Homeresque Samba Member
Joined: November 11, 2013 Posts: 90 Location: Hippy-Dippy Fruitcake Land
Posted: Thu Apr 13, 2017 3:56 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
Eric&Barb wrote: |
Single circuit will most likely not move enough fluid to work the discs.
Get new grommets and fix the dual circuit problem. |
Well I have new grommets. As well as the new grommets that came installed in the new MC...I'm curious of what ever happened with the previous poster who had the same problem and replaced his grommets three times with no luck?
My preferred inclination is to convert back to the design without the leaking grommets. I'll check the disc-brake conversion posts for luck using existing single circuit MCs. _________________ "Do you see what happens Larry?!?!" |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Apr 13, 2017 7:08 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
BTW have you double checked that the stop bolt in the top of the MC is tight? If loose it will leak from up under the reservoir and look like grommet failure with MC in situ. _________________ In Stereo, Where Available! |
ozark23 Samba Member
Posted: Thu Apr 13, 2017 8:41 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
Homeresque wrote: |
Eric&Barb wrote: |
My preferred inclination is to convert back to the design without the leaking grommets. I'll check the disc-brake conversion posts for luck using existing single circuit MCs. |
I was the one with 3 sets of grommets. Still leaked. I gave up and bought a new master from bustoration, here: http://www.bustoration.com/Master-Cylinder-DUAL-Circuit-67-ONLY-CHINA_p_2041.html
It is the brakes, so I didn't want to chance it and I was sick of messing with it. Put the new one in, bled it, no leaks, works freaking great.
Good Luck. |
GERMANAIRE Samba Member
Joined: August 25, 2007 Posts: 689 Location: BUFORD,GA.
Posted: Wed Apr 19, 2017 6:55 am Post subject: |
I have read the thread but see no answer to this set up. Has anyone tried it
is it worth it. Price seems right. Prices have been ranging from$39 bucks for a dual circuit to $300 + reservoir? German ATE is always best but $300 is steep |
Posted: Wed Apr 19, 2017 6:56 am Post subject: |
slamwise wrote: |
I'm not gonna read this whole thread, but here's my 2 cents. WW sells the 67 only Reservoir, instead of buying used rabbit reservoirs. It fits the 67 only M/C and the late Bay M/C with the proper grommets.
Whats funny is they used to come in the ATE box with the part number cut off of the box. I bet there is a huge mark up on these, as it looks like $1.00 worth of plastic.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211611301E
SocalAutoParts.com sells the 67 only M/C for about $80. It comes with the right grommets and also includes the residual pressure valves already installed, and the dust boot.
It only has one outlet for the front circuit, you have to section in a tee fitting for the front.
http://www.socalautoparts.com/product_info.php/ind...es-p-16772
I've used the kit from Airkewld before. I don't like it. It adds in 2 more grommets and aluminum spacers because he is using the cheap beetle reservoirs with the fat outputs. It works, but i would prefer to keep it simple.
Anyone tried the WW Reservoir and SOCAL Master? I am going drums all around. Thanks in advance, Peter |
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Thu Jul 20, 2017 7:10 am Post subject: Re: Dual Circuit Master Cylinder conversion |
mod needed at the floor pan to fit an ATE MC
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
Posted: Thu Jul 20, 2017 9:32 am Post subject: Re: Dual Circuit Master Cylinder conversion |
perello wrote: |
mod needed at the floor pan to fit an ATE master cylinder
With or without MC spacer?? _________________ In Stereo, Where Available! |
Posted: Thu Jul 20, 2017 10:59 am Post subject: Re: Dual Circuit Master Cylinder conversion |
Eric&Barb wrote: |
With or without MC spacer?? |
Without. Machined push rod though. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Thu Jul 20, 2017 5:24 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
perello wrote: |
Eric&Barb wrote: |
Without. Machined push rod though. |
have any measurements for making that hole? _________________ 1957 Beetle
1966 Bus |
TurbedAWD Samba Member
Joined: October 15, 2011 Posts: 19 Location: Seattle, WA
Posted: Wed Dec 06, 2017 1:42 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
After reading through this entire thread and seeing it has spanned many years, parts prices and availability have changed. Would the easiest solution, for someone who will continue to use drum brakes all around, be just to use a 67 master cylinder with reservoir? They are both available from CIP for about 100 bucks. |
Posted: Wed Dec 06, 2017 1:51 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
Except for say a 1967 only bus. Both the 1967 only and the 1971-79 MCs take the same requirements to install. So no easier either way for pre-1967 bus.
With a 1967 bus the push rod is already setup for the 1967 MC, and would probably need to be redone for the later MC.
Seeing that one can get the later MC for just over $50.00 right now. That means for the average Joe, not having to work an extra 4 or more hours at work to pay for the 1967 only MC. So easier that way.
Also if out on the road, lot more chance of finding a later MC in a local FLAPS than the 1967 only MC. _________________ In Stereo, Where Available! |
Posted: Wed Dec 06, 2017 2:29 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
Eric&Barb wrote: |
Also if out on the road, lot more chance of finding a later MC in a local FLAPS than the 1967 only MC. |
Ah, I was thinking the 67 master would be a direct bolt in without the use of the adapter plate since it is intended for a split bus. |
Posted: Wed Dec 06, 2017 2:45 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
TurbedAWD wrote: |
If you check out the directions we posted earlier, you do not need or in cases of earlier buses do not want the spacer. Without spacer you can fit on the earlier pedal splash pan without need of cutting the rear of the pan to clear there.
Of course with not needing to buy the special spacer it saves one a bit more $$. Even after buying a bolt to cut off the head and file round on one end for a new short push rod. _________________ In Stereo, Where Available! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Wed Dec 06, 2017 4:44 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
I just finished installing a '67 MC on my '65 bus today, here's some notes:
Stroke of the '67MC is 32mm per the Bentley, I measured the stroke of the pushrod (without MC installed) on my '65 bus and got exactly 32mm. No pushrod modification was needed.
Does anyone have pictures of the '67 pushrod assy next to a >66 pushrod? I can't see the difference.
I used the Chinese MC from Cip1 and a Rabbit reservoir, it fit well without a spacer, of course.
I haven't bled or driven the bus yet but I'm confident it will be fine. My '66 bus has a late Bay power MC (manual brake MCs don't fit) with a spacer. The power MC has a bore of 22mm which is probably giving me a hard pedal as the '67MC is 3/4"/19.05mm. I'll likely change the '66 bus to a '67MC in the future.
The pedal pan (if I install it) will need some cutting. I'll post up pics soon so you can see the line routing. (pretty much the same as everyone else's) _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Wed Dec 06, 2017 9:26 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
Been following this with interest because I am about to roll the 56 pickup over onto the rotisserie and clean and paint the bottom and ALL NEW BRAKE PARTS! I bought a roll of the copper bearing metal line stuff. Gonna go all stock BUT a dual circuit master.
HERE'S SOMETHING I'M CONSIDERING;
68-69 MC is a Q, I think, 70 is a T(Drum brakes, no booster) Both about 22.2mm (7/8"- .875") bore and physically the same as 1967's .EXCEPT the 1969 cylinder (Q) has 2 output fittings for the front.
Also, all 3 years have residual valves, that partly check the return flow, so you can pump the pedal up. (NO DISC brake M/C's will have these).
I have a ton of cores around. I used 69 and 70 type 2's as daily drivers for about 3 decades , so, I'll try to figure out which I like the best, then perhaps buy a new or rebuilt one. Or a kit and rebuild my own.
Bottom line, It seems to me that using disc brake Vac- boosted master is just plain wrong in several ways.
(edited- the 1968-9 is the one with 2 front line fittings. and the size on all 3 years is 22.2mm.) _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
Posted: Wed Dec 06, 2017 9:34 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
Residual valves can be added. Personally have just keep the shoes adjusted properly Big problem with the 1968-70 MC is how to mount and use those years of reservoirs.
Please update how it goes! _________________ In Stereo, Where Available! |
Posted: Wed Dec 06, 2017 9:59 pm Post subject: Re: Dual Circuit Master Cylinder conversion |
Are they not the same as the 1967 one? If not... I agree, not so great. Pretty sure they are both 20mm, though. _________________ Al Brase
Vanagons:
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Wed Dec 13, 2017 5:15 am Post subject: Re: Dual Circuit Master Cylinder conversion |
Alan Brase wrote: |
Are they not the same as the 1967 one? If not... I agree, not so great. Pretty sure they are both 20mm, though. |
Well, I'm wrong on most counts here. the 1968-9 is 22.2mm.
The 67 reservoir won't fit either.
The early reservoir has nipples at 100mm. these 1968-70 cylinders have 85mm nipple spacing. Go figure. I have one later chinese cylinder with 100mm spacing, but single outlet for front and that extended piston for the booster.
Back to square one. _________________ Al Brase
Vanagons:
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
