tk76 Samba Member
Posted: Tue Dec 23, 2008 11:13 pm Post subject: What oil to use on a 2002 1.9L TDI conversion Syncro? |
Hi friends, desperately need some advice on which oil to use. I was told VW'S Quantum 10/40 semi synthetic is best. But will any 10/40 semi do:?: |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Tue Dec 23, 2008 11:16 pm Post subject: |
"5/40 Delvac1" or "Mobil1 5/40 Diesel truck and SUV" or "Mobil1 5/40 Turbo diesel truck", they are all the same oil. Its good for any climate in North America, and is good for at least 7500 miles in TDI in a Vanagon, even one thats 4wd .
Regarding the semi synthetic, don't use it, your TDI requires fully synthetic oil. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
tk76 Samba Member
Posted: Tue Dec 23, 2008 11:19 pm Post subject: |
Thank jack. 5/40 is ok? I'm a newbie when it comes to engines. I wonder what the difference is and why the guy who sold it to me said 10/40...? |
tk76 Samba Member
Posted: Tue Dec 23, 2008 11:22 pm Post subject: |
tk76 wrote: |
and how he was running it usinf semi synthetic |
Posted: Wed Dec 24, 2008 8:49 am Post subject: |
tk76 wrote: |
tk76 wrote: |
5/40 is a bit thinner at cold temp than 10/40.
The engine will run on normal oil, or semi synthetic, or full synthetic, the problem with normal oil/semi synthetic is that it will coke/burn around the top piston ring, then the ring will no longer move freely then the ring won;t seal properly, the compression will drop, it will be harder to start, it will smoke more, etc... _________________
Samba ad here.
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Wed Dec 24, 2008 11:07 am Post subject: |
Shell Rotella Synthetic 5W40
Mobil Delvac 1 Synthetic 5W40
Amsoil makes one too, not sure of the name
Many others but those are the most common. Basically you need a diesel-specific synthetic 5W40 weight, should have CI-4 rating. |
Posted: Wed Dec 24, 2008 11:20 am Post subject: |
Since you are in Cyprus you might want to look for an oil that you can acquire locally. See what the local truck shops are using and maybe follow their lead. |
StealthB4 Samba Member
Posted: Thu Dec 25, 2008 11:22 am Post subject: |
we use rotella t on our tdi and we get about 8-10k between intervals. Not sure if running it on a syncro would change that, but it is great oil! |
