Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24059 Location: Southeast USA
Posted: Sat Jul 14, 2007 7:25 pm Post subject: SOLEX 26 VFIS question |
Hi folks. I just picked up the carb on the left. All it says on the body is SOLEX. It looks like the SOLEX 26 VFIS carb on my engine, but you can see it doesn't have the strengthening ribs in the body or around the base. Can someone identify it and give a date of manufacture? Danke Sehr.
splitjunkie Samba Member
Posted: Sat Jul 14, 2007 7:40 pm Post subject: |
It's a later replacement part. They refined it over the years even after they stopped putting them on productions engines. They were still using that carb on the industrial engines into the mid 50's or later although the ones for the industrial engines had different linkages on them. _________________ Chris
Posted: Sat Jul 14, 2007 11:13 pm Post subject: |
Why would Solex weaken the casting around the base? It would make more sense that the beefier one on the right is the later carb. I have photos of wartime KdF carburetors with the identical body casting as the carb on the left. |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Sun Jul 15, 2007 12:03 am Post subject: |
Here is a NOS later replacement carb for an industrial engine. It still has the same casting as the others. The second pic has some numbers stamped into the side of the flange where it bolts to the manifold. Any idea what these numbers are? Maybe a date code?
And here is a picture of Christian's (KDFkid) Kubelwagen, chassis #66. It looks like the carbie you found, with the exception that the Kubel one has the VW cog wheel logo cast into the side of it.
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Sun Jul 15, 2007 10:18 am Post subject: |
Well then it must be an earlier carb. How about some more pictures. _________________ Chris
Posted: Sun Jul 15, 2007 1:39 pm Post subject: |
Here's a couple more pictures.
My guess is that it's an early postwar 26 VFI series. |
IN2VWS Samba Member
Posted: Sun Jul 15, 2007 7:42 pm Post subject: |
This pic is from a 1950 barndoor manual
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
