davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Mon Jun 10, 2013 11:39 am Post subject: |
I don't like the location or the cramped-ness of the fitting on the propane tank. In wet, muddy or icy conditions it is less than ideal to be down there.
This is what I did. It allows propane to flow in both directions; tank can supply external things, or a portable tank can supply the stove, fridge and furnace. There is a small regulator on the hose going from the portable tank to the port. Going from the van's tank to something hooked up outside, the flow goes through the westy's regulator. Not sure what would happen if connecting the port to an outside appliance that has it's own regulator since there would now be 2 regulators.
Quick disconnect fitting attached to hose made at a propane place, tee'd into one of the lines in the van. |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Mon Jun 10, 2013 5:46 pm Post subject: |
Cool, but what'd you do w/ your water hook up?
tam
davevickery wrote: |
_________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
Posted: Mon Jun 10, 2013 8:37 pm Post subject: |
Oh crap is that what that was Or do you mean how did I seal it off? I just put a cap on the end of the hose, but I could also have capped it at the faucet. The way I did it, the next owner can get a new door and put it back if they want. |
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Sun Jul 21, 2013 5:33 am Post subject: Hose |
Hey folks,
I installed the extend-a-stay fitting about a month ago. I had the tank filled. The problem I am having is that my coleman stove lights up and runs great for a minute then the pressure drops. The T fitting is before the regulator.
Someone mentioned drilling out the orifice in the hose. Mention drilling and orifice I get uncomfortable!
Any other hints?
Brian _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
Posted: Tue Aug 27, 2013 7:22 pm Post subject: |
Well that didn't happen before my July trip! LOL
See it's still on sale, is it the 66-8812 one that you guys used that worked? If I get on this now, maybe it'll be done by next summer.
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
Altoona Samba Member
Posted: Tue Aug 27, 2013 8:13 pm Post subject: |
Not sure what would happen if connecting the port to an outside appliance that has it's own regulator since there would now be 2 regulators. |
You could just T in before the regulator. Any external tank would be regulated when using internal appliances. Any camping appliances like bbq's or lanterns that would be run off of the westy tank are already internally regulated as they are designed to run off of unregulated external tanks. |
