1966type1 Samba Member
Joined: September 09, 2015 Posts: 129 Location: New hampshire
Posted: Mon Oct 21, 2019 11:16 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Chickensoup wrote: |
1966type1 wrote: |
1966type1 wrote: |
Hello, I just lowered the front of my 1966 beetle. It has a narrowed adjustable beam and 2.5 dropped spindles. Im running stock rims with drum brakes. Tires are 165/80R15. The issue I have is rubbing on the fenders. What is the solution narrower tires? Thanks |
Yes, smaller tires, different offset rims, not using drop spindles, etc. just the little things. |
What size tire would you suggest. Im still learning about tire sizes |
Im no expert either but maybe 145/65/15 at the most. It all depends on your likings. Personally, my tire have got to have lots of meat on em |
So the 145s are narrower than 165s _________________ 1966 beetle sedan "blue bird"
1972 super auto stick
1972 deluxe bay window "big Larry"
1997 Jetta "the red car"
2001 Jetta 1.8 "the blue car" |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Mon Oct 21, 2019 12:00 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Yes. The first number (145) is how wide in millimeters the tire is (roughly, where it is measured varies from manufacturer to manufacturer.). The second number is the aspect ratio, what percentage of the first number the height of the sidewall is (80). So the sidewall height is 80% of the 145, or 116 mm. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
cbdubs Samba Member
Joined: December 13, 2013 Posts: 87 Location: Scarborough UK
Posted: Fri Nov 15, 2019 8:12 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
This is my 58.
Front is lowered using KCW 3.5 narrowed beam. Standard spindles and drum brakes. Fake fuchs 4.5 x 15s. 1.5 adapters to Porsche PCD. Tyres are 145 65.
Rear is 7x15 fake fuchs, standard drum brakes and 1.5 adapters.
suburbanlegend Samba Member
Joined: February 20, 2008 Posts: 41 Location: Arizona
Posted: Sat Nov 16, 2019 8:06 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
SP Bullet wrote: |
1967. Khumo Solus front and rear. 205 65 15 on 6" wide rear and 175 55 15 on 4" wide fronts. Rear is stock height long axle with a little sag. Front is 2 1-2" drop spindles and no adj beam.
Nice. Where are people getting stock look wheels widened? What is the backspacing on the rear widened wheels? I dont read a lot of people talking about backspacing but it seems critical. |
Posted: Sat Nov 16, 2019 8:10 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
SingallZ wrote: |
72 Canadian Standard beetle (back dated fenders, I know, not year correct but I like em )
FRONT
2 Narrowed adjustable ball joint beam
2.5 drop spindles
15X6 Widened rims
195X55X15 tires
Total Drop 3
REAR
Swing axle with Limebug 2 drop adjustable spring plates
15X7 Widened rims
205X55X15 tires
Total drop 2.5 |
I love this one too. What is the backspacing? Disc or drum brakes up front! Where can I get my stock wheels widened? |
Danny604 Samba Member
Joined: October 09, 2019 Posts: 89 Location: Port Coquitlam BC Canada
Posted: Mon Nov 18, 2019 10:31 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
59 Beetle
front:
Previous owner said 2 leaves were taken out of one of the packs
15 x 5.5 gasburners with 145 nankang, wide 5 to 5x130 adapters, stock drums
rear:
stock height
15 x 5.5 gasburners, with 195/65, wide 5 to 5x130 adapters, stock drums
Davidee17 Samba Member
Joined: December 02, 2015 Posts: 2 Location: Sao bernardo Brazil
Posted: Fri Dec 06, 2019 9:25 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
My brazilian 1968 characterized as 1964 vw beetle.
FRONT:6" narrowed beam,14"vw bus wheels 165/60 kumho kh17 solus 75T
REAR: lowered swing axle, 7" wide 15" wheels 185/65 bridgestone 88h turanza er300
walter kandetzki Samba Member
Joined: June 02, 2003 Posts: 918 Location: Dillwyn, VA
Posted: Sat Dec 07, 2019 7:17 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
suburbanlegend wrote: |
SP Bullet wrote: |
my buddy john arkham williams on facebook can do wider steel wheels.he made me 6.5" wide rears.they look like 5.5" and fit perfect under fenders and im still running 68 long axle (68 bug) |
muravr Samba Member
Posted: Mon Jan 27, 2020 2:23 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hello everyone from Italy!
Yesterday I tested my new tires mounted on rear axle, on 6" widened smoothies: Retro Classic 001 (made by Nankang) 165HR15 (165/80R15).
These tires have tread absolutely similar to MIchelin XVS. Available also in 155R15 and 185R15 sizes.
Stumpjumper19 Samba Member
Posted: Sat Feb 01, 2020 9:35 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I have 185/60/R15 front
With 205/60/R15 on the rear.
Bug is stock room for bigger rear tires.
What size do you think I can go on the rear if I go bigger and tad wider?
My bug below Im considering changing rims to a black smoothie with center chrome dome or a all black raider with a red line around edge.
Posted: Sat Feb 01, 2020 9:51 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Few options Im considering.
Andrzej Samba Member
Joined: March 06, 2020 Posts: 1 Location: Northern Ireland
Posted: Fri Mar 06, 2020 8:39 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Current Set
rear 2 outer splines and 15" 6.5J with 185/65 tyres
front adjustable beam with standard spindles and 15" 4.5J with 145/65 tyres
toxicavenger70 Samba Member
Posted: Tue Apr 07, 2020 8:05 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
We need some new tires on the ride. I wanted to stick with as close to stock as I could. I ordered some Nankang CX668 Low Noise tires from Discount Tire Direct. They were $50 a piece.
I have to say combined with an alignment it is rolling really good. I might need to lower the air pressure to get it riding a little smoother.
I will try and remember to do a longevity report on them. |
grenadeAcorn Samba Member
Posted: Thu Apr 09, 2020 8:12 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
muravr wrote: |
Love these tires! |
DonHomer Samba Member
Posted: Tue May 19, 2020 6:24 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
1970 Standard
FRONT:
Stock beam
EMPI disc brake conversion with 2.5" drop spindle
15 X 4-1/2 INCH ( 4-1/2 INCH BACK SPACING) Wheel
KYB KG4520 Gas-A-Just shocks
155/60 R15 Continental ContiProContact Tire
Rear:
Stock drums
Lowered 2 splines on stock IRS
15 X 5-1/2 INCH (4-1/4 INCH BACK SPACING) wheel
Air shocks(Monroe Max-Air Rear Shocks?) with bike valve for adjustment
195/65 R15 Continental ContiProContact Tire
Pros: Looks great, and I love the look of the additional backspacing on the rear wheel in addition to the wider tire. The air shocks are a great(and cheap) way to get an inch or so of adjustment.
What would I have done different: I would have replaced the 50 year old front shocks before buying front tires.
After I did the front brakes/drop spindle the stock tires were rubbing so I went with the 155/60 tire. After replacing the shocks with the new KYB units it raised the front end up well over an inch, and now the fender gaps are not even. They will settle in over time, so not really a big deal.
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Tue May 19, 2020 8:15 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
New shocks will not raise a car. And especially not an inch. Maybe the shocks are bottomed out and keeping the car from sitting lower. _________________ If you`re going to do something, do it right. |
jjwdesign Samba Member
Joined: November 10, 2009 Posts: 4 Location: Orlando, FL
Posted: Tue Jun 23, 2020 4:15 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Tire Suggestions Please:
I have a '74 (regular/standard) Beetle
Stock front beam
2.5 EMPI drop spindles with disc breaks
Rear dropped 1 outer spline; approx 2.3
I have some new EMPI style 8 spoke 5.5 x 15 wheels I would like to use. 4.6 backspacing.
Right now the level is fairly good. I'm not into extreme low riders. I'd like to keep the vehicle level if possible. I don't care for tiny wheels or tires.
I was thinking of using 175/55R15's on the front and keep my 195/65R15's on the rear.
Posted: Wed Jun 24, 2020 7:22 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I think you'll be fine with 175/55R15's on the front, I may move mine from the rear to the front and buy another set of 15 X 5-1/2 INCH (4-1/4 INCH BACK SPACING) wheels for the back.
Looking at mine it looks like there is plenty of room for 195/65R15's on the rear.
Post pics when you are done, I'd love to see it! |
bigryanh Samba Member
Posted: Tue Jul 07, 2020 8:09 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Stumpjumper19 wrote: |
I am running 185/65R15 in the front and 205/70R15
Posted: Wed Jul 08, 2020 2:11 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I couldn't tell you, if yours is stock and mine is lowered the difference is pretty noticeable, sorry |
