to C/D systems only. A/B and E are different. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Fri Jan 10, 2014 1:04 pm Post subject: |
Unfortunately, you have a '78 beetle which uses a different fuel injection system than the type 3's. |
Posted: Fri Jan 10, 2014 1:34 pm Post subject: |
Right, but on a Beetle, Bus injectors will provide the additional fuel flow needed for a 1776. He'll be adjusting the mixture on the air flow meter rather than the MAP. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
RSL Samba Member
Posted: Sun Jan 26, 2014 8:34 am Post subject: fi 1776 potential upgrade |
Which heads are recomended for this upgrade, must the size of the valves be increased? |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Sun Jan 26, 2014 2:25 pm Post subject: |
So I had an 1835 using the f/i with a w100 cam, and had to up the fuel pressure and adjust the sensor, we did it on a dyno with a sniffer and it did run a bit lean, buit i wasnt beating it sensless. Currently im going to try a 1776 using another efi setup and another w100 cam. Valve size is barely going up about one or two mil's aabove a stocker, mostly cause i dont want a race engine, but want a bit better uhmph for utah's retarded hilly terrain. I've never really heard of a 1776 being unreliable so far, and i've seen a few that were well maintained last good lives. Far as the power gain i think its worth it to go from a 1580ish (1600) to the 1776 rather then 1641, but I haven't run a 1641 yet . _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
RSL Samba Member
Posted: Thu May 08, 2014 6:29 am Post subject: Upgrade 1776 FI |
I finished the upgrade to 1776cc with FI, runs great, only adjustment made is setting the AFM a bit more "Rich".
Used items:
-Stock Cam
-Mahle Cilinder set 1776cc
-Heads Autolinea 35mm intake and 32mm exhaust
-Set compression 8.0:1
Thank you all for advice |
Posted: Thu May 08, 2014 11:35 am Post subject: Re: Upgrade 1776 FI |
RSL wrote: |
Used items:
-Stock Cam
Do yourself a favor and go with the blue/ green D-Jet injectors for a 412, Volvo, or Mercedes D-Jet car. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
RSL Samba Member
Posted: Sun Oct 05, 2014 4:35 am Post subject: |
Hi Tram,
What will be the advantage for switching to these blue/green injectors? And do you have a part#. for these injectors?
The engine is now running on Bosch part# 280150112.
Thank you, |
