madmax25 Samba Member
Joined: March 04, 2007 Posts: 204 Location: Kansas City MO
Posted: Fri Sep 07, 2007 3:58 pm Post subject: Driver door lock mod? |
Has anybody been able to mess with the driver door lock so it can be locked when the door is open (like the pass. side)?
Life would be so much easier if I didn't have to take the whole 6 1/2 seconds to close the door, stumble for the key and lock it from the outside every time... _________________ -Elliot
'88 Vanagon GL "Big Red"
'90 Westy |
McHuntley Samba Member
Joined: November 12, 2002 Posts: 791 Location: Costa Mesa, CA
Posted: Fri Sep 07, 2007 4:00 pm Post subject: |
Thats Interesting.
Both my Drivers and Passengers door locks have to be locked with a key.
What was done to yours to enable this?
Do you have Central Locking in your vanagon?
Matt _________________ Any opinions stated here are my own, otherwise someone else would have said them. |
Posted: Fri Sep 07, 2007 4:12 pm Post subject: |
sorry I didn't specify...it's an 88 with manual locks. The passenger door can be locked with the little knobby while the door is open but the driver's can't...
And everything's stock so it hasn't been messed with......yet ...
Interesting you need a key for the pass. door...what have you got in your van? _________________ -Elliot
'90 Westy |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Fri Sep 07, 2007 10:59 pm Post subject: |
It is very easy to "fix" the lock for the vanagons so that they are lockable from the inside. Once you figure out what you need to do it only takes 10 minutes to "fix" The only tool needed is a dremel tool with a pointy grinding stone. Once you have to removed the locking mechanism from the door and look at the working parts you will see that there is a metal tab that stops on a cam of the door lock if it is in the open position
Here is a better picture of the location of the offending metal tab that has to be removed from the mechanism.
Get out you trusty dremel and pointy grinding stone (this stone was a little too wide, but it did the job with minimal unwanted damage. Please note that you have to lift the spring out of the area to avoid unwanted damage to it.
Here is a better picture of the tab that needs to be ground off and the spring that if lifted out of the area to avoid damage.
What you are trying to do is grind the edge of the tab that touches the cam and make it weak enough to bend out of the way and break off. With bending it a few times it will fall off and you can finish grind where it broke off. Try not to take off too much material from the metal arm that it is attached to and spray the mechanism with your favorite lube before replacing it in the door. Also remenber to place a hide a key somewhere outside the van in case you accidentally lock the keys inside the van. I have done this mod to several vans with and without power locks and have never looked back. When I bought my last van the first comment GF made was that the locks had to be fixed of course the second comment is that I own too many cars. Good luck.
Mario |
MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Sat Sep 08, 2007 9:39 am Post subject: |
When it comes to hiding a key, I gave up with those little magnetic hide-a-key holders years ago and have a spare key attached with a sheet metal screw to the underside of the body in an invisable but easily accessible place (I'll let you figure out where).
A pocket knife, screwdriver, or a dime will get you into the car. For me, it's even a two-step process, as the side door lock has been replaced so the key under the van is just the door. The actual ignition key is hidden elsewhere inside.
I haven't had to use it on the van yet (as I haven't done Mario's modification so I haven't locked the keys inside) but the open-it-with-a-dime has saved my patootee a number of times with previous vehicles. _________________ 1984 Westy with tencentlife power! |
Posted: Sat Sep 08, 2007 7:48 pm Post subject: |
Thanks a bunch Mario, just what I was looking for!
Elliot _________________ -Elliot
'90 Westy |
Posted: Sat Sep 08, 2007 9:41 pm Post subject: |
Play with the mechanism a little bit to simulate locking and unlocking and you will see the tab that needs to be ground off. I couldn't get a really good picture of the tab, but the pictures show you the area that it is located. You will never miss the way VW design the locks to work.
I have always put a hide-a-key somewhere under my cars because if I ever lock the keys in the car it is always at the worst possible time. I always look under a new to me car and usually find a spare in much better shape than the key given to me that I can make copies for backups. Good luck. |
1621 Samba Member
Posted: Sat Sep 22, 2007 6:23 am Post subject: |
GREAT mod. I followed your instructions and it worked out perfectly. I may actually start using my drivers side door rather than exiting from the slider all the time. Thanks! _________________ '85 Westy |
dokarex Samba Member
Joined: January 13, 2007 Posts: 251 Location: SHELBURNE NS
Posted: Sat Sep 22, 2007 7:24 pm Post subject: |
Why are you "fixing" probably the smartest thing ever done to a vehicle? Just imagine how much money CAA(AAA) gives to the big three to make sure everyone else can lock their keys in the car, not ot mention Apple and other auto glass places.
I actually was telling the wife that I can't believe other manufactors haven't don this to their cars I've never locked myself out of a VW but have ruined many good coat hangers on other makes. |
?Waldo? Samba Member
Posted: Sat Sep 22, 2007 8:21 pm Post subject: |
Mercedes are the same way. Brilliant. Because I live in a dry climate I like to keep the key in my hand anyway while I step out of the vehicle and then touch it to the latch post on the chassis so that the inevitable static shock is discharged there rather than to my hand when I go to shut the door.
Andrew |
Posted: Sun Sep 23, 2007 10:06 am Post subject: |
I have locked my keys in my vws only a few times in 21yrs. of owning various VW models. The vanagon is the only VW that I have owned with this feature built in- I have owned many aircooled VW's in the past. I don't like the feature and I found a better way that works for me. There is a reason that I put a hide-a-key under the van- although I was a licensed reposessor at one time and I could get into my car easily.
1621 Samba Member
Posted: Sun Sep 23, 2007 10:16 am Post subject: |
I've never locked my keys in any of my cars, ever. But damn you for making me utter that statement because I'll now lock myself out before work tomorrow.
Just keep a spare hidden somewhere outside the vehicle as was mentioned before and hopefully you'll never have to use it. _________________ '85 Westy |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Sun Sep 23, 2007 11:38 am Post subject: |
I have only locked keys in a car one time. It was a car that let you lock before you close the door.
I happen to like it. _________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
ctilander Samba Member
Joined: December 29, 2007 Posts: 14 Location: Oceanside
Posted: Wed May 26, 2010 4:30 pm Post subject: Vanagon dvr/psgr door actuator??? |
My (new) 88 Vanagon GL wolfsburg weekender 2.1, drvrs/psngr door locks remain in the open position, I went to a locksmith and he recommended I take off the sliding passenger door handle (because it was easier to take off) to get the key number, I did, and he made a factory cut key. It now fit and operated the sliding door but the dvrs and pasngr door will now lock with doors open or closed. Rear hatch works fine. Any suggestions or recommendations would be greatly appreciated, thank you |
buttonwagon Samba Member
Joined: May 16, 2010 Posts: 27 Location: Bellingham, WA
Posted: Sun May 13, 2012 8:35 pm Post subject: |
This is amazing!
Thank you so much for the detailed step-by-step!
I used the diamond wheel point attachment for my dremel -- it was the only attachment I had to get in there.
http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=7144
Now a passenger can lock their own door -- no funny exit procedure needed.
Cheers! _________________ 'Tic-tac' 1965 Bug
incredibleincredible.com |
albertr Samba Member
Joined: February 10, 2015 Posts: 1 Location: Pennsylvania, USA
Posted: Tue Feb 17, 2015 5:45 pm Post subject: |
This mod can be done on EuroVan too! The lock is slightly different, but the same principle applies.
Here's the original EV lock:
Here it's cut half way through:
Mission accomplished! Took for me about 10 minutes with dremel to mod it. It's really very easy.
Next on my list is automatic lock/unlock mod.
-albertr |
danclark Samba Member
Joined: September 29, 2014 Posts: 63 Location: Kentucky
Posted: Tue Feb 17, 2015 7:23 pm Post subject: |
did you guys shoot the mechanism with WD-40 or somesuch upon completion of the mod? |
bluebus86 Banned
Posted: Tue Feb 17, 2015 8:21 pm Post subject: |
danclark wrote: |
you probably should use some lube that is longer lasting and has a thicker film than WD-40 WD 40 is a little too wimpy, a grease or heavy oil would be good. Many of the locks I have worked on appear to be factory greased., but the grease does dry up after 40 years, good suggestion, but WD-40 is not the best for this _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Feb 17, 2015 9:11 pm Post subject: |
Triflow works well. I would avoid WD40.
Good luck |
jwallis Samba Member
Posted: Sat Dec 29, 2018 2:00 pm Post subject: Re: Driver door lock mod? |
Got this done. Made a video about the locking mechanism and what to grind off: https://youtu.be/_UpPBrtWMQ0 _________________ TheVanTracker.com - Kill Switch + GPS Tracker + Door-open alerts, made specifically for the Vanagon!
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
