dreadlocks Samba Member
Posted: Mon Aug 13, 2012 7:43 pm Post subject: |
If you have a working TSII id wire a double throw relay up to it, NC to the TS2 & NO to the Pot.. Then put a switch next to pot, flip it on to shut off the TS2 and go manual...
I have a Wideband o2 on mine and this does seem worthy of exploring; I know exactly what my AFR is.
-R _________________ 2013 4dr Golf TDI w/Technology & Tow pkg
2001 GTI - 3.0L VR6 Turbo
1975 Westfalia - 2.0L Fuel Injected |
johnlynch47 Samba Member
Joined: July 17, 2008 Posts: 270 Location: Bradenton, Fl
Posted: Thu Aug 16, 2012 10:14 am Post subject: |
I tried to replace the sensor and it broke off, and I just didnt want to pull the motor (yet) to fix it. So I am bypassing it with the switch, just to follow up, before I knew the sensor was bad I tried to adjust the throttle. I then discovered the sensor was bad, figured out this switch, it started and ran great like I said at 2500ohms. I then was driving home and remembered the throttle adjust, so I made sure it had warmed up then set the swictch to 50 ohms (ran terribly) adjusted the trottle so it ran nice, now it works like a champ. Im going to drive it for a bit to see if there are any other problems before I pull the motor (or pay someone to pull it) to get the hole rethreaded (easy out did not work) and anything else that needs fixin. so there ya go. anything you feel like im missing? _________________ "My shovel is sharp, my pick is sharp, and my will is outstanding." - Rod Marinelli
"I've got a good heart, but this heart can get ugly" Rapper DMX
"Bring your face over here so I can smack it" My Mom
1977 Sage Green Westy up in this!
her name is Velma
1994 Chevy Silverado - Mater
2006 Kia Sedona - Pearl |
Posted: Thu Aug 16, 2012 10:29 am Post subject: |
johnlynch47 wrote: |
I tried to replace the sensor and it broke off, and I just didnt want to pull the motor (yet) to fix it. So I am bypassing it with the switch, just to follow up, before I knew the sensor was bad I tried to adjust the throttle. I then discovered the sensor was bad, figured out this switch, it started and ran great like I said at 2500ohms. I then was driving home and remembered the throttle adjust, so I made sure it had warmed up then set the swictch to 50 ohms (ran terribly) adjusted the trottle so it ran nice, now it works like a champ. Im going to drive it for a bit to see if there are any other problems before I pull the motor (or pay someone to pull it) to get the hole rethreaded (easy out did not work) and anything else that needs fixin. so there ya go. anything you feel like im missing? |
You can easily drill and tap the hole on the #4 cylinder with the engine in place. The function will be the same. You may already have a hole on the #2 cylinder, it will work as well. |
Posted: Thu Aug 16, 2012 11:32 am Post subject: |
REALLLYYYY?! Are there any dementions forth coming? or am I to eyeball it? Anyone have pics? _________________ "My shovel is sharp, my pick is sharp, and my will is outstanding." - Rod Marinelli
her name is Velma
Posted: Thu Aug 16, 2012 12:36 pm Post subject: |
REALLLYYYY?! Are there any dementions forth coming? or am I to eyeball it? Anyone have pics? |
You just need to remove the screw that holds the tin down on #4 and drill and tap the hole for a 10mm x 1 mm bolt thread. |
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Sun Aug 23, 2015 4:47 pm Post subject: |
I know this is an older thread, but I was just recently linked to this thread by Danfromsyr (thanks Dan!). This is a great option for anyone driving an aircooled Vangon, as they are the hottest of the hot!! I have an 81 aircooled vanagon Westy, with California emissions. I have a working temp2, but am unable to reign in CHT. I have tried MANY things, without success. I am going to install this modification with a 5000ohm pot. From radio shack. My plan is to simply unplug the working temp2 and tape up the end. I will attach a wire to the temp2 harness connection and run it to the dash and attach it to the pot. I plan to ground the pot. On one of the open key on the grounding rings under the dash.
My primary question is this, I have a whole reel of 14gauge wire. Will this gauge wire work for this purpose. Also, is my wiring/grounding design feasible? Thanks _________________ 1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground. |
cmonSTART Samba Member
Posted: Sun Aug 23, 2015 5:03 pm Post subject: |
I'm very intrigued by the idea of a manual TSII option. That's right up my alley! _________________ '78 Bus 2.0FI
de K1IGS |
VWinVT Samba Member
Posted: Mon Aug 24, 2015 3:34 am Post subject: Head Temperature Control Knob (manual Temp sensor II) |
Ye olde thread bump.....
VWinVT wrote: |
My primary question is this, I have a whole reel of 14gauge wire. Will this gauge wire work for this purpose. Also, is my wiring/grounding design feasible? Thanks |
sestino Samba Member
Joined: July 03, 2007 Posts: 70 Location: University Park, Maryland
Posted: Thu Jun 16, 2016 12:51 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
I was glad to see this thread on "manual Temp Sensor II being quoted this week in the thread about the scarcity of TS2 replacement parts -- I've been running a potentiometer on my dash for nearly 2 years.
It looks like Radio Shack sells the one I used for $3.49: https://www.radioshack.com/products/radioshack-5k-ohm-linear-taper-potentiometers?variant=5717291205
The potentiometer from Radio Shack goes up to 5,000 ohms and I add in about 1/3 of that into the TS2 circuit during an uphill run (or slightly in advance of the hill) and it can cool my CHT temps by 30 degrees.
I attached the potentiometer under my dash using a small angle bracket I had laying around. I connected it to the TS2 circuit using a piece of 2 strand lamp wire (14 gauge, I think).
I had Colin tune my AFM in 2014 but even after that I found my cylinder head temperatures go over 400 degrees (Dakota Digital gauge) on long uphill grades on the highway. I also have a dash mounted vacuum gauge and my vacuum is always between 17 and 20 inches at idle, my fuel pressure is good, and my timing is good, so using this manual TS2 is the last step of a long process to bring my CHT temps down.
I only resort to using this manual TS2 when I see the temps going over 390 degrees. Having it installed gives me a lot of peace of mind on longer trips. |
SGKent Samba Member
Posted: Thu Jun 16, 2016 2:20 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
anyone with a catalytic converter needs to know this strategy won't work without burning out the catalytic and everything else around it. They turn cherry red when too much unburned fuel goes thru them. Even at 13.3:1 or so at freeway speeds I can see the slight deterioration in mine just in 4500 miles. And that is 18 - 20 MPG. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Thu Jun 16, 2016 5:32 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
You know, a much better solution to all this theorizing is installing a wideband O2 sensor with a gauge, such as the innovate MTX-L. I have one and I've noticed that the fuel/air mix changes with the seasons. I can precisely tune the mix on the AFM to my liking and keep an eye on the mixture all the time. It's the ultimate gauge. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
57babywindow Samba Member
Joined: December 02, 2007 Posts: 1 Location: Coupeville, Washington, USA
Posted: Wed Jan 11, 2017 2:32 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
I just did this on my '75 Bus. Radio Shack 5k ohms potentiometer. It cost me about $4. I used some wire I had in the garage. Tested it at the motor before running it to the dash. Drilled and mounted it next to the headlight switch. It works great. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Jan 12, 2017 6:27 am Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
57babywindow wrote: |
Long time lurked? First post in ten years? Nice! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
airkooledchris Samba Member
Posted: Thu Jan 12, 2017 1:50 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
Run the stock TSII signal up to a switch on the dash, so you can toggle between the stock TSII signal and the potentiometer.
I also run an Innovate MTX-L so I know what the adjustments are doing to the mixture.
In short, I'll run the stock TSII signal most of the time for in town driving, but toggle over to the potentiometer when I hit higher speeds on the highway so I can richen up the mixture.
It really helps identify the ranges in which your motor is happiest when you have the MTX-L to tell you the current mixture while you adjust. You can then adjust the AFM itself to a better middle-ground point, which makes adjustments with the potentiometer much easier. |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Sat May 13, 2017 5:03 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
I'm not much of an electrician, but can follow directions and this just makes sense. I really would stop worrying if I could drop 30 degrees when needed. I see the radio shack potentiometer and will buy the 5k one. Any chance you can share a picture of your setup Chris and also your switch? They're cheap enough, I'll buy them for when Colin shows up, we have this as an option. _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Mon May 15, 2017 9:21 am Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
Gregg in the 603 wrote: |
I'm not much of an electrician, but can follow directions and this just makes sense. I really would stop worrying if I could drop 30 degrees when needed. I see the radio shack potentiometer and will buy the 5k one. Any chance you can share a picture of your setup Chris and also your switch? They're cheap enough, I'll buy them for when Colin shows up, we have this as an option. |
At work at the moment, but I have this I can share. |
Posted: Wed May 17, 2017 4:55 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
Love this, thanks a lot, I'm gonna give it a shot _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Tue Jul 04, 2017 1:54 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
Wow, this thread was a game changer for me. I've been battling high CHT's since a recent rebuild. A visit from Colin helped us address the AFM mixture a little, but like Chris, the temps were still pretty high. I installed the potentiometer under the dash and use it on hills. It is amazing, I haul my loaded bus up hills that before would break 440 degrees. With a little dialing-in, I can get the temps to stay below 410 and even lower if I want. With enough ohms, the temps actually drop on big climbs! I don't use it too much, but wow this is a tremendous relief!
One thing I did notice is that there is a slight loss of power the more you increase the ohms and it richens up. I didn't expect that, but small compromise. It truly expands my bussing abilities! I'm not terrified of big hills and higher speeds.
Thanks for the hook-up on this, I love it.
[/img] _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Tue Jul 04, 2017 1:59 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
Good stuff, thanks for posting your experience with it! I'm considering doing it just to have a "back up" if my ts2 fails. _________________ '78 Bus 2.0FI
de K1IGS |
Posted: Tue Jul 04, 2017 2:14 pm Post subject: Re: Head Temperature Control Knob (manual Temp sensor II) |
Dude, I'm telling you, this thing is AWESOME! I ran up and down 89 at 65mph and saw 410 and lower! You know how 89 can get, those hills are looooooong!
A true horizon-extender this hack is! _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
