wcfvw69 Samba Purist
Posted: Mon Sep 03, 2007 10:03 am Post subject: TOP 10 causes of break downs in an air cooled VW |
I was out this morning enjoying a beautiful morning in Arizona in my 69 bug convertible. As I was driving down the freeway, I was thinking of what causes the most break downs leaving VW owners on the side of the road to include my own past experiences.
Here is my list not in any specific order- The asterisks indicated what has caused my own breakdowns.
1) Broken fan belt
2) Bad fuel pump *
3) Bad ignition coil *
4) Worn out cap, rotor or points
5) Burnt condenser
6) Broken accelerator cable
7) Seized wheel bearings*
Clogged fuel lines
9) Broken clutch cable
10) Engine failure
What's your list and what has caused your break downs? _________________ Contact me at [email protected]
The Samba member since 2004.
ScottK Samba Member
Joined: August 28, 2004 Posts: 1748 Location: Avilla America
Posted: Mon Sep 03, 2007 10:08 am Post subject: |
I only have 2 so far:
1) Ignition switch. I had a spare with me, so I was able to fix it.
2) Pertronix failed. I didn't have a set of points with me. I walked. |
vwluver74 Samba Member
Joined: February 29, 2004 Posts: 889 Location: at the buffet in the fetus room
Posted: Mon Sep 03, 2007 10:10 am Post subject: |
burnt points
bad master cylinder
sewer lid covers
stripped wingnut on clutch cable |
bugntjw Rants Lurker
Joined: February 11, 2004 Posts: 698 Location: Purgatory
Posted: Mon Sep 03, 2007 10:12 am Post subject: |
2 fuel pumps
clutch cable
accelerater cable
#3 exhaust valve _________________ A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Wow...that was fun!"
Duct tape is like 'The Force'. It has a light side and a dark side, and it holds the universe together. |
2true Samba Member
Posted: Mon Sep 03, 2007 10:13 am Post subject: |
Gremlin.
Seriously a gremlin chewing on something. I get out wiggle some wires and giggle some stufff and it starts back up.
Here he is (with his buddy): |
George Evans Samba Member
Joined: November 18, 2005 Posts: 632 Location: Flowery Branch , Ga
Posted: Mon Sep 03, 2007 10:52 am Post subject: |
1. nut in intake manifold (pre-owner)
2. bad starter
3. old poor wiring |
cal57 Samba Member
Posted: Mon Sep 03, 2007 11:26 am Post subject: |
ear on the t/o bearing fork, bowden tube cracking. The nut that holds the steering wheel. _________________ "never give up"
Iowa Mark Samba Member
Posted: Mon Sep 03, 2007 2:30 pm Post subject: |
Clutch cable
Throttle cable
Fuel pump
Vapor lock
Exhaust valve
Gas tank vent plugged
Generator quit
Belt
Wheel bearing
Drunk owner (a few years ago) |
John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
Posted: Mon Sep 03, 2007 3:09 pm Post subject: |
Pressure Plate Failure.
Distributor dis-engaging.
Condenser failure.
That's about it. So far. _________________
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Mon Sep 03, 2007 3:29 pm Post subject: |
Stopping it unable to be driven:
For me (driving VWs from 1970):
wire to coil shorted out
engine case cracked 10 years after machining for 92mm, and cam plug blew out (that I couldn't fix on the roadside, obviously)
clutch cable broke
one fan belt broke
For girlfriend driving mine:
accelerator cable broke
For wife driving mine:
clutch cable broke
oil pan stud fell out, dumped out all the oil
For mom driving mine:
fan belt broke
generator pulley exploded _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
melville Samba Member
Joined: August 09, 2006 Posts: 1246 Location: Just Outside the Redwood Curtain
Posted: Mon Sep 03, 2007 4:05 pm Post subject: |
1. The owner
2. The owner
3. The owner
4. The owner
5. The owner
6. The owner
7. The owner
8. The owner
9. The previous owner
10. Some miscreant copulating with my fuel filler, pissing in my gas tank. Took a tank drain and several fuel filters to straighten that one out.
Everything else has been my fault in maintenance, design, or usage.
My cars have never been on a tow truck, but I have had to do roadside McGyver shit from time to time.
Later
Mel _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Mon Sep 03, 2007 5:23 pm Post subject: |
1) Vapor lock
2) Broken throttle cable
3) Clamp on battery not tight enough
4) Bad coil
God, what lemons we drive! _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Pedrovolky62 Banned
Joined: August 14, 2007 Posts: 24 Location: Holyoke, MASS
Posted: Mon Sep 03, 2007 5:28 pm Post subject: |
Master Cylinder was my favorite. It went out on a street with a pretty steep grade with a stop sign and a very BZ intersection. I had to get up on the side walk to avoid the car @ stop line.It was bad because I had neglected to fix the e-brake. When I got to the bottom of the hill I dodged an F150 going about 45 and had a 3mile trip home avoid stopping the others werent too bad. Bad Starter. Fuel Pump and accelerator |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Mon Sep 03, 2007 5:29 pm Post subject: |
Bad electrical connections (so I solder every one I repair)
Leaky fuel line (so I replace it every other year)
Stripped spark plug threads (so I use a little anti-sieze)
Battery (so I put in a larger than stock one and new cables)
Wear and eventual overheating (so I put in a doghouse)
Stripped bolts as other repairs are done (so I curse and use anti-sieze on assembly)
Minor oil leaks (so I... I... I learned to live with them)
With regular maintenance, the unexpected failures went way down. These were never "just drive it and forget it" cars; you had to have a look and take care of little mechanical things that will otherwise become big mechanical things.
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Sep 03, 2007 6:09 pm Post subject: |
Poor maintenance. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Mon Sep 03, 2007 6:27 pm Post subject: |
1 bad coil
2 bad points (new, defective, lasted a few miles,)
Ive had crap plug the sock in the tank , but got it home
Had a clutch cable (or 4) break but drove em home without a clutch, once from Yuma to Nogales.
Had the igniton switch go bad, hotwired it and got home.
I dont count stuff that I was able to make it home as leaving me stranded. |
KTPhil Samba Member
Posted: Mon Sep 03, 2007 6:48 pm Post subject: |
Tram wrote: |
Poor maintenance. |
No kidding! With each car purchase I took a few months to discover and undo "repairs" the PO had inflicted on the car. Wrong parts and materials, shoddy workmanship, misdiagnosis... all created more problems! |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Mon Sep 03, 2007 6:56 pm Post subject: |
drive a Type 3 and never worry about #1 again. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
90volts Samba Member
Posted: Mon Sep 03, 2007 7:00 pm Post subject: |
1. accelerator cable
2. bad fuel guage |
Posted: Mon Sep 03, 2007 7:12 pm Post subject: |
KTPhil wrote: |
Tram wrote: |
Poor maintenance. |
I wonder how many of us agree with Tram's statement? Ok, I do too. Of my three issues that caused my car to break down, all were preventable in my mind. Two of the issues where after I bought a new to me bug. I should have been suspicious of the rebuild-able OEM fuel pump and original "small" coil. Obviously the coil is old and who knows the condition of the fuel pump.
The wheel bearing break down was also my fault about 25 years ago when I was learning to work on VW's. I tightened the adjustment nut to remove all the free play= seized wheel bearings.
We have a lot of the same repeat offenders on this list (cables, coils, pumps). What other "issues" have left you on the side of the road? _________________ Contact me at [email protected]
