Rowroy Samba Member
Joined: November 07, 2006 Posts: 1012 Location: The ass of nowhere
Posted: Mon Aug 27, 2007 12:29 pm Post subject: Is this even remotely possible? (pic inside) |
Is it at all possible to install the front firewall tin (#23) in a '69 Std. Beetle with out removing the engine?
[/url] _________________ Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher |
bhorn Samba Member
Joined: March 28, 2005 Posts: 112 Location: LA (lower alabama)
Posted: Mon Aug 27, 2007 12:41 pm Post subject: |
...you could pull the body off first... _________________ '74 Beetle <-currently
'68 Beetle <- Gone but never forgotten
Quote: |
Now that it's verbed, I'm not sure I can noun it again. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Mon Aug 27, 2007 12:44 pm Post subject: |
I've actually seen it done.
Personally i'd drop the engine first. And you don't even have to take it out from under the car. _________________ Glenn
Member #1009
#BlueSquare |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Mon Aug 27, 2007 12:47 pm Post subject: |
On a non doghouse earlier style it is a bear but possible... not saying it could not be done with doghouse tin but man... Like Glenn says you will actually save time and knuckles/skin just dropping the engine out and down... |
Rowroy Samba Member
Posted: Mon Aug 27, 2007 12:58 pm Post subject: |
Thanks for the quick replies, guys. It looks like I'll be dropping the engine. I can use this opportunity to repair the leaky oil cooler, too. _________________ Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Aug 27, 2007 2:01 pm Post subject: |
If you try it with the engine in the car, it will be helpful to have fingers like a skeleton! _________________ Ghia Owner Emeritus |
DrvwStevo Samba Member
Posted: Mon Aug 27, 2007 4:17 pm Post subject: |
Geeeez Remove the shroud, the carb(s) etc ....FIX the cooler leak AND install the plate(#23). Reassemble it all. Since its screwed in place to the cylinder tins at the backside. And rests over the joint of engine case and tranny....A LOT easier and faster than yanking it all out in my book, especially if its a doghouse cooler.
Good Luck _________________ Those who can, DO. Those who can't, wish they COULD
'68 bug |
MattKab Samba Member
Joined: May 27, 2003 Posts: 26 Location: Warrington UK
Posted: Mon Aug 27, 2007 4:52 pm Post subject: |
Do the job on the trolley jack, half take it out.. _________________ '79 Karmann getting T4i
'70 411 Variant (Black and low)
'89 Polo (parts chaser) |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Mon Aug 27, 2007 5:14 pm Post subject: |
DrvwStevo wrote: |
Good Luck |
it takes less time to drop the engine...especially if you've ever tried to just whip off the shroud(doghouse) with an actual full cooling system...meaning all thermostat and "flaps" assembly with crossrod... quicker to drop the engine then remove the shroud than to do it in the car. _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Mon Aug 27, 2007 7:34 pm Post subject: |
duhhhh too true buginva, I forgot about the cooling flaps and rods. Since I never ran with them (20 years ago) _________________ Those who can, DO. Those who can't, wish they COULD
'68 bug |
