vwjoe Samba Member
Posted: Sat Aug 04, 2007 1:56 pm Post subject: Hooking up a 2nd Alternator. |
I have a 69 bus the are picture's of the bus, motor and alternator set up under Gallery 68-79 Deluxe. "Back n Black".
2nd alternator has 3 wires on top a red -S, a brown with white stripe-F, and a Brown -L.
How would i hook these wires up to make it work properly?
Alternator is out of an 88 buick or 88 olds or 89-90 pontiac lamans or a 88-94 sunbird.
S is sense wire 12volt wire to battery, F- is feild to CPU. central processing unit don't have that, L is for indicator light. L wire to light, light wire to fuse and fuse to 12 volt switched.
Posted: Sat Aug 04, 2007 5:37 pm Post subject: |
Pretty hefty load on your primary alternator/fan belt. I would be real worried about this causing excess slippage and overheating. |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Sat Aug 04, 2007 8:34 pm Post subject: |
What are you doing with the second alternator? You could have a second battery to run whatever you need so much power for - a kicking stereo I would hope!!! Then have the second alternator charge the second battery?
Just a late Saturday night hunch.. don't put too much merit in it! _________________ '71 Westy |
