BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Sep 17, 2007 9:26 am Post subject: distributor points plate oil or grease or what |
I searched in the engine threads, already, so sorry if this isn't split specific. I completely disassembled my distributor and was wondering if the points plate gets grease or oil put on it. It's a late '67 distributor without the felt in the middle of the shaft. It has the fiber washer and steel spacer between the cam and the body. The shaft has the spiral oiling grooves. Also the points plate advance bearing surface has faint oiling grooves in it. Does the oil get on there automatically or what? There's no place to oil it manually.
Here's the advance/points plate thing.
Here's the faint oil grooves.
The body of the distributor where the bearing rides.
I'm hoping the oil comes from the shaft and weeps out to the points plate grooves. Any one know? On older ones I always just greased it and forgot about it. |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Mon Sep 17, 2007 9:53 am Post subject: |
I think Glenn is our resident distributor expert. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Mon Sep 17, 2007 11:20 am Post subject: |
Bosch distributor grease.
You're not going to get any lubrication from the engine. Also since it barely moves the grease will do the job. _________________ Glenn
Member #1009
#BlueSquare |
BarryL Samba Member
Posted: Mon Sep 17, 2007 3:11 pm Post subject: |
Thanks Glenn. I just happen to have a tube of Bosch grease. I'll check if it says distributor on it. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Sep 17, 2007 8:47 pm Post subject: |
I'll second the Bosch grease sollution and need to ad that you are missing the ground wire from your points plate to distributor body. You'll want to solder one on before you reassemble. |
BarryL Samba Member
Posted: Tue Sep 18, 2007 7:28 am Post subject: |
It's under there you just can't see it. I thought they were welded? How many trillion times can it flex before it breaks? I've always wondered that about my motorcycles, too...you know how the handlebars are always turning back and forth? |
BarryL Samba Member
Posted: Thu Sep 27, 2007 4:19 pm Post subject: |
With the distributor in place the solid shaft moves a little with the rotor like there's slack in the distributor drive dogs when moved by hand. Does the shaft settle into the direction of rotation against the dogs or what? The timing is avanced or retarted depending on where I release the rotor on this one because of the slack. |
Stocknazi Samba Member
Posted: Fri Sep 28, 2007 10:48 am Post subject: |
make sure you have a good connection on that dizzy groung wire. i have had a roadside problem b/c mine had almost become detached. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
