What windshield wipers?
Page: Previous  1, 2
dan macmillan
dan macmillan is offline
PostPosted: Tue May 03, 2011 10:52 am    Post subject: Re: What windshield wipers? Reply with quote
BL3Manx wrote:
PK Socal wrote:
Is there a particular year assembly that works well in a glass buggy. Is there even a link that shows exactly what the WW assembly looks like?
If you decide you want an electric wiper assembly, to clear the back of the dash, etc., it should be one that looks like this. Not sure of exact years but I think 58-67. The 67 is best because it has a 12v motor, however you can buy the new pieces to upgrade a 6 volt wiper motor to 12v.
You need longer bus wiper arms or need to extend the sedan arms.
On one of my buggies I had a motor clearance problem. I used a wiper assembly just like this one. The solution was to remove the motor and relocate the motor to a more spacious area {to the left of the steering column}. The pushrod that runs from the motor to the left wiper shaft was then lengthened and shaped to clear any obstacles.
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
aburger01
aburger01 is offline
PostPosted: Sun Aug 30, 2015 7:30 am    Post subject: A SOLUTION - manual handheld wiper, no welding ! Reply with quote
I worked out a very simple and clean solution for a manual/handheld wiper setup on my buggy. Searched high and low for a solution, I saw this post that had a similar setup mounted on the top of the window (North Carolina buggy) - I have little to no room behind my dash for automatic wipers, post 68 integrated speedo/gas gauge and electric fuel pump center mass, so I got busy working out something that anyone can duplicate easily, cheap, no welding.
Less than $100 check this out !!!
One Modification needed. The Size of the eyelet on the adapter is 3/8" - the threaded barrel on the Marinco wiper is 7/16" - I used a 3/8" sharp/new drill bit and slowly made the 3/8" hole to exactly the size where it actually fit in a threaded manner over the barrel. Once done, screwed the adapter 10mm directly into the MANX mirror mount which is also 10mm with loctite - its very stable. adjusted the manual arm to work closely next to the mirror side. Its out of the way, very stable, and looks great. The Marinco wiper is a little more expensive than the cheaper ones you can buy, however, most of the parts are stainless (specific boat manufacturer) - see below final assembly and installation:
AMAC1680
AMAC1680 is offline
PostPosted: Sun Aug 30, 2015 8:43 am    Post subject: Re: A SOLUTION - manual handheld wiper, no welding ! Reply with quote
Very nice indeed!
I've been using a clamp on golf cart deal and it looks like crap. I'm also from the school that it would meet regs in Florida . I'll be doing a copy, thanks.
From Florida code.
(3) The windshield on every motor vehicle shall be equipped with a device for cleaning rain, snow, or other moisture from the windshield, which device shall be constructed as to be controlled or operated by the driver of the vehicle.
(4) Every windshield wiper upon a motor vehicle shall be maintained in good working order.
AMAC
aburger01
PostPosted: Sun Aug 30, 2015 12:52 pm    Post subject: UPDATE - first road test Reply with quote
Solid as a rock, pulled it down just about 1/2" from where it was before for exact horizontal alignment with bottom of windshield glass - no buffeting at high speeds, didn't budge, easy reach to operate:
[/img]
VW Aircooled Society
VW Aircooled Society is offline
PostPosted: Fri May 05, 2017 10:30 pm    Post subject: Re: A SOLUTION - manual handheld wiper, no welding ! Reply with quote
[quote="AMAC1680"]
Very nice indeed!
From Florida code.
AMAC
Here is the solution.. we just made a handful of these and used Stock Billet Aluminum...
Innovating Parts for Aircooled VWs & Dune Buggies
www.vwaircooledsociety.com
Last edited by VW Aircooled Society on Sat May 06, 2017 11:31 pm; edited 1 time in total
Singerdude
Singerdude is offline
PostPosted: Sat May 06, 2017 8:40 am    Post subject: Re: What windshield wipers? Reply with quote
Thank you Wolfgang, I will be placing an order in the coming days Smile
BL3Manx
BL3Manx is offline
PostPosted: Mon May 08, 2017 7:59 am    Post subject: Re: What windshield wipers? Reply with quote
The other option which allows use of a top and wind deflectors and leaves it out of your vision when not in use, is to have a hole cut in your windshield and use one of these https://www.amazon.com/Marinco-31000-Wiper.../dp/B000NI1D2I
PostPosted: Mon May 08, 2017 8:23 am    Post subject: Re: What windshield wipers? Reply with quote
BL3Manx wrote:
The other option which allows use of a top and wind deflectors and leaves it out of your vision when not in use, is to have a hole cut in your windshield and use one of these ]
You cannot cut a hole in your windshield without cracking it...so your suggestion will not work
BL3Manx
BL3Manx is offline
PostPosted: Mon May 08, 2017 1:37 pm    Post subject: Re: What windshield wipers? Reply with quote
You can't cut/drill a hole in tempered glass(side and rear glass).
Your windshield is laminated Safety glass. It can be cut/drilled by an automotive glass shop. Here is a video of it being done. https://www.youtube.com/watch?v=JXSDBd3_DO8
The edges of the hole should be dressed after to stop cracking
Gary0302
Gary0302 is offline
PostPosted: Mon May 08, 2017 2:20 pm    Post subject: Re: What windshield wipers? Reply with quote
Even though my original photo shows the bracket mounted on the top of the windshield, nothing prevents that same bracket from being mounted on the side of the windshield frame. I have mounted it there myself in the past, locating it just above the level of the top edge of the hood. It did not affect the wiper arm's use in any negative way.
Gary David Holbrook
Facebook and YouTube
Coastal North Carolina
Check out my videos on Youtube
"It's a buggy not a space shuttle...." - Dale M.
"When in doubt, blame it on the previous owner" - Gary0302
PostPosted: Mon May 08, 2017 6:09 pm    Post subject: Re: What windshield wipers? Reply with quote
Why go thru all that trouble and expense to get that procedure done ?
It's cheaper and less of a hassle to just the wiper arm..
Like Ronco.. Set it and Forget it !
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Thu May 11, 2017 2:20 pm    Post subject: Re: What windshield wipers? Reply with quote
I've neen a resurgence in interest in this type of hand wiper in the US in recent years and to be honest, I just don't get it.
I've built and worked on numerous Manx and Manx type buggies since 1970 and have been able to fit the stock Beetle rack (granted sometimes with a bit of shimming and tweaking ) to all of them, most with a centre mounted VW speedometer/fuel guage. Bruce even molded two little humps on the hood spaced to take one to make it easy.
Surely if it's raining and you haven't got a top then you're going to get rain water on both sides of the screen, so what? You use this little wiper with one hand and clear the inside of the screen with the other and...steer with your knees? I'd sooner keep both hands on the wheel thanks. If you have got a top then you can't fit one of these anyway so to be safe you need electric wipers.
Good visibility is paramount for safe driving in today's traffic so why risk your own and the safety of others for the sake of the simple fittment of a wiper rack, arms and a switch.
My Manx 2 fitted with an early 70s 12v two speed rack, Land Rover spindle adapters and classic Mini Cooper S stainless blades and arms.
AMAC1680
AMAC1680 is offline
PostPosted: Thu May 11, 2017 5:11 pm    Post subject: Re: What windshield wipers? Reply with quote
The little crank wipers not for clearing the windshield it's about keeping the law at bay. Theres not a wiper, power or otherwise, that will clear both the inside and outside in a Florida downpoor. IMO they just take up space.
AMAC
www.SEGS4VETS.org
manxdavid
PostPosted: Thu May 11, 2017 11:30 pm    Post subject: Re: What windshield wipers? Reply with quote
If I were a Florida cop (of which I actually know quite a few) and I was presented with one of those as a wiper I'd probably say 'seriously?' and find something else to ticket you for...lol...
Wiper mechanism taking up space? Not useable space though surely?
I take the point about Florida downpours but they do have ordinary rain there too, or at least they do in the part I visit (Panhandle).
AMAC1680
AMAC1680 is offline
PostPosted: Fri May 12, 2017 3:13 am    Post subject: Re: What windshield wipers? Reply with quote
Taken up space was simply an simply an expression.
Yes we have regular rain here too but the natives just don't notice it.... Wink
AMAC
www.SEGS4VETS.org
manxdavid
PostPosted: Fri May 12, 2017 4:36 am    Post subject: Re: What windshield wipers? Reply with quote
AMAC
Sure, but I'm still more in favor of building 'up to a specification' of at least what the donor Bug was fitted with rather than 'what can I get away without?' A few Americans have asked what the little black spot on my hood to the rear of the gas cap is, obviously not used to seeing washer jets on a buggy...lol...
PostPosted: Fri May 12, 2017 8:32 am    Post subject: Re: What windshield wipers? Reply with quote
Florida cops don't give a damn.. they are just too busy texting and driving so they are not going to write anyone up for anything else..
Here is a video of typical south florida weather and rain.. this video was filmed by my business partner Val using Rain X
Page: Previous  1, 2
Page 2 of 2
