Engine tin diagram
pinkiedog64
pinkiedog64 is offline
PostPosted: Sun Jul 22, 2007 8:00 pm    Post subject: Engine tin diagram Reply with quote
Does anyone know where there might be a complete engine tin diagram on the internet or on this site that shows all the engine tins and where they go? I'd like to look at one as I think I may be missing a piece or two. It's for a '69 Beetle with a '75 1600 dp.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jul 22, 2007 8:02 pm    Post subject: Reply with quote
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
harryset
harryset is offline
PostPosted: Mon Jul 23, 2007 10:43 am    Post subject: Reply with quote
I don't believe I've ever seen parts no. 7 or 8 before, for that matter, I've never seen either of those assemblies before.
'72 Standard
Proud owner of a "Hoover Bit"
185 60's up front, Empi disc kit, 2 1/2" drop spindles, 185 65's in back, stock drums.
Sound Deadening by Secondskin
webwalker
webwalker is offline
PostPosted: Mon Jul 23, 2007 11:03 am    Post subject: Reply with quote
These diagrams cover a wide number of years, including much later engines.
North American Member of the Static Motion Club
1977 CE1 Transporter Deluxe
Click to view image
DrDarby
DrDarby is offline
PostPosted: Mon Jul 23, 2007 11:47 am    Post subject: Reply with quote
7 & 8 are the lower cooling tins with flaps for the "stale air" heat exchanger cars up to 1963-1/2
Midwest Autosavers, Inc. Cary, IL
harryset
harryset is offline
PostPosted: Mon Jul 23, 2007 5:23 pm    Post subject: Reply with quote
That's good to know. I thought I was gaining ground on replacing my engine tin, until I saw that particular diagram. My 72 should be ok.
'72 Standard
harryset
harryset is offline
PostPosted: Mon Jul 23, 2007 5:25 pm    Post subject: Reply with quote
Does part no 11 have a matching right hand tin? Is this the pice that the top cylinder tins screw to?
'72 Standard
68Bug-lite
68Bug-lite is offline
PostPosted: Mon Jul 23, 2007 7:04 pm    Post subject: Reply with quote
Yes, and yes...
They vary slightly in appearance, but thats it. The rear breast tin is held by the same screws aswell.
pinkiedog64
PostPosted: Mon Jul 23, 2007 7:31 pm    Post subject: Reply with quote
How important is piece no. 11? I have the piece in the picture above, but not the opposite piece. Will my engine be ok cooling-wise without it?
Thanks,
Stephan
Mr. 010
Glenn is offline
PostPosted: Mon Jul 23, 2007 7:32 pm    Post subject: Reply with quote
They're all important. If they weren't needed the factory would of left them off.
Glenn
pinkiedog64
PostPosted: Mon Jul 23, 2007 7:58 pm    Post subject: Reply with quote
I realize that, but is my engine gonna overheat and fry if I don't have that piece?
Mr. 010
Glenn is offline
PostPosted: Mon Jul 23, 2007 8:00 pm    Post subject: Reply with quote
No... most engines have them missing along with the "Hoover Bit", the flaps and the thermostat.
But is will run cooler and last longer with all that stuff.
Glenn
pinkiedog64
PostPosted: Mon Jul 23, 2007 8:22 pm    Post subject: Reply with quote
Do you know anywhere where I can get this individual piece?
harryset
harryset is offline
PostPosted: Mon Jul 23, 2007 8:56 pm    Post subject: Reply with quote
Mid America has them listed, but not shown, in their engine tin listing. $13.00, 306-104 and 306-105. Wasn't sure where they went until now. Also, try the classifieds here.
'72 Standard
Mr. 010
Glenn is offline
PostPosted: Tue Jul 24, 2007 3:00 am    Post subject: Reply with quote
Swap Meets
Classified
Salvage Yards
Glenn
68Bug-lite
PostPosted: Tue Jul 24, 2007 5:44 am    Post subject: Reply with quote
$10.00 at BFY, thats where I found mine.
http://www.bfyobsoleteparts.com/1964-79-Air-Deflector-Plate---Rear-Cylinder-Tin-p-3679.html
harryset
harryset is offline
PostPosted: Tue Jul 24, 2007 5:42 pm    Post subject: Reply with quote
CURSE YOU!!!
Visited the site and ended up spending $250.
'72 Standard
mikemck
mikemck is offline
PostPosted: Tue Aug 07, 2007 9:56 pm    Post subject: Reply with quote
Where does piece #5 go?
Thanks.
68Bug-lite
PostPosted: Wed Aug 08, 2007 5:49 am    Post subject: Reply with quote
Under the cylinders, muey importante!
You can just see it in this pick, up against the cylinders...
Woreign
Woreign is offline
PostPosted: Wed Aug 08, 2007 6:32 am    Post subject: Reply with quote
What about pieces 44, 49, & 51? It looks like they seal up the heat riser. Do parts 49 & 51 fit inside 44? I found 44 for sale @BFY, but not the others. And part 42, does it seal up the pre-heat hose?
