OvalTeenAZ Samba Member
Posted: Thu Mar 19, 2009 12:38 pm Post subject: |
So since "17wheels" no longer sells these who does??
I searched in the classifieds and nothing.... |
Ace Samba Member
Posted: Thu Mar 19, 2009 1:18 pm Post subject: |
They are out of stock. The add will re-appear when there is new stock. |
BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 833 Location: KANSAS toto's fire hydrant
Posted: Mon Mar 30, 2009 6:46 pm Post subject: |
Ace wrote: |
Hey, has anyone that owns these wheels ever think about buying one extra for a spare or if the unthinkable dent or breakage happens? I was thinking about this the other day, and thought it would be nice to have an extra set around in case production cease's and no longer available _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
silberwagen Samba Member
Joined: July 26, 2006 Posts: 21 Location: Pennsylvania
Posted: Wed Apr 01, 2009 9:00 am Post subject: |
We asked about this when we bought our set. At that time they were only selling complete sets. |
jeff kyle Samba Member
Posted: Sat Jan 02, 2010 2:18 pm Post subject: More Escra.. |
Some pics of my '55 project with 17" Raders.
The pan is a '61.
Tires are Yokohama S. Drive.Discount Tire did me right.
225-50-17 rear...the engine has a 200hp tune,so skinnies are out.
195-40-17 front...low,but wide enough to have grip.
Swing axles are '67.They leave about 3/4" between the tire and swing plate.
Front beam is a new 4" narrower link pin w/2 1/2 drop spindles,Chop Shop Aluminum tie rods.
I have the '55 body on it to check clearances.
airevo wheels Samba Member
Get Mad Now Samba Member
Posted: Wed Mar 31, 2010 11:56 am Post subject: |
Finally putting it all back together
_________________ 64 Beetle |
Posted: Wed Mar 31, 2010 2:24 pm Post subject: |
Get Mad Now wrote: |
Man thats orange, very nice. Could you show a side view? I like it _________________ I know you would understand what I'm saying if you could just see my HANDS
1963 15 window bus
1966 VW bug
1969 Dune Buggy
1965 VW bug
1974 VW bug
Posted: Wed Mar 31, 2010 5:34 pm Post subject: |
The front is a lil high because the hood and gas tank isnt in there.
vic Samba Member
Joined: August 31, 2005 Posts: 1669 Location: Fontana, Califas
Posted: Wed Mar 31, 2010 5:40 pm Post subject: |
heres my buddies car,
has 5.5 narrowed air beam, (no drop spindles in pic but they are now installed) stock drum brakes for now
1 inch wider empi rear disc brake kit on a short axle, airride also
it clears everything fine when aired up but the wheel rubs on the shock tower right by the body mount when aired down, im guessing extending the spring plates as its pitching the wheel forward when aired down
_________________ The Original German Folks! |
Posted: Tue Apr 13, 2010 8:11 pm Post subject: |
I know someone is goin to say something negative about the clear tailights, but its my bug and i like them.
[/img] _________________ 64 Beetle |
huff diesel Samba Member
Joined: February 01, 2009 Posts: 11 Location: Church Hill
Posted: Fri Apr 23, 2010 10:15 am Post subject: |
I just got my wheels in today. Opened them and one had a very bad blemish and emailed Juan. He is sending me a new rim today. Cant beat this guys customer service. |
Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Thu Oct 21, 2010 7:59 pm Post subject: |
mock up for now, its headed for the body shop. i think she'll be running 17" smoothies when it comes out though
_________________ its not about what you say you will do oneday, its what you do today that actualy means something. |
PASHN8 Samba Member
Joined: January 30, 2011 Posts: 152 Location: Melbourne, Australia
Posted: Mon Jan 31, 2011 9:25 pm Post subject: |
Ace wrote: |
I have my fronts on but my rear is still on stock white walls. Here are some options:
2 of the 3/8 spacers stacked with long lug bolts
1 inch spacers with long bolts
Convert to 67 axles and brakes finding old parts
Convert to 68 axles with compatible wide 5 drums with all new parts
Convert to 1 inch wider rear disc brake kit (ac industries?)
Convert to 68 axles with aftermarket wide 5 disc conversion (ac industries, cb etc)
If anyone has another option, feel free to tack it onto the list
I refuse to put down running a bus tranny with redux boxes |
Hi guys,
Great thread which I have read from start to finish with some fantastic info!
I have a '59 Beetle with original drums and have just taken delivery of a set of Escra's. Trial fit indicated the usual touching of spring plates in the rear, front is ok for now with standard gear.
On order:
4.5" narrowed beam with 2.5" drop spindles.
Can anyone confirm how much the CB front wide 5 dropped disc kit will increase the FRONT track? Will they be ok with the Escra's? I won't be running crazy low, but low enough
For the rear, i've heard that the '67 axles will give you around 1 inch increase in rear track? What I want to know is, can I just do a swap for the 67' long axles with short splines and re-use my standard 1200 beetle rear drums and need nothing else?
If not, which rear wide 5 disc kit will give me the clearance I need? Rear escras as running 205/45/ZR17 tyres for reference.
Any help appreciated! _________________ www.dinography.com.au - Dino!
1957 11-Window Split Bus
1954 3-fold Sunroof Oval Beetle
*** Looking for '56 Porsche T1 356A 1300 engine no. 22373 *** |
bfrancis972 Samba Member
Posted: Tue Feb 01, 2011 12:29 pm Post subject: |
Anyone know where I can get a set of these in the states? Also what tire should I run in the rear of my 67 vert? Its dropped 2.75 inches. I was thinking 215/45/17? or 225/45/17? Which would be best? I am running 205/40/17 up front. |
PASHN8 Samba Member
Posted: Tue Feb 01, 2011 9:39 pm Post subject: |
Francis, GR Wheels in the US stock them.
Tyre size will depend on your clearance but a 205/45/17 will fit, a 215 maybe.
I think we are looking like the annoying newbies who haven't used the search function
Combined with the fact i've been lurking and not registered for over 5 years and been registered on the AussieVeedubbers forum since 2003, so I can see how i'd look like the annoying newbie!
I've gathered all the info from this thread, just hoping someone can pinpoint the quickest way for me to get that evasive 1" wider rear track _________________ www.dinography.com.au - Dino!
Posted: Tue Feb 01, 2011 10:03 pm Post subject: |
bfrancis972 wrote: |
If ur that low I think u should stick with 205s in the rear. That is what I am running and I am about 1.5 splines down in the rear and the tires rub on the springplate with heavy cornering. I ran short axles with a 1inch spacers at 1st and the rim would sometimes contact the body when cornering. I added empi wide 5 disc in the rear and it added enouch clearance the the rim doesnt touch anymore just the tire. I also run 195/40/17 up front with a 4inch narrowed beam. _________________ 64 Beetle |
PASHN8 Samba Member
Posted: Tue Feb 01, 2011 11:20 pm Post subject: |
GMN,
Thanks for your input. So you are saying that with:
Short Axles
1 inch drum spacers in the rear
Empi wide 5 disc kit rear
205 tyres
You STILL sometimes hit the plates on the inside or the body? How low are you running? Any pics of the car?
From what I can read the CB and Empi rear disc are zero offset if they come with the e-brake, non e-brake kits add an inch each side. _________________ www.dinography.com.au - Dino!
envycustoms Samba Member
Joined: June 20, 2006 Posts: 324 Location: Oakland - Nor*Cal
Posted: Tue Feb 01, 2011 11:24 pm Post subject: |
Heres an ad from GMN showing his car..
Ad number: 1061358 _________________ 56 SunRoof (o\U!U/o) "Hood Fellas"
Damn.. not another car on earlies!
www.EnvyCustoms.Tumblr.com |
PASHN8 Samba Member
Posted: Tue Feb 01, 2011 11:43 pm Post subject: |
Thanks Envy, sensational car GMN!
What is freight to Melbourne, Australia I wonder? _________________ www.dinography.com.au - Dino!
