Link Pin Shim vs Camber
chrisflstf
chrisflstf is offline
PostPosted: Wed Jul 25, 2007 9:40 am    Post subject: Link Pin Shim vs Camber Reply with quote
Anybody know how much the camber will change in degrees (or minutes)with the change of one link pin shim?
I'm sitting at -.4 degrees. My offset is 7.24mm. The manual lists 7mm or 7.5mm to calc shims. I'm in the middle. I set the shims for 7mm, now going to set it for 7.5mm, but wondering if one shim will bring it back in?
secr1973
secr1973 is offline
PostPosted: Wed Jul 25, 2007 12:40 pm    Post subject: Reply with quote
Do the math on it. Its a simple right triangle. You have the shim thickness and the distance between the link pins, do some Trig and get the angle.
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Jul 25, 2007 12:43 pm    Post subject: Reply with quote
Assuming link pin spacing of 6" (just my guess) the camber angle will change about 0.4 degrees for each 1mm shim.
hazetguy
hazetguy is offline
PostPosted: Wed Jul 25, 2007 1:05 pm    Post subject: Reply with quote
the stock, factory shims are .5mm thick (each).
thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
secr1973
secr1973 is offline
PostPosted: Wed Jul 25, 2007 1:12 pm    Post subject: Reply with quote
That would come out to be .19 degrees, assuming a 6" distance between link pins and a 0.5 mm shim
KTPhil is offline
PostPosted: Wed Jul 25, 2007 3:05 pm    Post subject: Reply with quote
With a 1/2 mm shim thickness and 6" spacing, I agree with that new figure.
chrisflstf
PostPosted: Wed Jul 25, 2007 3:20 pm    Post subject: Reply with quote
Thanks for the math help! I'll see what happens after I change it.
