bugpack tie rod flip kit
MaineBuggy
MaineBuggy is offline
PostPosted: Mon Jul 16, 2007 7:46 pm    Post subject: bugpack tie rod flip kit Reply with quote
Anyone have any experience with this kit. I think i just wasted $20 on this piece of crap. Drilled out my pitman arm, tapped the bushings in, went to put the tie rods on, tie rod ends fit way too f*&king loose. Very dissapointed. Am i doing something wrong before i give up?
Jason C
Jason C is offline
PostPosted: Mon Jul 16, 2007 7:53 pm    Post subject: Reply with quote
What year? The later style tie rod ends, 68 and up I believe, are bigger then the earlier ones.
Throw me a bone here. All I wanted were
sharks with friggen laser beams attached to their heads.
64 Bug
MaineBuggy
PostPosted: Mon Jul 16, 2007 9:15 pm    Post subject: Reply with quote
Part # on the kit is 6613-11.....the instructions say:
Tie Rod Relocation Bushing
The purpose of this bushing is to reduce bumpsteer in lowered VW Type 1 Sedan with a balljoint front beam.
Thats what i have is a BJ beam, and i thought all BJ front ends were the same.
ashman40
ashman40 is offline
PostPosted: Mon Jul 16, 2007 9:40 pm    Post subject: Reply with quote
Sorry MaineBuggy. Looks like you will need at least two new inner tie rod ends (see note at bottom):
http://www2.cip1.com/ProductDetails.asp?ProductCode=C12%2D6613%2D11
These look like the parts you will need:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D131%2D415%2D821%2DA
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D131%2D415%2D813%2DE
Looks like VW made an upgrade midway thru the 1968 model year.
Folks like me who upgrade their brake spindles also need to worry about matching the correct tie rod ends.
AshMan40
'67 Beetle {project car that never made it to the road Sad }
Jason C
Jason C is offline
PostPosted: Tue Jul 17, 2007 4:12 am    Post subject: Reply with quote
66-67 are ball joint, but have smaller sized tie rod ends.
64 Bug
rgdedge
rgdedge is offline
PostPosted: Tue Jul 17, 2007 4:49 am    Post subject: Reply with quote
You drill the steering arm on the spindle and press the bushing in and mount the tie rod from the bottom not on the pitman arm.
Tim
MaineBuggy
PostPosted: Tue Jul 17, 2007 5:54 am    Post subject: Reply with quote
Thanks for everyones reply. Last night i check in a Bugpack book i had laying around and it said that you do need the later tie rod ends. I bought this kit at the local VW speed shop and neither the front of the package nor the instructions said anything about the newer ends. I know this kit is made for the spindles but i have a sand rail that has a raised front end so im using it on the pitman arm.
Jennepher Premium Member
Jennepher is offline
PostPosted: Tue Jul 17, 2007 7:02 am    Post subject: Reply with quote
please keep discussion to one thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=2360340
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - 1958-1967 All times are Mountain Standard Time/Pacific Daylight Savings Time
