MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Tue Mar 13, 2018 3:22 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
You need to visit your local hardware store and search YouTube for flaring copper tube. You can't use compression fittings. _________________ ☮️ |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
iiigoiii Samba Member
Joined: January 05, 2008 Posts: 307 Location: Bay Area, CA
Posted: Sun Jul 01, 2018 9:38 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
For all of you concerned about refilling the 1lb bottles, just saw this at REI:
https://www.rei.com/product/113609/flame-king-refillable-propane-cylinder-1-lb
Quote: |
Certified by the DOT as legally and lawfully refillable and transportable |
Looks like it uses heavier-duty hardware meant to take the stress of repeated refills.
Haven't used them myself. Just FYI. _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3802 Location: VA/TN
Posted: Fri Jan 11, 2019 9:41 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
SyncroJoel (I think Ron) posted this on facebook. It's a 1lb canister with a shut off valve and a regulator.
I only use propane for the stove. I was considering doing this instead of buying a heavy tank that I refill every 3 years. Any thoughts on his setup?
_________________ Brandon
Instagram @joannthevan |
jimf909 Samba Member
Posted: Fri Jan 11, 2019 9:59 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
The big news in that post of Ron's is that he's deleting the Propex and replacing it with the inexpensive Chinese diesel heater (he says it'll provide much more heat). There's a new furnace in town.
I believe the two advantages of the green bottle are: less weight and easier refill (just swap out the bottle).
Less weight/more ground clearance is incontrovertible.
The easy refill can be solved with a hose that allows you to fill the oem propane tank with a green bottle.
If less weight/more ground clearance (at the loss of stock setup and years supply of propane) are important then it's a win.
This is a hose I had made to fill the oem tank with a green bottle.
_________________ - Jim
Abscate wrote: |
Posted: Fri Jan 11, 2019 2:29 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
jimf909 wrote: |
Yeah these gas heaters are game changers for sure. Personally I plan on going with a petrol, tapping into the gas tank. I would like weight savings and clearance from removing the factory propane tank.
Also - mine needs to be replaced and if I can save money on doing so would be awesome! Someone needs to make a DIY kit for a clean conversion!
I wonder if I can put my 1lb canister in the driver's seat battery box. It's vented right? _________________ Brandon
baltik Samba Member
Posted: Fri Jan 11, 2019 2:51 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
Another interesting variation could be to replace the gas burners with something that burns diesel and going single fuel for everything... maybe even repurposing the window washing fluid container as a small diesel tank... |
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Sat Jan 12, 2019 7:49 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
jimf909 wrote: |
I believe the two advantages of the green bottle are: less weight and easier refill (just swap out the bottle). |
My only problem with those green canisters (And I use them with my Coleman stove) is that you cannot recycle them. I've got about a dozen spent ones in my shed.
Need someone to shoot them, then if cut in half they can go to the metal recycle bin w/o freaking out the authorities. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Sat Jan 12, 2019 8:43 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
vanagonjr wrote: |
jimf909 wrote: |
Need someone to shoot them, then if cut in half they can go to the metal recycle bin w/o freaking out the authorities. |
Legally refillable propane bottles can be purchased. Home Depot carries the system.
https://www.rei.com/product/113609/flame-king-refi...G9EALw_wcB _________________ - Jim
Abscate wrote: |
drj434343 Samba Member
Joined: January 31, 2016 Posts: 401 Location: Portland, OR
Has anyone found a gasoline burning stove top cooker? I have only been able to locate diesel burning units like the link above.
I can find gasoline air heaters. With a gas stove top, those of us with gas engines could also go single fuel source. |
Posted: Sat Jan 12, 2019 11:52 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
vanagonjr wrote: |
jimf909 wrote: |
I have been refilling mine. I bought caps to provide extra seal because theyre not designed to be refilled. I think i refill it to 75% _________________ Brandon
Posted: Sat Jan 12, 2019 4:53 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
jimf909 wrote: |
I actually looked into these in there past and there was a recall, so ruled them out and have not even given them a thought since.
But all recent reviews look good! I think I'll get 2 to 4 of these and that will carry me through my trips. Thanks for posting! _________________ John - 86 Wolfsburg Westfalia "Weekender"
metropoj Samba Member
Posted: Tue Jan 15, 2019 6:21 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
I don't know if the USA has gone the way of OPD safety valves on their 20lb propane tanks, but up here we have them.
This means we cannot invert our 20lb tanks and get fuel flow to refill these suckers.
I have one old 20lb tank left that doesn't have an OPD value but I'll never get it refilled. _________________ John.
86 TiiCo powered Westy. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Tue Jan 15, 2019 9:14 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
I don't think the OPD valves stop the flow when the tank is upside down. If you think about it, with the tank upside down the float would be in the "down" position and should work until the tank starts to get low. In all the videos of people refilling 1 lb bottles no one seems to be having any issues. |
Posted: Tue Jan 15, 2019 9:24 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
How I refill my 1lb containers.
Put them all in freezer for 30 mins.
Install adapter and bottle to BBQ propane tank.
Flip propane tank upside down, open valve on BBQ tank
I usually let it go for a minute? When I stop hearing gas flow. Not sure if I'm doing that part correctly.
They even make this bad boy
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Tue Jan 15, 2019 9:31 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
I do the same thing Brandon. I will be buying new canisters this year to start with as I do worry about the valves wearing out. This time, I plan on putting a mark on each canister and replacing after 5 or so refills. There is zero science or engineering behind this plan, strictly for my own peace of mind. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Tue Jan 15, 2019 9:46 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
mikemtnbike wrote: |
I do the same thing Brandon. I will be buying new canisters this year to start with as I do worry about the valves wearing out. This time, I plan on putting a mark on each canister and replacing after 5 or so refills. There is zero science or engineering behind this plan, strictly for my own peace of mind. |
I wish you could buy a 6 pack of the 'refillable' kind for cheap.
Here are the brass caps I bought to go on my 'nonrefillable' ones
https://www.amazon.com/gp/product/B06XYPK1GF/ref=oh_aui_search_asin_title?ie=UTF8&psc=1 _________________ Brandon
Posted: Tue Jan 15, 2019 9:57 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
davevickery wrote: |
I don't think the OPD valves stop the flow when the tank is upside down. |
Thanks for adding this. It piqued my interest to find out a little more about the effects of the float in the newer tanks.
According to propane101.com:
OPD Valve Operation
Propane OPD valves operate inside the bottle and are activated as the liquid propane in the cylinder rises to a level that pushes a float upward stopping the flow of gas into the bottle. This action is similar to that of a float valve in a toilet; once the water in the bowl rises to a certain level, the flow of water stops. The OPD valve is only actuated during the filling process, not during operation. In other words, inverting a cylinder will cause an OPD float to actuate but it will not stop the flow of gas out of the cylinder. Why is this important to know? Because the OPD valve is not designed to restrict flow out of the cylinder, it's only designed to stop flow into the cylinder during the filling process. OPD equipped propane cylinders will allow liquid propane into gas lines and hoses if tipped over or inverted. Overfill Prevention Devices are not a safety mechanism used or actuated during cylinder usage.
OPD valves are also designed to only allow propane into and out of the bottle if attached to the appropriate hose end connection. The threads on this type of connection are called ACME threads and are visible on the OPD valve at the point of connection. The ACME threads are easily identified by how much larger and farther apart they are as compared to normal pipe threads. OPD valves will not allow propane out of the bottle if it is not hooked up to anything. This is why turning (opening) an OPD handwheel on an unattached bottle does nothing in terms of letting propane out. Many people think that the bottle is empty but in fact, the cylinder needs to be hooked up to allow any gas out.
I did refill my 1lb tanks, I didn't need to but hated the waste. I also use the brass caps with seals. I had some that leaked after a re-fill, I even had some NEW ones that leaked after only one use that the brass caps help contain. _________________ John.
Abscate Samba Member
Posted: Tue Jan 15, 2019 7:26 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
That safety engineering at its finest. You know which side of the curve you want to be on.
I've had three one pound bottleshVe valve failure in my life. It's quite spectacular. _________________ .ssS! |
