jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Fri Sep 14, 2007 11:27 pm Post subject: steering wheel paint |
anybody ever try Krylon Fusion Plastic paint on a steering wheel? would it work better than regular spray paint? _________________ www.cultwagen.com |
Paul D Samba Member
Joined: July 30, 2006 Posts: 565 Location: Far away from the fruits & nuts
Posted: Sat Sep 15, 2007 5:09 am Post subject: |
Yes, tried both - first regular spray paint and that turned out really horrible. I then put on the Fusion plastic paint and it coated the wheel much better and had a nicer finish. Unfortunately it always seemed "sticky" even after months after drying. I ended up putting a leather wheel wrap. I can't wait to see if others have some ideas. _________________ 76 Fuel Injected Standard Bug
KantDriveFast wrote:
Quote: |
As cool as it is to find old VWs that have been sitting since the '70s, most of these are cut up (buses especially) and smell like weed and feet. Sad |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Sat Sep 15, 2007 5:23 am Post subject: |
duplicolor has a creamy white that works pretty good on wheels.
real paint is better but not always available. _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
Posted: Sat Sep 15, 2007 6:08 am Post subject: |
Foxx4086 JHC wrote: |
real paint is better but not always available. |
how well does it hold up? my wheel is mint just not sure it matches the car. should i just leave it alone? interior needs to be done so i could match it around the wheel
Foxx Uncle Meat
Posted: Sat Sep 15, 2007 9:58 am Post subject: |
a lot of good paint shops not only can match any color, but a lot can also make it up as spray paint but the duplicator holds up alright i suppose.
you can use it on the seat bottoms too as well _________________ Frank
OG JHC
59 panel
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Wed Sep 19, 2007 9:22 pm Post subject: |
I would paint that thing! From what I have heard, anytime you use spray paint it feels a little gummy. Single stage paint here would be fine. Even a really cheap gun would suffice. In fact if you scuffed it I bet a painter would hit for ya for next to nothin (you provide the paint). |
Posted: Wed Sep 19, 2007 9:35 pm Post subject: |
I used kylon fusion then hit it with a clear coat. not gummy at all. _________________ www.cultwagen.com |
buguy Samba Member
Posted: Wed Sep 19, 2007 9:38 pm Post subject: |
Good for you, much cheaper alternative. Has it sat out in the sun yet? Did you use spray paint clear? |
Posted: Wed Sep 19, 2007 9:43 pm Post subject: |
its only been a few days. i will post up how it held up in a few months. _________________ www.cultwagen.com |
buguy Samba Member
Posted: Wed Sep 19, 2007 9:44 pm Post subject: |
Best of luck! |
