slowesty Samba Member
Joined: May 11, 2006 Posts: 63 Location: San Luis Obispo
Posted: Wed Aug 22, 2007 3:50 pm Post subject: Perfect Gas Can? |
Has anyone found a functional, and by functional I mean storage space, spare gas tank? I need one for a big trip and those 5 gallon military tanks look nice, but how realistic is it for me to lay it down in the storage above the driver seat? If it started leaking.....
http://www.jcwhitney.com/webapp/wcs/stores/servlet...ogId=10101
I did a search here and nothing came up...so, what's everyone using? Any good ideas? Bolting and welding are not options. |
zohami Samba Member
Dogpilot Samba Member
Posted: Wed Aug 22, 2007 4:13 pm Post subject: |
The military style cans were an innovation if you where in the Afrika Corps. THey are lousy by modern standards. Normally cheap one leak, the fillers leak, the slosh gas everywhere and scratch up your paint and rack. Personally I despise them.
Modern times have made a host of plastic ones that actually fit in your luggage rack:
http://www.onlyatv.com/fuelpack.php
The other option is the Volvo gas can that fits in the inner portion of your spare tire. It is round and flat to nestle in there and give you a 4 gallon shot o gas. It is a great place to store stuff, and can hold quite a bit. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Wed Aug 22, 2007 4:19 pm Post subject: |
Funny you mention that, because I am bringing a boat on the trip, and a 6 gallon tank for it. I was planning on mixing the gas for the 2-stroke when I get to my final destination, just in case I need gas for my van on the way down.
Problem is......I plan on using the boat, and the gas, and will need 5 gallons max to feel safe in case the gas stations are out of gas on the way back.
So you are gonna next say bring two marine tanks, which I could do I guess. I've been wanting an extra tank and maybe now is the time to do it...the spout might be a problem with a marine tank though... |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Wed Aug 22, 2007 4:25 pm Post subject: |
Zohami has the same idea that I have used -
When I drove up to Alaska, I took my outboard motors 5 gallon gas tank. Strapped it to the top and used the tanks fuel hose with the rubber bulb pump(with the motor clip cut off) to Cyphen(sp?) fuel down to the tank filler cap with out having to remove the gas can from the rack. Worked great and it doesn't sit as flat as a Jerry can does on it's side, but beggers can't be choosers. I like the idea of the plastic outboard fuel tank, as it wont scratch the luggage rack.
[/i] |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Wed Aug 22, 2007 4:37 pm Post subject: |
So if you're pulling a boat, why not just throw as many gas cans in there as you want? Seems like a no brainer. Go get a couple five gallon plastic cans for a few bucks each if you want the peace of mind. |
Posted: Wed Aug 22, 2007 9:59 pm Post subject: |
I'm not pulling a boat, it's a rolled up zodiac and I'm going way down baja with my wife and kids, so gas fumes inside are an absolute no no.
I like that kolpin fuel cannister. That is exactly why I posted.
Thanks Dogpilot! |
Posted: Wed Aug 22, 2007 11:28 pm Post subject: |
Damn, I forgot about those larger Kolpin fuel packs! They're great. I had two of the Jr packs mounted on my motorcycle for my trip to South America.
Will the large one fit perfectly in the luggage rack? |
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Thu Aug 23, 2007 11:21 am Post subject: |
Both the iBoat and Kolpin packs look like great solutions. I agree that Kelpin might have a better solution ... w/ multiple (smaller capacity) packs, you don't have to be Superman to get the pack up on the luggage rack. I'd rather lift/stack 2-3 3gal. packs than hoist up one 9gal. pack. Plus I can imagine that it's easier to refuel w/ the smaller packs as well.
The only other idea I would suggest is if you're not towing a boat, you could add a luggage box or "grate" to your tail hitch and put your gasoline tanks there.
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Aug 23, 2007 12:24 pm Post subject: |
The Kolpin packs are pretty nice ... I wonder if they would be willing to make custom sizes, to fit perfectly into the Westy lugage tray. |
Taylor L Samba Member
Posted: Sat Aug 25, 2007 9:53 am Post subject: |
That's a nice tank...
And I sure like the idea of having an extra 4 gallons of gas, especially in areas where you can go a long time between stations, like down in Mexico in certain areas.
The only thing that concerns me just a bit, is how hardy is the cap on those things? I'd hate to have it over my head in the luggage rack, and then have the dang thing spring a leak!
-t |
Posted: Sat Aug 25, 2007 5:56 pm Post subject: |
The ones I mounted on the side of my top box of my motorcycle are high quality. Though they were not mounted horizontal they did not leak even while baking in the sun. This is a problem with standard plastic Blitz gas cans, but I think that has to do with nozzle inverted in the can. This leads me to wonder though if the Kolpin is on its side will the cap seep gas while its baking in the sun? Possibly. If it stays cool they would never leak. Though how do you keep it cool while on top of your Westy? Don't know. The biggest thing I don't like Kolpin fuel packs are the price. $80 bucks is a lot for a plastic gas can.
So I am starting to lean back towards a $20-25 outboard motor tank and a fuel hose with priming bulb attached to it to cyphen fuel from the luggage rack to the vans fuel tank cap. |
