jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Mon Aug 13, 2007 5:21 pm Post subject: Engine warrantys |
does a engine warrenty transfer to a new owner?
Motor has a 1 year 12,000 mile warrenty. I bought the car the motor is now only 6 months old with less than 2,000 miles. should the builder honor the warrenty? _________________ www.cultwagen.com |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76946 Location: Sneaking up behind you
Posted: Mon Aug 13, 2007 5:23 pm Post subject: |
Paper warranty's are worthless. Unless the builder is local you'll have to remove and ship the engine to get it fixed. And that's never covered. _________________ Glenn
Member #1009
#BlueSquare |
efi67vw Samba Member
Joined: March 13, 2004 Posts: 558 Location: las vegas, nv usa
Posted: Mon Aug 13, 2007 6:14 pm Post subject: |
builder is local. motor already is about to freeze up. _________________ www.cultwagen.com |
SRP1 Samba Member
Posted: Mon Aug 13, 2007 6:33 pm Post subject: |
jroymcd wrote: |
builder is local. motor already is about to freeze up. |
I'm sorry that just does not make sense. Can you explain maybe you have something else going on. |
Posted: Mon Aug 13, 2007 6:39 pm Post subject: |
SRP1 wrote: |
jroymcd wrote: |
I bought the car from a guy that just had the engine built localy. It was only 2 months old when i got it. now the motor is about to blow up. its now only 6 months old. The motor came with a 1 year warrenty. _________________ www.cultwagen.com |
Glenn Mr. 010
Posted: Mon Aug 13, 2007 7:12 pm Post subject: |
How do you know it's going to blow up? _________________ Glenn
Member #1009
#BlueSquare |
SkrapMetal Samba Hornblaster
Joined: January 18, 2006 Posts: 2558 Location: Dallas, TX
Posted: Mon Aug 13, 2007 7:16 pm Post subject: |
Glenn wrote: |
How do you know it's going to blow up? |
Maybe it's ticking... _________________ oo9less since 2007
-72 Ghia- |
Glenn Mr. 010
SkrapMetal wrote: |
Glenn wrote: |
Maybe it's ticking... |
Then adjust the valves. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Aug 13, 2007 7:23 pm Post subject: |
it seems like the cam drive gear is loose on the crank. there is 1/4 inch slop when you turn the bottom pulley in the direction that the motor turns. keyway in crank is good. it does not seem to be end play. _________________ www.cultwagen.com |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Mon Aug 13, 2007 8:12 pm Post subject: |
could it be a beatup keyway in the pulley?
im not sure i follow on how you assume its going to "blow up"
maybe its just cos ive had a few drinks. though.
either way id contact the builder and have a talk with them see if they will look it over for you, afterall he / she did build it and should know that motor better than anyone else _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
propflux01 Samba Member
Joined: June 03, 2006 Posts: 501 Location: Central Arkansastan
Posted: Tue Aug 14, 2007 6:03 am Post subject: |
If you still have contact with the previous owner, talk him into taking it down there and you paying for any kinda 'extra's, while his name gets the warranty work taken care of. The builder never has to know who actually owns the car... |
