J Flare Samba Member
Joined: September 27, 2004 Posts: 309 Location: San Diego
Posted: Sat Aug 18, 2007 8:25 am Post subject: Hard top hardware |
How does a hard top secure to the body?
I just got a hard top but it has no hardware. |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sat Aug 18, 2007 9:48 am Post subject: |
The front edge of the top attaches to the top of the windshield with the same latches that are used on the soft top. The rear of the top attaches with 7 "L" brackets to the inside of the cargo area with bolts that thread into captured nuts. Then, if you have the side supports, they bolts to the inside of the door piller. |
kuebelwagen84 Samba Member
Joined: March 15, 2007 Posts: 144 Location: Edison, NJ
Posted: Sat Aug 18, 2007 10:03 am Post subject: Re: Hard top hardware |
J Flare wrote: |
I have some hard top hardware from my old top available, I can send you pics if you want to see what's involved - I'm at work right now so can't be of any immediate help _________________ // '73 Thing "Jeep Zerstörer" currently being restored / kustomized
// '07 Rabbit taking over daily driver duties
1600s of air-cooled German muscle! |
Posted: Sat Aug 18, 2007 10:51 am Post subject: |
That would be great.
I'm in no hurry |
Posted: Sat Aug 18, 2007 4:45 pm Post subject: |
J Flare wrote: |
I'm in no hurry |
here you go:
Those two beams go from the door pillar and attach to the top, those metal brackets (mine rusted right off my top) should already be attached to your top and you should have 7 or so of them, you need the hood latches (not pictured), and then those bolts and that's it
here's a pic of the top installed before it broke apart:
hope that helps some _________________ // '73 Thing "Jeep Zerstörer" currently being restored / kustomized
Posted: Sat Aug 18, 2007 5:02 pm Post subject: |
Thanks
Are the beams for support in case you put some thing on top or do they need to be in place to keep the fiberglass from flexing?
No metal brackets are attached |
Posted: Sat Aug 18, 2007 5:11 pm Post subject: |
J Flare wrote: |
Thanks
I'd say they're there for both reasons, as for the brackets, mine were riveted right onto the hard top :-/ can't seem to find anyone that sells them online either _________________ // '73 Thing "Jeep Zerstörer" currently being restored / kustomized
Posted: Sat Aug 18, 2007 6:11 pm Post subject: |
The side posts came on the tops sold by the dealerships. The tops sold by other independent vendors did not have them... |
