Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Fri Jun 16, 2017 7:18 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Has anyone outfitted their bug with Bugwheel.com's 16" slotted wheels? Would love to see some pics. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
stizz Samba Member
Posted: Fri Jun 16, 2017 9:35 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Airride 155/60 fronts. And 195/65 rear on 6 1/2 steelies
_________________ 66 beetle |
alain0790 Samba Member
Posted: Tue Jun 20, 2017 2:20 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hey there , I'd like to ask for some advice if you guys don't mind. My bug has a stock beam and my tires in the front are 205 50 R15. I have an 8 spoke wheel and don't really know the off-set of the rim haha.
I plan on instaling the disk convertion kit with the drop spindle from cip1, I'd like to know if you think the tire would rub ?
Thansk in advance!
Here is a pic of my car
blue65 Samba Member
Joined: March 10, 2016 Posts: 123 Location: Melbourne Australia
Posted: Mon Jul 03, 2017 2:41 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I have a 1965 Beetle (1641cc engine).
I'm using Mangel steel rims 5.5 with Bridgestone tires 195/60 R15 - front and rear.
Tyre Pressure is 22psi front and 24 in the rear. (Update: I changed it to 20psi front and 28psi in the rear and that was an immediate improvement)
The front is slightly lowered by 1 or 2 inches. I'm also using anti-sway bars in the front and rear. An anti-camber bar was installed in the rear recently because it was found that the rear wheels were getting their inside threads worn out. see photo. But that made the ride stiff and uncomfortable going around corners. After a year or so, the handling improved though.
sonoma_vw Samba Member
Joined: May 19, 2013 Posts: 464 Location: Sonoma County
Posted: Mon Jul 03, 2017 10:58 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hi Blue65,
Beautiful stance.
Guessing your brakes are all stock drums still?
As you lowered the front 1-2" with 195/60's, any rubbing?
And has the anti-camber bar improved the ride, aside from wheel life?
Thanks! |
blue65 Samba Member
Posted: Mon Jul 03, 2017 12:13 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
sonoma_vw wrote: |
Hi Blue65,
Beautiful stance.
Thanks! |
Hello. Thank you for your kind remarks.
Yes the brakes are still stock. front and back.
The front is lowered about 1-2 inchs. But it was done so long ago I cannot remember the exact measurement.
The ant-camber compensator stiffen the rear and I disliked it . Because whenever I went around corners it felt like the rear wanted to slide away. No it did not improve the ride. But it made it easier for me to get over humps in the road without scrapping the bottom.
Its been nearly 2 years since they were installed and the handling has improved with age. I also changed my air pressure to 20 front. 27 rear and handling is much better now.
I'm tempted to drop the rear - but my house has a steep driveway and I can't do that.
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Tue Jul 04, 2017 5:03 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
alain0790 wrote: |
Thansk in advance!
Yes I think it will rub. I believe the drop spindles push the wheel out 1/2" and I think the disk brakes push it out another 1/2". With that wide of a tire I believe it will rub. |
CP65chop Samba Member
Posted: Fri Jul 14, 2017 4:20 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hey Everyone... I am hoping to get some help in choosing tire sizes for my project. A little bit of information on the build. 1965 Type 1 with many years of reassembly. Franklin's VW Werks is handling the suspension mods. So forgive me if I leave out a crucial number or fact. As you can see, I would like to use these Jetta 15" X 6" five spoke rims on this car. They are offset 38mm with a 5X100 bolt pattern. I have a 3" adjustable beam up front with adjustable spring plates out back. AirKewld Bad Series Disks around for stoppage. I'm having to have the front rims machined to accept the brake flange, so hopefully that will mount flush. My hope is that you folks will be able to help me find a suitable tire size for front and rear. I don't like the slammed down look, but a nice rake would be my preference. Thank you in advance!
Posted: Fri Jul 14, 2017 5:51 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
CP65chop wrote: |
[i]Hey Everyone... I am hoping to get some help in choosing tire sizes for my project. A little bit of information on the build. 1965 Type 1 with many years of reassembly. Franklin's VW Werks is handling the suspension mods. So forgive me if I leave out a crucial number or fact. As you can see, I would like to use these Jetta 15" X 6" five spoke rims on this car. They are offset 38mm with a 5X100 bolt pattern. I have a 3" adjustable beam up front with adjustable spring plates out back. AirKewld Bad Series Disks around for stoppage. I'm having to have the front rims machined to accept the brake flange, so hopefully that will mount flush. My hope is that you folks will be able to help me find a suitable tire size for front and rear. I don't like the slammed down look, but a nice rake would be my preference. Thank you in advance!
You may have to play around with tire sizes to see what does and doesn't work. I once had 5 spoke Empi knock offs and ran 195/55 in the front and 205/60 on the rear. I wasn't very low though. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
JPro62 Samba Member
Joined: November 04, 2012 Posts: 98 Location: Hamden, CT
Posted: Sat Jul 15, 2017 4:23 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Here's mine.
1962
Front
CB Performance 2 1/2" dropped spindles and 5x130 disc brakes
3.5" narrowed adjustable beam with shock towers
Porsche Space Savers 15x5 1/2"
Dunlap Direzza 195/50/15
Rear
Rare Atomwerks's drop spring plates think 2 1/2"
Spline might be stock? Not sure where previous owner had them with the stock spring plates.
Stock drums with Wide 5 adapter's to 5x130
Porsche space savers 15x5 1/2"
Dunlap SP Sport 600 205/65/15
_________________ 1962 Beetle
1974 Super Beetle (Sold) |
CLEvwLAND Samba Member
Joined: August 01, 2017 Posts: 1 Location: Cleveland, OH
Posted: Tue Aug 01, 2017 9:14 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Here is my 1965 Sea Blue VW Beetle
With the help of this thread, I was able to dial-in my suspension to exactly what I was looking for. This is my first post on TheSamba, so thank you everyone.
Front:
- 2 1/2" drop spindles
- 2" narrowed adjustable beam
- Drum brakes all the way around
- 135's with 2" white wall inserts
Rear:
- Combination of inner and outer splines (basically 2 outer)
- OEM spring plates - not notched
- 165's with 2" white wall inserts
kinkerstinker Samba Member
Posted: Tue Aug 01, 2017 9:52 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Very nice! I need to re post my sea blue 65 since all of my photobucket links died.
Front
-2 inch adjustable beam
-drop spindles
-145r/15
Rear
-3 inch The.Dub.Lab drop plates Indexed to stock degrees according to his thread.
-long axle rear end
-165r/15 |
Posted: Fri Aug 04, 2017 6:01 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Harvey got new shoes.
Front:
Stock height (soon to change)
16x5.5 Bugwheels Outlaw rims
185/55/16
Rear:
Sagging ass
205/60/16
1967 Ghia
oj77 Samba Member
Joined: February 05, 2014 Posts: 2 Location: United Kingdom
Posted: Tue Aug 22, 2017 8:59 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
2 inch narrowed front beam, dropped spindles and standard shocks on 135's
Hmm maybe a couple of splines on the rear (did it a long time ago and forgotten) standard shocks and 165's.
Not especially low but ideal for running about town and the dreaded speed bumps/sleeping policemen.
I found this thread really good when trying to decide on the stance I wanted.
Oh the number plate change is due to DVLA finally finding the correct reg after already issuing an age related plate. |
Posted: Fri Aug 25, 2017 11:10 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Sharp64 wrote: |
Front:
185/55/16
Rear:
Sagging ass
205/60/16
Post lowering. 2.5" spindles and 2" narrowed adjustable beam.
1967 Ghia
Bulliwinkle Samba Member
Joined: July 30, 2013 Posts: 118 Location: Wheat Ridge, CO
Posted: Fri Aug 25, 2017 11:25 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Sharp64 wrote: |
Nailed it! _________________ Darel
'66 Velvet Green Riviera Camper
'72 Sierra Yellow Westy
'71 Chianti Red Westy ~Sold
'71 Pastel White Westy ~Sold
'61 Pearl White Sedan ~Sold
johnnypan wrote:
"John Muir was a hack mechanic who convinced thousands of people to attempt repairs they had no business attempting". |
Posted: Fri Aug 25, 2017 11:27 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Ancient Mariner wrote: |
Sharp64 wrote: |
Nailed it! |
Thank you. Now if I can just get it to track correctly and its all good to go. lol. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
apozzo Samba Member
Posted: Sat Jan 06, 2018 2:11 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hi guys!
I’m Stefano and I’m from Italy.
Last year I’ve finally succeded to realize my dream: I’ve bought a 1966 beetle!
The original idea was to make an exterior upgrade...I’ve worked hard for 6 mounths: I’ve changed the front beam, the shock absorbers, the wheels with tyres. I’ve Made the brakes new (New pump, cylinders, pads, tubes), the carb and finally the interior!!! It was not in my project but I was not able to resist!!
However, coming to this thread...
The car now has this stance:
- Front: Sway a way front beam not narrowed with Caster shims. Short KYB Excel G shock absorbers. Original 4j smoothie wheel with Nankang 145/80 r15 tyres. Standard spindles.
- Rear: Dropped one outer spline. Standard shocks. Hand Made 6.5J smoothie wheels with Nankang 205/65 r15 tyres.
This is the “before and now”....
apozzo Samba Member
Posted: Mon Jan 08, 2018 4:05 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Oh no....the photos are too small....
Let me try to repost others...
Posted: Tue Jan 09, 2018 1:53 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Sharp64 wrote: |
Front:
185/55/16
Post lowering, did you have to reduce the tire size in front? Or did you keep the 185/55 ? If you kept em, any rubbing?
Thanks! |
