fxr Samba Member
Joined: December 07, 2014 Posts: 2322 Location: Bay area CA
Posted: Tue Jan 15, 2019 8:38 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
I refill 1lb propane 'one-use' tanks on a regular basis.
The danger problem isn't the main valve on top - it's the schrader valve at the side, that has to be pulled opened with a suitable tool (DIY) in order to fill the 1lb tank to 80% quickly and safely. That side valve is r-e-a-l-l-y a one-time use valve. I reckon about 10-15% of my 'old' tanks don't seal properly at that valve once this valve has been woken/broken into use. Use your eyes, nose and ears! _________________ Jim Crowther
Vespa GTS 300 |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Mon Apr 29, 2019 7:04 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
My OG propane tank has finally ran out of propane! I thought it was magical and was never ending!
I'm going to drop my OG tank and switch to the 1lb canisters.
I noticed Syncro Joel used a 1-stage regular and Van/Cafe + RMW both use 2-stage. One post earlier said some states require the two stage. I really like the placement of Joel's. I don't think I can do that with the two stage. Any thoughts?
Marshall
Type: Two Stage
Max. Inlet Pressure: 250 PSI
Inlet Connection: 1/4" FNPT
Outlet Connection: 3/8" FNPT
Exterior Finish: Raw Zinc / Powder Coated
https://www.amazon.com/Marshall-Excelsior-MEGR-295...amp;sr=8-1 _________________ Brandon
Instagram @joannthevan |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Tue Apr 30, 2019 2:11 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
How does the refillable propane canister address the anhydrous vs standard propane issue? _________________ .ssS! |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Thu Aug 08, 2019 6:16 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
My Westy came without the stock propane tank to power the stove. I've looked through this thread and considered a couple of options, then got a wild hair and did a search on the Intertron. This is what I came up with:
1) KIBOW Low Pressure Regulator w/ 2 ft Hose - Type 1 QCC1 (fits 20 lb can)
1) GASPRO 1 lb Propane Adapter
Ready-made, Plug-and-Play. Found on Amazon. Under $20.00 total.
_________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
danfromsyr Samba Member
Posted: Thu Aug 08, 2019 9:04 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
just an FYI, you don't need the adapter if you change the end on the regulator to a 1/4 Male Pipe Thread x 1"-20 Female Throwaway Cylinder Thread Fitting
https://www.google.com/search?q=1/4+Male+Pipe+Thre...ad+Fitting
shadetreemech wrote: |
Abscate wrote: |
vegpedlr Samba Member
Posted: Thu Aug 08, 2019 9:12 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
I got wha I needed at Home Depot. Hooked it up, checked for leaks, works great. Haven’t blown anything up yet. _________________ 1985 Tintop 4 sp GW 2.3 “Connie”
2006 Mk V GTI 2.0 FSI “Penelope” |
Posted: Thu Aug 08, 2019 9:39 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
danfromsyr wrote: |
Good point, Dan.
I wanted to be able to hook up to a 20 lb tank should I get another wild hair.
'01 Volvo V70 T5
Posted: Thu Aug 08, 2019 10:54 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
well yer gunna want a longer hose than that one then.. well maybe not.. hven't tried stuffing a 20# into the sink galley cabinet.
or is your hose hook up on the outside? that'd take a little more work. _________________
Abscate wrote: |
Posted: Thu Aug 08, 2019 11:45 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
fxr wrote: |
The danger problem isn't the main valve on top - it's the schrader valve at the side, that has to be pulled opened with a suitable tool (DIY) in order to fill the 1lb tank to 80% quickly and safely. That side valve is r-e-a-l-l-y a one-time use valve. I reckon about 10-15% of my 'old' tanks don't seal properly at that valve once this valve has been woken/broken into use. Use your eyes, nose and ears! |
The problem is actually the propane in the disposables is anhydrous - by design.
The propane from Bobs Gas for a gas grill is not, and rusts out the refillable.
Thats why its an up to $25,000 fine for transporting refilled disposable Propane bottles.
Arguing "I have done it for years" is failed experiential based logic. _________________ .ssS! |
The_Raven Samba Member
Joined: January 18, 2016 Posts: 13 Location: Nowhere-Stadt
Posted: Mon Dec 02, 2019 2:00 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
For those that might be interested, FlameKing produces a DOT legal refillable 15.4 oz propane bottle and has a kit to allow for refilling from a 20lb cylinder. _________________ 1.7D/5-spd 2WD Doka - 'Heinz'.(Deceased)....Frankensteined out so that others could live. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Mon Dec 02, 2019 10:54 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
Abscate wrote: |
Arguing "I have done it for years" is failed experiential based logic. |
The charge that this is dangerous could be the “failed experiential based logic” or otherwise known as “a guess”.
Another guess is that the $25,000 fine etc is to prevent the creation of “cannister refill exchange businesses” which is completely understandable. It could be a booming business in the “commercial camping” areas because a cannister holds about 75cents of propane yet costs appx $6 each. They’d sell fast for $4 or $5 each.
Current restrictions offer good protection to the one-time-use cannister industry which has a pretty good thing going.
Could “date” your refillables With a sharpie & change them out periodically. Fresh cans are not hard to come by.
And if anyone has a really “old” one, cut it open and post pics of the corrosion inside. I have some old ones with “Bob’s propane” in them for at least 5 years, maybe towards 8 years. But they’re full, and I won’t remember to cut them open when empty. Which I suppose contributes to the “failed experiential based logic” that we got goin’ on here.
Best thing going are the aftermarket caps. They get pretty safe at that point.
It might be sensible to mark the number of times you refilled it on the can & change out for newer cans after 5 or 10 refills. _________________
....KTMs, GasGas, SPOT mtb |
monstersteve Samba Member
Posted: Sat Mar 28, 2020 11:44 am Post subject: Re: Connecting 1lb propane tank to Westy stove |
It puzzles me that a Westy owner who camps would want to ditch the tank the van came with in favor of fiddle-farting around using 1 lb canisters. Even if there isn't a hazard involved in the economy of refilling the canisters from a 5 gal. tank, why hassle with that? My own story with a 1 lb. can was a trip north on 101 to San Francisco. The cupboard where I keep my lantern and some canisters popped open on the highway and a canister or two rolled out. One apparently rolled up to the heater vent on the floor behind the two front seats. Just as I was entering SF I heard a loud "POP" and "HISssss" accompanied by the distinctive aroma of propane. That little side plug had failed when the canister got hot. No place to pull over, so I rolled the windows down quickly and dissipated the propane before anything ignited it. Pretty scary for a minute or so.
The tank on my '83 has performed well for years. Changed the regulator when it pooped out. Easy-peasy.
On my '81, the westy came with an icebox and no stove - no propane. I got a $100 fridge on Craig's list and it fit right in the hole. Figured out the wiring and plumbed it through the factory hole to where the propane tank mounts. Found a Westy tank on Samba for $60 (even had propane in it) and cleaned it up - wire wheeled the rust off and painted it all pretty. Not hard to install at all - basically bolted it on and plumbed it to the fridge, careful to insulate the line from rubbing on metal.
Way cheaper to fill that stock tank up than to buy multiple $6 1 lb canisters that only last a short while. The tank is sturdy and made out of thick metal. The fittings are available. This guy has some of the odder (NLA) stuff you can't get at Volks Cafe (now Rocky Mtn Westy) http://vanagonwestfaliaaccessories.com/ And if you run out in the middle of nowhere, you can use a 1 lb. canister to refill. https://www.thesamba.com/vw/forum/viewtopic.php?t=612317 |
Californio Samba Member
Posted: Sat Mar 28, 2020 12:44 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
It's easy to just bolt on another 3 gallon standard tank on the passenger side, all the bolt holes are there waiting for you.
I did this 10 years ago and just shift back and forth between the two, keeping one valve closed for use as a "spare."
I keep the Dometic on for months that way, use my Propex and stove as needed, never run out even after a few weeks off grid. |
Posted: Sat Mar 28, 2020 4:01 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
When I bought my Westy the stock cylinder had been removed. Rather than bolt a $350 bomb into the crash zone on the Driver's side, I bought the components to adapt the stove to 1 lb. cylinders. I get 'em for $4.99 @ at my local Army Surplus store. Cylinders not in use are stored in my roof top box. The same cylinders fit in my Lil' Buddy heater.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
wagohn Samba Member
Joined: June 24, 2014 Posts: 740 Location: United States
Posted: Mon Apr 20, 2020 6:34 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
Hello all,
Sorry if this is a repeat question, but I ONLY want to use the 1lb bottle for the stove - nothing else. Do I still need a regulator or just an adapter for the canister->stove connection? Anyone have Amazon links for what I need?
Thanks! |
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1086 Location: Atlanta, GA
wagohn Samba Member
Posted: Mon Apr 20, 2020 6:56 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
Thanks!!! |
jimf909 Samba Member
Posted: Mon Apr 20, 2020 6:58 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
wagohn wrote: |
Hello all,
Thanks! |
Yes, you'll still need a regulator. propane in those bottles is at a much higher pressure than the stove can use safely, hence the need for a regulator to regulate the flow of propane from the bottle. Its measured in water column an you want 11" of water column. But no need to do that, just buy the $14 regulator in the post above (unless you really like the science).
https://www.propane101.com/regulators.htm
http://www.leapsecond.com/pages/manometer/ _________________ - Jim
Abscate wrote: |
wagohn Samba Member
Posted: Mon Apr 20, 2020 7:00 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
jimf909 wrote: |
wagohn wrote: |
Hello all,
Thanks! |
Yes, you'll still need a regulator. propane in those bottles is at a much higher pressure than the stove can use safely, hence the need for a regulator to regulate the flow of propane from the bottle. Its measured in water column an you want 11" of water column. But no need to do that, just buy the $14 regulator in the post above (unless you really like the science). |
Will the 2ft version work? My bottle is right under the sink. Thanks. |
Posted: Mon Apr 20, 2020 7:41 pm Post subject: Re: Connecting 1lb propane tank to Westy stove |
It should. I've got mine under the sink. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
