65vwgirlzcan2 Samba Member
Posted: Tue Jul 24, 2007 10:17 am Post subject: |
great find but its his girlfriends. great birthday gift. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Tue Jul 24, 2007 7:44 am Post subject: |
Congratulations! Certainly a more solid example as far as New England Beetles are concerned.
I'd strongly suggest first trying to save your fenders and front apron by pounding out the dents. IF those are original fenders, or even German fenders from a different car, the metal is STURDY. You have nothing to lose in trying to un-dent the parts. Just buy a universal body dolly (Eastwood.com). Or find a sledge hammer head to back up your hammer blows... Even though your front apron is rusty at the bottom and may not provide enough holding strength, you can try to use a small hydraulic jack placed vertically inside the trunk, using sturdy boards against the panel under the gas tank to spread the pressure of the jack's wheels. Small block of wood at the arm pedestal. As you pump up the jack, the arm will then force the apron forward. A little at a time, and work the creases with a body hammer (also from Eastwood).
Then practice evening out the dents with "gorilla hair" and body filler. Finally, spray the fenders and apron black with gloss black Rust-O-Leum in a spray gun + compressor to match the paint on the car. Cheap, cheap, cheap but decent results for a "20-footer" finish. Use the same paint to 2-tone your wheels to factory scheme.
The rear bumper blade really needs to be replaced rather than straightened, but you can readily find better examples at VW swap meets like Terryville CT in August. Soak all bolts from the bumper parts with PB-Blaster, then heat them up with a propane torch when removing so that you minimize snapped heads. |
dropped65 Samba Member
Posted: Mon Jul 23, 2007 7:18 pm Post subject: |
well thats with the door half shut also the hinges are tight so it could be that |
69CalLookBeetle Samba Member
Posted: Mon Jul 23, 2007 7:14 pm Post subject: |
Seriously, looks good to me. As far as the front clips go, many beetles need them (including mine). The only concern I would have is the door alignment as was mentioned before. However, maybe the door is just bent. _________________ 1969 Sedan
1962 Sedan |
Posted: Mon Jul 23, 2007 5:36 pm Post subject: |
i lifted parts of the rubber mats and took the battery out and the worst spot i found so far is the battery tray |
dantrefethen Samba Member
Joined: April 28, 2004 Posts: 729 Location: Boise Idaho
Posted: Mon Jul 23, 2007 5:31 pm Post subject: pan |
I would clean the floor up and check the pan real close from ON TOP.
That undercoating can be hiding things.
Dan |
Posted: Mon Jul 23, 2007 5:23 pm Post subject: |
the pan is good someone undercoated it sometime in the mid 70s and the headliner is good for a driver with 2 small rips about 1 inch long |
Posted: Mon Jul 23, 2007 5:21 pm Post subject: |
This really doesn't look all that bad!
The interior is not too bad. Seats look good.
How is the headliner, back seat?
Just new fenders all the way around.
The front clip is bent, but thats not to hard to fix.
Send us pictures of the pan top and bottom
Dan |
Posted: Mon Jul 23, 2007 2:28 pm Post subject: |
Well acording to the vin and the paint it was made in august 1965 |
Posted: Mon Jul 23, 2007 2:20 pm Post subject: |
Even the registration / title doesn't mean a lot sometimes. I had a 68 Mustang a long time ago that was registered as a 67. It was the 333rd 1968 Mustang produced in Mid 1967. I guess it confused the people at the DMV or something. _________________ 1969 Sedan
1962 Sedan |
Posted: Mon Jul 23, 2007 1:29 pm Post subject: |
Posted: Mon Jul 23, 2007 1:28 pm Post subject: |
Posted: Mon Jul 23, 2007 1:26 pm Post subject: |
Posted: Mon Jul 23, 2007 12:00 pm Post subject: |
Ok so i have the car at my house and i did get a previous registration which is the tittle in r.i. and it says the car is a 1965 but the vin #is 116 so it must be a real early 1966 tittled as a 1965 |
JR.LBR Samba Member
Joined: March 07, 2007 Posts: 409 Location: GARDENA,CA
Posted: Mon Jul 23, 2007 11:19 am Post subject: |
decklid. under the hood (spare tire area) motor.. you know.. the usual.. some better interior shots..
etc..
JR.LBR |
Posted: Mon Jul 23, 2007 7:12 am Post subject: |
Ok its 10:15 am locally this car should be home by 12:00 locally what do you guys want for pics |
Posted: Mon Jul 23, 2007 7:09 am Post subject: |
Ya its been in a garage so that saved it from rust. I guess you cant save every car from horrible driving though |
coW Samba Member
Joined: September 21, 2004 Posts: 2096 Location: New England
Posted: Mon Jul 23, 2007 4:40 am Post subject: |
Congrats on the score! That's a great project - I would have snapped that up as well.
It doesn't look in terrible shape, considering it is new England. |
junk4cash Samba Member
Joined: May 30, 2007 Posts: 212 Location: Kansas City, MO
Posted: Sun Jul 22, 2007 10:00 pm Post subject: |
Don't sweat it, I'd rather have a 66 anyway. But then again I'm partial. |
Posted: Sun Jul 22, 2007 8:35 pm Post subject: |
Ya i am not doubtin you guys i will check the vin #s when i get it home tommorow. I already have the horn ring and motor for it now all i need is a 67 tranny if anyone has one localy |
