mabbo Samba Member
Joined: October 13, 2004 Posts: 216 Location: United Kingdom
Posted: Thu Mar 20, 2025 3:33 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
4" beam with dropped spindles
2" adjustable spring plates
135r15 Michelin ZX front tyres
165r15 Michelin XZX rear tyres
Stock wheels with period trims / beauty rings. _________________ Retro Restoration
West Midlands, UK
www.retro-resto.co.uk
See more of our work here:
www.instagram.com/retrorestoration
www.facebook.com/retrorestos |
sparkle_0 Samba Member
Posted: Sat Mar 29, 2025 11:03 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
1969
Front
2.5" Spindles
15x4.5 type 3 steels (+46? Offset)
165 65r15
Rear
+5/-5
Stock 15x4
165 80r15
Want to go slightly wider in the rear and fill guards. May either widen a spare pair or purchase a set of 5.5s (however it seems they have more positive offset than stock?) Any ideas on what fits with long axles? |
krahulec Samba Member
Joined: March 15, 2024 Posts: 8 Location: Ashburn, VA
Posted: Thu Apr 03, 2025 6:49 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
1967 Agate Metallic Grey
Suspension:
CoolRydes Customs (CRC) True Performance T-1 Front Mendeola Suspension Kit Stock Width w Red Coilover Springs, and 2.5” drop spindles
CoolRydes Customs (CRC) True Track Rear Suspension Kit – Narrowed 1.25 per side
CoolRydes Customs (CRC) CoolStop 11” Cross-Drilled 5x130MM Disc Brakes w Wilwood 4 Piston Red Calipers
Double U-Joint Steering Shaft
Wheels
Schott RAIL Cover-Loc Wheels
bolt pattern - 5 on 130, studs 14x1.5
Fronts - 17”x7”, +40mm offset
Rears - 17”x8”, +40mm offset
Tires
Firestone Firehawk Indy 500
Front 205/40R17
Rear 215/45R17
FRANKR Samba Member
Joined: September 20, 2005 Posts: 6 Location: Orange County, CA.
Posted: Wed May 14, 2025 7:00 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
6" narrowed beam, 2 1/2 drop spindles, rear adjustable 3" drop plates. disc brakes all around. |
TastyTuner Samba Member
Joined: March 11, 2010 Posts: 122 Location: Tulsa, OK
Posted: Tue May 20, 2025 3:37 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
FRANKR
Beetle looks great! Perfect stance _________________ TastyGarage |
shanered Samba Member
Posted: Mon Jun 02, 2025 8:39 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
| MrGoodtunes wrote: |
| type4split wrote: |
| ... 90 degree off?? |
Look at how the adjusters are oriented; they're about 90° different from one another. |
4 more articulation without bottom adjj interference with pan head |
Junkbone Samba Member
Posted: Thu Jun 19, 2025 4:30 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Just wanted to post up my 63. I have a 5 inch shockless beam from Sam at Valley autowerks, 2.5 drop spindles on drums. The fronts are 5.5 smoothies from JBugs with Conti 145/65R15. The rear is just a combination of inner and outer splines to get me where I wanted. Honestly I went up and down so many times I stopped counting and just worried more about degrees. The rears are 7 wide smoothies from US wheel. They have 4.25 backspacing and are pretty tight on the inside and may need to massage the body mount to clear when hitting bumps. I was hoping they would fill the fender a bit better. Stock swing plates with no notching. Tires are Ironman 205/60R15 and like I said they just clear the body mount.
slayer61 Samba Member
Posted: Thu Jun 19, 2025 4:38 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I like it.  _________________
| Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
| 67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo (pending)
Tim's stage II turbo heads (pending)
MSD Box and distributor
Car Craft turbo header |
muravr Samba Member
Posted: Thu Jul 03, 2025 2:32 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hi there, news for my MY63 with adjustable front beam
Front with original 4” smoothies and Retro Classic 001 155/80
Rear with John Brown Wheels widened smoothies 5,5” and Retro Classic 001 165/80
OtisGore Samba Member
Joined: April 21, 2019 Posts: 37 Location: South Africa
Posted: Wed Oct 01, 2025 6:33 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
215/65/15 in the rear
165/60/15 in the front
...wrapped around 5.5J BRM repros
_________________ '67 Euro Sedan - almost completed
www.instagram.com/odysseygarage
www.odysseygarage.com
Odyssey Garage - "The Odyssey Continues" |
Apostle_ Samba Member
Posted: Wed Oct 01, 2025 8:36 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
| Beautiful! |
Posted: Wed Oct 01, 2025 8:43 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
| OtisGore wrote: |
Gawd that's badass! Very cool  _________________
| Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Posted: Thu Oct 02, 2025 7:23 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
| slayer61 wrote: |
Gawd that's badass! Very cool  |
thanks man
this is my first attempt at building a car.... i had ZERO experience in any of the disciplines involved, and I did 100% of the work myself.
I stripped everything to bare metal, pan off, every original bolt and nut re-plated, etc....it took me 3 years of working every single day (after my day job).
I'm so happy with the result I could scream
mgs64ragtop Samba Member
Posted: Sat Oct 18, 2025 9:15 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
| Junkbone wrote: |
So i just bought and received the same US Wheel 15x7 for the rear for my 64. Assume yours are the +6 offest as well. I plan on running a 195/65R15 tire, also will be on air ride. Just not hoping for the wheel and tire to stick out to much. but looking at your photos looks like it sit pretty flush with the fenders |
zodlaw Samba Member
Joined: July 27, 2005 Posts: 581 Location: Battle Ground, Wa.
Posted: Thu Nov 20, 2025 12:30 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
anyone using stiffer torsion bars in the rear? I prefer a stiffer ride and am considering 29mm or 30mm bars. I currently have upgraded 25mm bars and it still doesnt ride like I want. Thanks! _________________ TastyGarage |
Flozwo Samba Member
Joined: March 30, 2022 Posts: 2 Location: Germany Osnabrück
Posted: Tue Nov 25, 2025 10:52 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
1962 Ragtop
Front:
135/70 15
4.5 x 15 Fuchs
5 Inch narrowed beam
Cup Brace
KYB Shocks
Disc Brake
Back:
205/65 15
5.5 x 15 Fuchs
30mm Spacer per side
Koni red
Adjustable springplates with Porsche excenter
Greetz from Emsland Germany |
