65Westy Samba Member
Joined: February 15, 2005 Posts: 219 Location: Central Ohio
Posted: Tue Jul 24, 2007 6:06 pm Post subject: Wiring question |
I finished re-wiring my car and almost burned it up before it ever got on the road. Shouldn't the black wire to the coil only be hot when the ignition is on or did I wire something wrong?
_________________ Craig
63 Beetle
72 Schnepp XL13 Vintage Formula Vee
72 Caldwell D13 Vintage Formula Vee
71 Super Beetle convertible |
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Tue Jul 24, 2007 7:41 pm Post subject: |
Yes, only when key is on. |
Posted: Wed Jul 25, 2007 2:20 pm Post subject: |
That's what I thought. I've traced and re-traced my wires according to the wiring diagram and the instructions that came with the harness. I don't see where I made any mistakes.
63 Beetle
warcrocop Samba Member
Joined: February 13, 2007 Posts: 81 Location: Laguna Hills, CA
Posted: Wed Jul 25, 2007 4:54 pm Post subject: |
63bug wrote: |
That's what I thought. I've traced and re-traced my wires according to the wiring diagram and the instructions that came with the harness. I don't see where I made any mistakes. |
Your first mistake was not investing in a multimeter before you started to rewire your car. _________________ '56 Oval 36hp
'06 Scion XB 103hp
Total hp of vehicles owned...
139...sweeeet |
beetleboy58 Samba Conquestador
Posted: Wed Jul 25, 2007 5:50 pm Post subject: |
Its simple...the wire from the coil goes directly to the ign.switch. Check to see that the wires are correct at the switch. Also make sure it is the right switch for the car. Use a multimeter or continuity tester on the switch to see that it is working properly. |
Posted: Wed Jul 25, 2007 6:45 pm Post subject: |
I do have a meter. That's how I discovered that the coil wire was hot all the time. I have all the wires run according the original wiring diagram and the directions that came from Wiring Works. It does not show the wire going directly to the ignition switch. I have what I assume to be the correct 4 terminal screw in switch. _________________ Craig
63 Beetle
janerick3 Samba Member
Posted: Wed Jul 25, 2007 7:32 pm Post subject: |
If your replacement harness uses the factory color patterns (some Brazilian ones don't), the black wire from Terminal #15 on the coil should be hooked to the corresponding Terminal #15 on the ignition switch. That terminal should only be hot when the ignition switch is on. The two #30 terminals are hot all the time. The lug with the biggest hole is for the fat (6 mm) red wire coming from the bolt-down solenoid terminal via the main harness. The other #30 terminal is for the 4.5 mm red wire that goes into the dash harness and is connected to a #30 terminal on the headlight switch. The last terminal (#50) is for the 2.5 mm red wire that goes back into the main harness and is connected to the small screw terminal (or spade terminal if a '61 or later starter) on the solenoid. This terminal is only hot with the switch in the "start" position.
Unless your ignition switch is bad or you have a short in your new harness, it appears you've got the black coil wire hooked to the smaller #30 terminal on the ignition switch. _________________ Thanks,
Jan K. |
Posted: Thu Jul 26, 2007 3:14 pm Post subject: |
Thank you, that makes perfect sense. I ran the coil wire directly to terminal 15 instead of to the fuse block and it makes the wire hot only when the key is "on". That is contrary to the original wiring diagram which shows the black coil wire going to the fuse block, but it works! The confusing thing is I have an extra semaphore harness since I have the Euro model and I have to figure out and only use the wires I need. The semaphores still work with the coil wire going directly to #15 on the ignition switch, but now the indicator light on the speedo doesn't light up.
Thanks for your help, _________________ Craig
63 Beetle
