westy81 Samba Member
Joined: July 07, 2007 Posts: 141 Location: Irvine, California
Posted: Wed Sep 05, 2007 11:53 pm Post subject: How much wasser can a wasserleaker leak? (Blinking coolant) |
I recently picked up an 87.5 Wolfsburg for a Subaru engine transplant, but was hoping the 2.1 wasserboxer motor would survive long enough for at least me to gather my parts together for the conversion.
Anyhow - I bought the van knowing it was dripping a bit of coolant, but lately it's been piddling green on a regular basis. More recently (today) the coolant temp gauge dash warning light began to blink, even though the coolant temperature was normal and the coolant level was topped off.
I initially thought the warning light was for temp, but obviously it isn't... which seems to be confirmed by looking through my Bentley on 19.13 and seeing that there's a coolant level warning light switch at the top of the expansion tank.
I'm assuming I've got a bunch of air in my system, and need to bleed it out as per Bentley 19.16 (and keep bleeding it since I'm dropping coolant on a regular basis). Yes? Some decent 2.1L bleeding info can be found at http://www.benplace.com/bleeding.htm. (I guess I could just look at the top of my expansion tank for air, but that would mean I would need to get off the couch, put on my shoes, and go outside with a flashlight.)
Also - any guesses how long I can drive it dropping coolant at a furious rate? (about 1 cup / 250mL every time I fill up with gas.) I'd like to drive it for about 6 months more (as I refresh my Subaru motor, etc) and don't care if the 2.1L is sold for core at the end of it. Maybe it's time to break out the jumbo tubes of JB weld and encase the cylinder head in an epoxy sheath...
I think I'll rig up a little "wasserleaker reservoir" on the outside of my cylinder to catch the coolant (to save groundwater and puppydogs from glycol, etc) or transition to water (I'm located in Southern California).
And this seems to be an error in Bentley: on 19.16, it says "raise vehicle aprox. 10 cm (4 in.) at front" for bleeding. The back should be raised... no?
Any wasserleaker pros out there want to chime in?
Garnet |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Thu Sep 06, 2007 5:19 am Post subject: |
Can't answer the quuestion of how long you can run this engine, but I can addess your final question about raising the front of the Vanagon to bleed. The Bemtley is correct, it's the front that needs to be higher, since the principal bled location is at the top passenger side of your radiator. Elevating the front insures that this is the highest point in the cooling system. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Thu Sep 06, 2007 5:48 am Post subject: |
The contents of the 1.9 liter coolant system is 16.9 quarts according to the Bentley and/or owners manual. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Thu Sep 06, 2007 8:03 am Post subject: vano |
Where is it leaking from? |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Thu Sep 06, 2007 9:47 am Post subject: |
If your pressure cap and the attached hose to the burp tank are intact, there is really no need to bleed it. It will self bleed. Every time it warms up, it will bubble the air into the burp tank. Every time it cools, it will draw in new coolant from the burp tank. A few cycles of this and most of the air is purged.
Unless I changed the radiator, I no longer bother with Bentley's complicated bleeding plan.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Van-go108 Samba Member
Joined: November 23, 2006 Posts: 2995 Location: Southwestern, NM
amishman Samba Member
Joined: March 09, 2004 Posts: 3215 Location: California
Posted: Thu Sep 06, 2007 10:14 am Post subject: |
69doublecab wrote: |
Al |
Really, the Vanagon cooling system is self bleeding where you only need to do it if you say replace a radiator or maybe a hose or something?
tj _________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Thu Sep 06, 2007 11:46 am Post subject: |
i always let it self bleed. but to ensure quicker bleeding, after long drives i will open the bleeder screw on the radiator and let air escape there. do that a couple of times and all is good. been doing that for about 10 years now and have had no problems |
Posted: Thu Sep 06, 2007 12:04 pm Post subject: Re: How much wasser can a wasserleaker leak? (Blinking coola |
.Also - any guesses how long I can drive it dropping coolant at a furious rate? (about 1 cup / 250mL every time I fill up with gas.) I'd like to drive it for about 6 months more (as I refresh my Subaru motor, etc) and don't care if the 2.1L is sold for core at the end of it. Maybe it's time to break out the jumbo tubes of JB weld and encase the cylinder head in an epoxy sheath...
if you decide to knowingly drive it leaking, don't push it as you are already losing a lot of fluid. just keep coolant in the van and don't stray too far from home in case the inevitable happens 6 months is a long time to be limping a long, only takes one good well heated engine to make that system go |
weatherbill Samba Member
Posted: Thu Sep 06, 2007 12:15 pm Post subject: |
I think the bently manual says to air it out by the screw on the thermostat as you raise the front of it. |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Thu Sep 06, 2007 1:24 pm Post subject: |
You can keep driving it, as long as you make sure the high pressure tank doesn't get empty. You can bleed out any air at the same time you check that tank. If the van is warmed up, and you open the lid to check that high pressure tank and it's got air in it, just unscrew that lid SLOWLY, you'll only need about 1/4 turn, and the pressure will force the air out, then tighten it back. The more air is getting into the system, the more often you'll have to do this. When the van is cold you take the high-pressure cap off and fill it up. Important to make sure the reserve tank doesn't go empty of course. I bought a subarood van several months back with blown head gaskets, and drove it cross country this way. Left the rear hatch unlocked so I wouldn't have to turn off the engine, then go back and let out some air. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Thu Sep 06, 2007 7:46 pm Post subject: |
Just an FYI note -
To bleed the system by raising the rear, as recommended by http://www.benplace.com/bleeding.htm works quite well. I just did it today by myself and it was quick and easy. This method makes a lot of sense to me. Water will always equalize itself no matter what it is in, whether it's a garden hose or your cooling system. Air will be displaced by the coolant via the 3 bleeding screws. The trick to it though, is to make sure the lip of your expansion tank is an inch or two higher than the bleed screw on the radiator. When there's coolant coming out of the radiator, plug it, lower the rear and top off the expansion tank and fill reservoir and your essentially done. Drive it a couple of times and let any excess air(mine had none) out of the radiator after each one. First time I did it this way, I was really questioning why VW wants you to do it the harder Bentley way.
With the Bentley method you are actually pumping coolant up hill and if the rpm's drop off for some reason, the coolant will rush back and splash out of the expansion tank. i.e. the water will try to equalize itself. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10077 Location: Abiquiu, NM, USA
Posted: Thu Sep 06, 2007 8:34 pm Post subject: |
What's key with the VW method (raising the front) is to do it cold (thermostat still closed) and rev it at 2000rpm as you add fluid, until it jets out the top. Raising the front gets the radiator lines to the front sloped upward such that there aren't any raised pockets where air can get trapped. Works a wonder every time if you do it right. If the thermostat is open or you don't raise the revs, it doesn't work so good. |
Bambus Samba Member
Posted: Thu Sep 06, 2007 8:44 pm Post subject: Re: How much wasser can a wasserleaker leak? (Blinking coola |
westy81 wrote: |
Anyhow - I bought the van knowing it was dripping a bit of coolant, but lately it's been piddling green on a regular basis. |
"Kitty? Heeeerrre Kitty! Come on, Kitty! Kitty, where are you?!" |
Posted: Sun Sep 09, 2007 10:56 pm Post subject: F I X E D |
Good news... the problem is fixed!
As it turns out, there was a small (1/2" ID, about 5/8" OD) coolant hose that was leaking. The hose connected between a metal tube along the top inside back of the engine compartment (above the license plate door hole) and down along the oil add tube and into the right side of the motor below the alternator and by the water pump.
Thanks to perrib for asking "Where is it leaking from?" - simple but exactly the right question. (And, thanks to lanval http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=106257 my neighbor who gave me his drain pan and a hand during the process.)
I think it is "P" in this diagram:
Anyhow, I replaced the tubing for $4 and am now as good as new with no leaks, no blinkin' light crying out at me, and no more visions of a ridiculously accelerated Subie transplant.
This has been my cheapest Vanagon fix yet... especially compared to my initial thoughts of the motor going and head gaskets leaking, etc. Hopefully the guy I bought the van from also thought that the heads were leaking and never checked it out and just sold it... |
msinabottle Samba Member
Posted: Sun Sep 09, 2007 11:30 pm Post subject: Hurray! |
Hurray!
Congratulations! Look up my post, 'Winston Tries to Give Rob a Heart Attack' for my own version of this story.
Congratulations, you took it calmly, took advice, took action--and prevailed!
Posted: Mon Sep 10, 2007 2:00 pm Post subject: |
Yikes! Mine is metal. Why on earth would something connected to a head running hot coolant through it be made from plastic? |
Posted: Mon Sep 10, 2007 3:07 pm Post subject: |
Why? I dunno, ask them cheap beancounters at VW. The amazing thing is how long the damn things held up. Mine must have gone 13 years before it broke off. Anyway, they caught their mistake, and be glad yours is already the metal one. |
perrib Samba Member
Posted: Mon Sep 10, 2007 5:15 pm Post subject: plastic |
Vanogens seem well sealed compared to newer VW's cooling systems. After 1988. Vw used plastic exclusively for all flanges on all VW model. They barely last two years in ther heat of Phoenix. Many of the replacements are made in China and have a 3-10 month life expectancy. |
