Skaper Samba Member
Joined: August 08, 2007 Posts: 92 Location: Portland Oregon
Posted: Wed Jan 16, 2008 10:43 pm Post subject: |
Nice, good lookin out.
-Kenneth |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Wed Jan 16, 2008 9:15 pm Post subject: |
That adjustable resistor is used in conjuction with the "main" voltage dropping resistor to give me that 2nd speed. On high speed it's just the other resistor, on low speed it's both, and I can dial in the speed for the low fairly easily via the adjustment.
The heat is normal. That's exactly why you have to have high-wattage resistors, they'll burn up otherwise. That's why I have them hanging in the open there under the dash - better heat dissipation. They get hot because, basically, they are "burning" off half the voltage, leaving the other half for the wiper motor. I did not buy it from Radio Shack. I think it came from a place I used to work, we had a whole bunch of misc stuff around and that might have ended up with my stuff. You should be able to find them for sale from large electronics supply shops. I've seen them on ebay, like these 3 and 5 ohm varieties:
http://cgi.ebay.com/3-Ohm-25-Watt-Power-Resistor-A...dZViewItem
http://cgi.ebay.com/5-Ohm-25-Watt-Power-Resistor-w...dZViewItem |
Skaper Samba Member
Posted: Wed Jan 16, 2008 7:02 pm Post subject: |
glutamodo wrote: |
That's my diagram up there - not keith's.
The resistors are not "colored" - they are high wattage ones, the little tiny ones you get at Radio shack will burn up in no time. Actually, one of them is a pair of high wattage resistors wired in parallel to achieve the resistance I wanted. The other is an adjustable resistor, which used so I could change it in winter time to get faster speeds out of it. This is what the variable one looks like:
The resistor values, the That diagram is in my Gallery on the Samba, and here is the caption that goes along with it:
-Andy |
I just had to put in a new switch on my 64. So the adjustable resistor is good for faster speeds, did you get that at radio shack also ? This being the first time I messed around with my resistor, I noticed that it was getting pretty hot. Is that normal or did I wire it wrong? |
DL West-Wiperguy Samba's Wiperguy
Joined: November 02, 2005 Posts: 432 Location: McMinnville Oregon
Posted: Wed Jan 16, 2008 1:50 pm Post subject: |
You need to be grounded at the switch where the escutcheon nut mounts at the dash. And the ground strip on the frame mount must be in contact with body. As the motor is braked by switching the current. If they are not grounded they will not turn off. They will only slow down a bit and run on after you turn off the switch. Then you have to pull wires to stop it. DL |
69project Samba Member
Joined: December 02, 2006 Posts: 9 Location: Boise, Idaho
Posted: Wed Jan 16, 2008 12:48 pm Post subject: Ground for wiper switch |
Can anyone tell me what "ground connected" in the wiper switch diagram means? I assume that because the wiper system is ground isolated and the switch is just switching ground that it means the terminal is connected when the switch is in the on possition. I just want to make sure.
Thanks, |
jign4bass Samba Member
Joined: December 09, 2006 Posts: 588 Location: Bakersfield, CA
Posted: Fri Sep 14, 2007 7:32 am Post subject: |
glutamodo, sorry about the mix up on drawings. Both were very helpful. I am going to give it a shot this weekend. I hope that no sparks fly!!
Thanks. _________________ Rob
So....how much is this going to cost me?
62 Custom Beetle
1776cc w/Dual Dell 36 DRLA's |
Posted: Thu Sep 13, 2007 3:19 am Post subject: |
Quote: |
Wiring Diagram I drew up showing the two-speed wiper switch from 1967 compared to the 1966/earlier setup. Also how to wire the two-speed switch to a single speed motor.
Also how to achieve two speeds when using a 6V motor on 12V, using a two speed switch and a single speed motor by using two separate dropping resistors.
On my car, I have resistor number 1 of about 1.3 ohms
Resistor number 2 is an adjustable resistor set at about 1.7 ohms.
With that setup, slow is only in the middle position of the switch. You get fast speed in position two and when it is self-parking. |
-Andy |
Posted: Wed Sep 12, 2007 8:34 pm Post subject: |
keifernet, what color resistor did you use? I'm kinda diggin' the two speed set up.
Thanks, _________________ Rob
62 Custom Beetle
Posted: Wed Sep 12, 2007 7:53 pm Post subject: |
Thanks to all. Very helpful. _________________ Rob
62 Custom Beetle
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Wed Sep 12, 2007 8:05 am Post subject: |
See... "handy Andy" already had it all figured out and drawn up!
Nice work as usual bro... |
Posted: Wed Sep 12, 2007 7:59 am Post subject: Re: Windshield Wiper Switch Wiring |
jign4bass wrote: |
I ordered a new wiper switch for my 62 bug from WW. My wiper motor is 12v and has connections for 54d, 31b and 54. The switch has connections for 31(2ea.)., 31b, 53, 53a, 53b. My question is is what goes where?
Did you come across this diagram I drew up regarding using that switch combination?
Posted: Wed Sep 12, 2007 7:52 am Post subject: |
jign4bass wrote: |
Pantone 149 were you able to find your drawings?
Thanks. |
If he got both a 12 V 2 speed motor and switch then his will be wired the way the diagram I posted is... if you have a single speed motor and are trying to use the 2 speed switch then the numbers on your motor will not match up to the ones on that switch... but with test light or on the bench with a battery or battery charger you can easily work out what is what. I mean you only have a hot, a ground and the one speed hot... |
Posted: Tue Sep 11, 2007 9:24 pm Post subject: |
62 Custom Beetle
pantone149 Samba Member
Joined: August 19, 2004 Posts: 1018 Location: Mt. Shasta
Posted: Thu Sep 06, 2007 2:21 pm Post subject: |
I recently went through the exact same thing. Got a 12 volt 67 motor and 2 speed 67 switch. I may have my notes staill at home. Will try to get you solid information tomorrow. |
Posted: Thu Sep 06, 2007 9:29 am Post subject: |
Does not mean you can't use it... use that diagram and hook it up so the motor runs on the firt click... |
Posted: Thu Sep 06, 2007 8:38 am Post subject: |
Yes I did, I guess. Kind of a novice, if you haven't noticed!! Thanks for the help. _________________ Rob
62 Custom Beetle
Posted: Thu Sep 06, 2007 8:11 am Post subject: |
Sounds like you may have gotten a later 2 speed switch?
Posted: Thu Sep 06, 2007 6:21 am Post subject: Windshield Wiper Switch Wiring |
Thanks as always,
Rob _________________ Rob
62 Custom Beetle
