Birdmanhere Samba Member
Joined: June 03, 2006 Posts: 1054 Location: CANADA EH
Posted: Sun Jul 22, 2007 11:12 am Post subject: limits of stock carb and muffler |
I am looking into getting a freeway flier and i doubt my 1600 dp with 34 pict and stock bus muffler would be able to push it along that well...
My question is what are the limits that a stock 34 pict carb and bus muffler can run?
1776, 1914??
I am looking to build a stronger motor but I do want it to appear to be stockish..
Just something that will be able to cruise well on the highway.
I don't really want to go dual carbs because I have a nice eberspacher i plan on putting in someday. _________________ 66 Bus
71 Bug |
tkelley Samba Member
Joined: January 10, 2006 Posts: 1597 Location: Where Pterodactyls crash and burn...
Posted: Sun Jul 22, 2007 11:23 am Post subject: |
I have a mexi 1600 and a 4.12 freeway flyer (.89 4th).
The engine has a 34pict. Except for the header and muffler,
it's stock.
I drove up to N.C. from S. Florida and cruised at 70-75mph
the whole way, if not faster. The hills weren't great(slowed down) but nothing bad. I was getting between 27-30mpg, this with a loaded down single cab.
Some are going to say a 1600 can't push a freeway flier and will
overheat. I had zero probs and ran cool all the way up. If I
had to change I'd probably opt for a 1776 with a 34pict or 40mm k-dogs.
But the motor has less than 7000 miles so I'm happy for now.
I wouldn't go with anthing bigger than a 1776 with the 34 pict. IMHO
Tom _________________ When the sun doesn't rise, we'll replace it
with an H-bomb explosion or a painted jail cell... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 22, 2007 12:29 pm Post subject: |
Hi Birdmanhere,
Which FF tranny gearing are you thinking of going? We went with a 3.875 R&P, 1964-67 RGBs and .82 fourth. Running a CW cranked SP with slip in 1641 P&Cs. Runs great and after getting all the right parts it stays cool. Not going to win any uphill races against a V-8, but can stay up with the faster semis when climbing.
Have known quite a few volks over the years that have run up to 1776 sized engines, with single carb or even small dual carbs on SP heads. _________________ In Stereo, Where Available! |
Posted: Sun Jul 22, 2007 8:36 pm Post subject: |
I plan on a 3.88 with .82 fourth and big nut boxes.
I will probably try it first with my 1600, maybe add some 1.25 rockers.
If I do go 1776 would it be advisable to keep stock heads and cam? _________________ 66 Bus
71 Bug |
Posted: Sun Jul 22, 2007 9:02 pm Post subject: |
Birdmanhere wrote: |
If I do go 1776 would it be advisable to keep stock heads and cam? |
If you are going to cruise near about 3,000 RPM. Then stick with stock SP heads and cam. Getting anything much more fancy can easily reduce your lower end torque which you need to get moving with. _________________ In Stereo, Where Available! |
Posted: Sun Jul 22, 2007 9:03 pm Post subject: |
Eric&Barb wrote: |
If you are going to cruise near about 3,000 RPM. Then stick with stock SP heads and cam. Getting anything much more fancy can easily reduce your lower end torque which you need to get moving with. |
it is already a 1600 dp _________________ 66 Bus
71 Bug |
Posted: Sun Jul 22, 2007 9:08 pm Post subject: |
it is already a 1600 dp |
That is easy to change!
A friend of our's up here ran a 1776 SP engine with small dual carbs, and was still able to fit in the factory installed Eberspacher. _________________ In Stereo, Where Available! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Sun Jul 22, 2007 9:59 pm Post subject: |
Eric&Barb wrote: |
A friend of our's up here ran a 1776 SP engine with small dual carbs, and was still able to fit in the factory installed Eberspacher. |
Post some pics. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
joe cool Samba Member
Joined: August 20, 2006 Posts: 1259 Location: Yolo County CA
Posted: Sun Jul 22, 2007 11:06 pm Post subject: |
A 1600 will turn a freeway flyer just fine near sea level. Up in the hills and mountains you will find 4th gear to be useless for going uphill, but 3rd gear will work as you expect. A 1776 might be nice, but not essential. You can run a stock muffler, carb and cooling system with the 1776. |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Mon Jul 23, 2007 8:03 am Post subject: |
I ran this for a good while with a stock 1600 sp. It didn't quite have the power to push it, and always ran on the hotter side, but at the same time, it just kept going and going. If you do a mild 1776, you will probably be more than happy with the setup. _________________ -Andrew |
2litre Samba Member
Joined: September 27, 2003 Posts: 23 Location: Bremerton, WA
Posted: Mon Jul 23, 2007 12:07 pm Post subject: |
I recently purchased a 66 D/C with a basically 'stock' 1776 dog house dual port in it.
34 PICT carb, stock valve train, stock oil bath air cleaner, SVDA, heater boxes and a single quite pack extractor exhaust.
It's willing and peppy and never seems to get hot. I shift at 4-4.2K and it feels like it would still make power for another 2-300rpm.
I still have my RGBs and I'm pretty sure I have a 4:37 gearbox. I turn 3500rpm at 55mph, and that's where I cruise.
My buddy has a 67 Deluxe (4:12? w/ RGB) with a 1600 dual port in it and he runs just a touch over 3K at 55mph and so is always running at 60 or better.
Having driven his Deluxe a number of times I feel I could step down from 4:37 down to 4:12 in my D/C without really noticing, but I doubt I could step down to a 3:88 without ill effect.
On level ground it wouldn't really be an issue but on any grade or hill the final drive, even with RGB, may be to tall for anything less than 2 liter torque.
I wouldn't recommend to my buddy that he step down from his 4:12 to a 3:88 for that same reason, unless he was going to run a larger motor as well.
R/
Jim |
Posted: Tue Jul 24, 2007 1:39 pm Post subject: |
Pics? E&B? _________________ Your Vanagon sucks, Stop waving at me.
Spezialist Banned
Posted: Tue Jul 24, 2007 5:26 pm Post subject: |
Was years ago. Do not have any images of the setup. _________________ In Stereo, Where Available! |
ZENAK Samba Member
Posted: Tue Jul 24, 2007 6:00 pm Post subject: |
whats a Eberspacher??... |
Posted: Tue Jul 24, 2007 8:04 pm Post subject: |
ZENAK wrote: |
gas heater.
It mounts to left of the engine _________________ 66 Bus
71 Bug |
Posted: Wed Jul 25, 2007 7:06 am Post subject: |
ZENAK wrote: |
Try the "Search" feature at top of this webpage. Lots of info on that and tons more info on other stuff. _________________ In Stereo, Where Available! |
Posted: Wed Jul 25, 2007 7:27 am Post subject: |
ZENAK Samba Member
Posted: Wed Jul 25, 2007 5:40 pm Post subject: |
oohhhh....i always thought that was the flux capacitor..looks like a jet booster ..and i do use the search button.....- most of the time... ......just lazy i guess |
