bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Aug 21, 2007 6:10 am Post subject: Sliding door |
What year Vanagons have the same side slider door as an 84?
I believe I read here awhile back in an unrelated topic (can't remember the topic to search it on) that mentioned a difference in door sizes for the side slider door.
I have a small dent in mine (lower left) that I cannot get to unless I have a body shop weld some rods onto it and pull it out. Perhaps buying a good slider door is cheaper, so I'm trying to find what year(s) are compatable with an 84 Vanagon. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
iceracer Samba Member
Joined: February 28, 2006 Posts: 949 Location: Milwaukee, Wisconsin
Posted: Tue Aug 21, 2007 8:13 am Post subject: |
As far as I know, they are all the same, except for colors. I happen to have a charcoal with silver stripe slider sitting in my garage in very good shape. It came off of a 1987 van. I have been thinking about how to get rid of it but I really don't want to ship it. Wanna pick it up??? _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
Posted: Tue Aug 21, 2007 8:14 am Post subject: |
Forgot, it is in Milwaukee, WI _________________ 86 Syncro Wolfsburg edition
captainpartytime Samba Member
Joined: December 04, 2005 Posts: 715 Location: Mission Viejo, CA
Posted: Tue Aug 21, 2007 8:46 am Post subject: |
I found out at my local pick your part that an 85 vanagon has a different slider door handle/lock mechanism than my 82. Don't know if his helps but it's a start.... _________________ -Kerry
1982 turbo diesel Westfalia |
Posted: Tue Aug 21, 2007 8:55 am Post subject: |
I do believe that '80- early '85 were the same and late '85-up were the same but the two styles are not interchangeable. There was a mid-year change in 1985. I'm not sure exactly where the cut-off was so you would be safe looking for any '80-'84 door. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
camo westy Samba Member
Joined: July 23, 2006 Posts: 400 Location: Madison, Va
Posted: Tue Aug 21, 2007 12:09 pm Post subject: |
The sliding doors are different starting in 1985.
Easy to tell the difference;
Late (post 1985) sliding doors have the latch at the rear of the door. and have rubber flap on the rear of the door frame at the latch.
Early doors through 1984 have the latch on the front of the door, and also the outside door handle is longer.
They do not interchange. (without a welder).
The later doors are an improvement, easier to adjust, close easier, etc. That said the early doors work just fine. |
gt8 Samba Member
Joined: April 15, 2006 Posts: 66 Location: Bothell. WA
Posted: Tue Aug 21, 2007 12:26 pm Post subject: |
camo westy wrote: |
what's involved in swapping doors? i have an 83 and would love a better sliding door. |
Posted: Tue Aug 21, 2007 4:48 pm Post subject: |
The sliders look the same. The latches are totally different. I would not jump on this swap, and I am a project junkie with welding/bodywork skills.
Now the inner rails on the 85 and later vans have the Much Improved curtain hangers... there is a project worth doing. |
