vdub Samba Member
Joined: September 07, 2003 Posts: 442 Location: Valley Springs, Ca.
Posted: Mon Aug 06, 2007 1:01 am Post subject: 5 lug drums question? |
Can I run 5 lug drums on a stock 69 square. if so what year drum do I use? |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Mon Aug 06, 2007 1:24 am Post subject: |
yes it CAN be done, but it requires sourcing alot of parts to swap out. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
vdub Samba Member
Posted: Mon Aug 06, 2007 1:40 am Post subject: |
I was hoping to just change the drums because I already have a new pair of shoes for the brakes I have now. |
jimmynotch Samba Member
Joined: February 11, 2003 Posts: 2901 Location: sacramento
Posted: Mon Aug 06, 2007 7:46 am Post subject: |
vdub wrote: |
For the fronts:
You will have to find drum spindles. You will need the backing plates, brake cylinders(two per side), shoes and drums. Also, all the springs, brake lines between cylinders and other bits.... The cylinders are getting very hard to find and very expensive. The drums turn up now and then, but also, getting really expensive. I spent a long time before I found all the stuff for my 65.
For the cost of converting to drums, I would say its not worth it. Especially since the discs are so much better and safer. A way better option would be to check out some of the wide 5 front disc kits that are starting to come available. _________________ Jim in Sacto -
my wonderful loving supportive wife wrote: |
You guys are dorks. |
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2 |
vdub Samba Member
Posted: Mon Aug 06, 2007 8:28 am Post subject: |
I'm not concerned with the front.
I am talking about the rear right now. |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Mon Aug 06, 2007 8:58 am Post subject: |
You can buy the repopped Type 3 rear drums. They are the '64-'65 style. They should be readily available for about $75 a piece at the most. Most of the pieces for the rear shouldn't be all that hard to find, as bus guys use this setup all the time when lowering. _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Aug 07, 2007 3:03 pm Post subject: |
I picked up a full set of front and rear 5 bolt T-3 drums last weekend, with backing plates. The front wheels cylinders look rebuildable. I dod not get any shoes with the rears. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
